Question about Samsung SCX 4521F All-In-One Laser Printer
Printer - Double feeding paper problem
My printer pulls an additional paper right after the first one was entirely pulled in (and is almost completely out) and then the printer stops with a "paper jam 1" messege. Thanks, Yaron
mdsaeed67
  • 849 Answers
SOURCE: fake paper jam
the roler, which picks the paper need to clean, try it
Posted on Oct 28, 2008
  • 5 Answers
SOURCE: paper keeps jamming
I was told by the local repair shop that Samsung made at least two mistakes on this printer related to the feed roller. 1) Many were installed backwards; reversing fixes it. 2) Many rollers were not manufactured correctly - replacement is about $20 (plus labor). They told me to call Samsung and ask them to at least cover labor to determine which problem; will do shortly. Don't forget, if you registered your printer, you got an extra 3 months warranty, 15 months total. I missed that by a month :(
Posted on Jan 20, 2009
ghassun
  • 499 Answers
SOURCE: Samsung ML 1510 LAser Printer
check the spring if it push the roller well or it's weak also check ur paper if its high quality to be rolled
Posted on Jun 12, 2009
  • 42 Answers
SOURCE: samsung ML2010 printer; paper jam
Lise, That is VERY similar to what I experienced yesterday. You can probably fix this by cleaning the rollers (all of them) thoroughly. See what I did exactly, and find directions to all the rollers from your manufacturer: http://annoyances-resolved.blogspot.com/2009/09/paper-jam-buy-new-laser-printer.html
Let me know if that helped you as it helped me solve the problem completely.
Posted on Oct 01, 2009
  • 24 Answers
SOURCE: paper jam, unable to pull paper out
Yeah, I would be careful though and only take out what screws you have to and document where they came from.
Posted on Jan 08, 2010
Preprinted 4 part paper crunching up when being printed in epson lq680 printer
Mustafa:
The printer is not meant to use multi-copy carbon invoices. The cause of your problem is the double-feed prevention pad below the paper pickup roller. When the first form is fed, the double feed prevention pad will stop multiple paper feeds. With multi-page carbons, the paper feed roller is trying to feed the form, and is pulling the top page of the form into the feed rollers while the double-feed prevention pad is stopping the bottom form from feeding and the top and bottom pages are sliding because of the carbon paper between the sheets. The only solution that I know of is to buy a printer with a tractor feed and pre-printed fan-fold forms with tractor feed strips on the sides of the forms.
Oct 13, 2012 | Epson LQ 680 Matrix Printer
No paper
give one paper per feed and try.
it must detect the paper.
if the paper is getting pulled in one side it must be OK with sensor.
just a proper cleaning work may be required
Oct 09, 2008 | Canon PIXMA MP460 All-In-One InkJet...
The printer keeps telling me it's out of paper, which it isn't
1> Open the sheet feeder cover and pull out the paper support.
Set paper, aligning the right edge of the paper to the cover guide with the paper's print side facing up.
Pinch and slide the paper guide to the paper's left side.
Note: Make sure to set paper lengthwise. Setting Credit Card sized paper long-side down by mistake may cause a paper jam.
Pull down the paper output tray supporting with both hands.
Pull out the extension completely.
Ensure that the Power lamp and the Auto Sheet Feeder lamp light.
Note: If the Cassette lamp lights, press the Paper Feed switch to light the Auto Sheet Feeder lamp.
If the Auto Sheet Feeder lamp does not light even after pressing the Paper Feed switch, Paper Source in the printer driver may be set to the setting other than Paper Feed Switch.
Nov 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Paper is pulled into printer unevenly causing paper jam
Look closely at the "path" that the paper takes through the printer -- you probably have a small piece of paper stuck somewhere, that is causing the paper-feed to get "skewed".
Failing that, take the printer to a qualified technician.
May 26, 2010 | Dell V313w AllInOne InkJet Printer
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Clear the jammed paper as follows.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
4. Close the front cover.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
How do I fix a paper jam? I've got paper jam around the exit roller and I can't get it out?
There should be a way to unlock one of the sides. Try taking out the toner cartridge and going in that way. If you can see the paper, get a pair of needle nose pliers and SLOWLY see if you can pull the paper out.
Sep 21, 2009 | Samsung CLP-510 Laser Printer
Lexmark X5400 Series AIO Feed Problems
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Thanks, Anu
Jul 20, 2009 | Lexmark X5495 All-in-One &USB...
Printer 2480- my printer is pulling paper only on right side
Try this :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 16, 2009 | Lexmark X2470 All-In-One InkJet Printer
Paper pulling
Be sure your paper guides are tight against the paper. If so, then clean the feed wheels with a damp cloth (just water). If this helps temporarily, you might need to replace the feed wheels.
Jul 28, 2008 | Lexmark X75 All-In-One InkJet Printer
Canon ip90 printer wont grab paper
The most likely culprit is that the rollers that pull the paper are dirty. Use the steps below to clean the rollers.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
1) Confirm that the printer is powered on.
2) Remove any paper from the printer.
3) Press and hold the <Resume/Cancel> button.
4) Release the <Resume/Cancel> button after the Power lamp blinks three times.
Note: The Power lamp will blink and the paper feed roller starts cleaning itself by revolving.
5) When the Power lamp lights in green, repeat Steps 3 and 4 up to two additional times. (Please wait approx. 30 seconds for paper feed roller cleaning to complete.)
6) To confirm whether cleaning has been performed properly, set a blank sheet of plain paper (8 1/2 x 11 Letter size) in the sheet feeder or cassette.
7) Press and hold the <Resume/Cancel> button and release it when the Power lamp blinks three times. (The paper set in the printer is picked up and fed.)
8) Repeat the process as necessary
May 12, 2008 | Canon PIXMA iP90 Mobile Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
