Beko wmb 81221 ls
Water leaking from detergent draw
SOURCE: Indesit W123 s UK water overflows from the detergent draw
My machine clicked round, although I did not have the water overflow. I managed to unlock the pump filter, on the front of the machine under the lower panel. This was fiddly. I removed a coin. The machine worked again, but two cycles later starting clicking round the timer. I called an engineer - it worked when he was here, he checked the element and pump and said it was OK. When he had gone, it clicked round the timer again! He came again, and once again it worked perfectly when he was here. Eventually I checked the pump filter again, and removed another two coins. At the moment - it is working!
Posted on Nov 26, 2006
venexcsd
  • 1185 Answers
SOURCE: washing machine help
If it fills up while just standing it is the filler valve , they are easy to replace
You need to take the back off the machine and with no power on listen to hear if water is trickling in, if it is then change the valve.
If it fills up while working then you need to do the same as above only this time take off the pipe which runs from a small tube shaped plastic moulding at the bottom of the outer tub to what looks like a small flying saucer which sits near the top
Blow into the tube and you should hear a clicking sound as you blow and release
If you can hear that the switch should be OK and I would then go back down to the Air Bell and make sure it does not have undissolved soap clogging it up inside
Posted on Jun 23, 2009
barkencoa
  • 3463 Answers
SOURCE: When on final spin, water leaks from detergent
You probably need to clean the filter.
Remove lower rear cover of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Posted on Jan 18, 2010
Jahn27
  • 1554 Answers
SOURCE: Miele 435-plus washing machine Problem: water
There's a hose or tube that goes from the dispenser cavity to the tub that is likely clogged. Small clothing can be siphoned into the hose or tube and block the water path causing it to leak out to the dispenser drawer. Locate the hose/tube port in the tub where the blockage may be located, if not, you have to remove the front panel fully access and take the hose/tube out for inspection.
Disconnect power then remove the screws attaching the top panel to the rear of the machine and slide it rearward and off. Remove the dispenser drawer then the screws securing the console to the machine cabinet. Lift the console off then remove the screws securing the front panel to the cabinet. Slightly lean the front panel forward and disconnect the door lock and switch assembly wire harness. Remove the front panel and set it it aside. The hose/tube can now be fully accessed for inspection. Reassemble the machine in reverse order of the disassembly steps.
Let us know if you need further advice. Please accept the solution should you find it helpful and informative. Accepting the solution will not stop you from communicating with the expert. You can still communicate with the expert as long as you need further advice regarding the issue stated herein.
Posted on Feb 25, 2011
kelvin971
  • 6 Answers
SOURCE: Water leaking out slightly from
Our was blocked. See solution here: http://www.fixya.com/support/t12512233-whirlpool_wfs1273bd_leaks_water_from
Posted on Aug 27, 2012
Why dosen't Beko WMB 61631s washing machine work?
sounds like a software problem.
Try unplugging for 2 hours, then replugging and starting the cycle.
The long unplug is to drain memory voltage.
Aug 19, 2014 | Beko Washing Machines
I have a beko wmb washing machine that stops working as soon as its put on and then the wash and ready lights start flashing... what could be wrong?
Try reading the "troubleshooting" section of the instruction manual. If you don't have the instructions, go to the Beko web site and download them.
Oct 21, 2013 | Beko Washing Machines
How to reset Beko wmb 91242 LC? Machine won't do
My washing machine beko WME7247W won't do anything it said C on it won't start change tem do anything can you help me
Apr 08, 2012 | Washing Machines
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
