Question about Pride Mobility Pride TSS300 Power Chair - Used Electric Wheelchairs
50 amp Fuse - Pride Mobility Pride TSS300 Power Chair - Used Electric Wheelchairs
2000 z3 location for fuse 107 50 amp
Joseph, check the fuse distribution panel in the engine compartment; your car's owner's manual should have the diagram & labeling to that panel and the fuse panel in the cabin compartment; sometimes diagrams are on the covers too.
If that's a problem, purchase or download service repair manual specific to your vehicle.
Do It Yourself and DIY Auto Repair by ChiltonDIY
Haynes Manuals
Car Repair Manuals Chilton Haynes Bentley
Feb 23, 2017 | Cars & Trucks
Why is fuse E hot on ground side w/key in on position. w/fuse removed.
Fuse E is 15 amps, not 50 and does not have a "ground side". The fuel pump relay receives power through 20A fuse O. The fuse links are "hot all the time" because they are connected directly to the positive post of the battery.
May 16, 2014 | 1994 Ford Bronco
95 mercury marquis ignition switch pin b5 is missing 12 volts- where does it come from?
B5 - 276 Brown - Switch Feed
Fuse 1 (15 amp) & Fuse 10 (10 amp) in the IP fuse box.
And, 50 amp Fuse in engine compartment fuse box. behind batery
please rate, thanks
Jun 27, 2011 | 1995 Mercury Grand Marquis
I am looking 4 a 50 amp fuse that came with it, can't fid it can i use a 40 amp? this is four a 1000 cobra
if your are looking for a 50 amp fuse i have found my self going to a care audio place they have the bigger fuses on had to to amps and so on hope this helps good look
Jan 08, 2011 | Cobra CPI 1000 DC to AC Power Inverter
Keeps popping a 50 amp fuse to the ignition. was driving it and it died,now it keeps popping a 50 amp fuse thats labled ignition in the fuse panel under the hood.
its shorted out somewhere check your injectors wires 1 may have had the insulation rubbed off of it and its grounding out
Nov 27, 2010 | 1998 GMC Sierra
What number is the horn fuse
The horn fuse is in the Power Distribution Box. It's the second fuse from the top of the box in the right side row, below a 60 amp fuse, above a 50 amp fuse. It is a 20 amp fuse.
Nov 17, 2010 | 1996 Ford Explorer
Alternator charging system
try the 60amp fuse under the bonnut there is a 30/40/50/60 amp fuse,s there the 60 amp is the charging fuse. i had the some thing it was the 60 amp fuse its all ok now the alternator fuse ok 60 amp.
Jan 31, 2009 | Suzuki Sidekick Cars & Trucks
Radio and all dome lights are not working.
interior fuse should be the culprit. Look for the Radio fuse inside (normally 10A red) sometimes labeled CABIN on the fuse layout
Dec 25, 2008 | 1999 Toyota RAV4
What size fuse do i need for amp
start with a 50, may need to increase it if you are not using a large capacitor.
600 watts = 12x
x= 600 watts / 12 volts
x = 50 amps
Dec 13, 2007 | Legacy Audio American Legacy II LA490 Car...
Basslink
make sure ur ground cabke is as large if not larger then ur poweer cable.
Oct 11, 2007 | Infinity BASSLINK Car Subwoofer
Pride Mobility Pride TSS300 Power Chair - Used Electric Wheelchairs Logo
42 people viewed this question
Top Pride Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Scooter Doctor
Scooter Doctor
Are you a Pride Mobility Health and Beauty Expert? Answer questions, earn points and help others
