Question about John Deere 670 770 870 970 1070 Compact Tractor Service Pricing Flat Rate Manual
Good alternator battery not charging - John Deere 670 770 870 970 1070 Compact Tractor Service Pricing Flat Rate Manual
The alternator is not charging the battery on my 2002 Alero, how do I fix this?
a bad battery would give a wrong judgement of an alternator output. take off your battery and replace with a working one, test your alternator output using a DMM it should read about 12.5 when engine off and 14v when engine start running any figure more or less shows you have a bad alternator or an incorrect input current to the alternator....hope this fixxx it?
Jul 14, 2015 | 2002 Oldsmobile Alero
Battery good, alternator good, starter good but my 1966 oldsmobile the alternator isn't charging the battery
Have you replaced the voltage regulator?
Unless you have changed the charging system and eliminated it, the alternator does not have a built-in voltage regulator like the newer ones do.
Be blessed.
Feb 06, 2013 | Cars & Trucks
Dead battery, replaced battery and alternator but still no charge!
if its not charging while running at14.5 volts or so you have a charging problem mabey no power to the alternator if its charging at 14.5 or so and the batery load tests good and its going dead over night you have a draw from some component in the system.
Dec 19, 2011 | 1994 Oldsmobile Cutlass Ciera
1999 dodge intrepid w/ 2.7 L engine and 280,000 miles. the dashboard battery light came on. i replaced the positive terminal at the battery due to corrosion. the dash light is still on. had both the...
did you have the alternator tested on the car? the alternator may be good but the wiring to it may have a fault, have some one do a charging test on the car, if it still shows that the it is charging have them do an AC current test it could be that the diode is out in the alternator which would cause the light to come on and also the battery to drain when the engine is off. If it is not charging on the car suspect the plug end on the alternator ( we see them fail alot ). there is also a charge fuse might check it. The charging is controlled by the BCM ( body control module). If no charge and plug and wiring are good , fuse is good , suspect BCM......GOOD LUCK
Dec 01, 2010 | 1999 Dodge Intrepid
Dash says battery not charging
Alternator is what charges the battery. The alternator isn't putting out enough of amps to charge your battery and you will get a light or gauge reading that the voltage is low.
May 11, 2010 | 1998 Cadillac DeVille
Battery wont charge changed alternator and battery still wont charge
fit a new reconditioned alternator and not one from a junkyard
Mar 30, 2010 | 1992 Ford F150 SuperCab
Alternator does not charge battery. Alternator light glows.
check for an inline fuse between the alt and battery,otherwise take a jumper cable from the positive terminal on the battery to the alt. battery terminal output direct and now check for charge
Mar 13, 2010 | 1984 Nissan Pickup
Alternator isnt charging my battery
Check and clean your battery cables.
Jan 10, 2010 | 1999 GMC Jimmy
After changing alternator and voltage regulator. Still not charging. 2nd $15.00 regulator replacment
Check your battery and check the ground wire from battery. Make sure all your wires are clean and good connections. A bad battery will not charge and a dead battery will not charge a alternator maintains a battery not charge a battery, so charge your battery completely before checking that the alternator is working. Check all the wires going to the starter for good tight and clean connections . Hope this helps...
Nov 26, 2009 | 1987 Dodge Ramcharger
Alternator not charging battery
If your "battery" light on the dash is going on and staying on the alternator is definitely faulty, either the diodes or the wiring. However, if the light doesn't come on when you turn the ignition key to "IG" position - befort it starts - check that the bulb is ok. The alternator won't work if the bulb is dead.
Jun 21, 2009 | 1998 Chevrolet Tahoe
John Deere 670 770 870 970 1070 Compact Tractor Service Pricing Flat Rate Manual Logo
141 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
