Speakers not working but coming out the tower
    Brigadier General:
  • 3,400 Answers
ANSWERD.
Posted on Jul 12, 2013
1.are the speakers okey.
2.are speakers cabels connected right.
3.I/O-shield back of the computer lightgreen contact audio out.
4.go to services and RESTART WINDOWS AUDIO .
Jul 12, 2013 | HP Compaq Business Desktop dx2400 - Micro...
No sound from this monitor. I have everything plugged in , volume icon is turned all the way, mute is off, adjusted speaker levels, etc on my desktop.
Firstly,
You need to check if the green cable from the computer tower is blugged into the back of the monitor (The cable looks the same at both the ends) this is for the output to come through the monitor.
If that is plugged in and if not working, Try a headphone on the tower and check if the sound is coming from the headphone, If yes, You will have to adjust the volume on the monitor or the speaker of the monitor might have gone bad. If there is no sound coming in, Then the problem is with the tower and not the monitor.
Dec 02, 2010 | Acer X193W LCD Monitor
My hp tower has a built in speaker how do I turn it off. I just want to hear sound from my speaks not the built in speaker
You have 2 options.
The easy one is: double click on the audio device at the task manager in order to open the audio mixer, try to locate the (internal) speaker slider and slide it all the way down. If the speaker slider is not viewable choose option and try to locate it at the new window in order to enable it and come viewable and then change it's volume. If the above method prove not to work you have to follow the hard way.
Open up the case. Locate near the front side of the tower the built in speaker. It has one pair of cables that are connected with a small plastic connector at the motherboard. Unplug the connector; maybe there is a clip in order to unlock the connector, use a small screwdriver with care not do make any damage at the motherboard. Close the tower and enjoy the sound from your speakers without the interference of the internal speaker.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Sep 04, 2010 | HP Compaq Business Desktop d330 Slim Tower
The system worked fine but has an intermittent connection in the main power tower unit..you can shake the unit or bump it heavily and the sound from the main tower speakers goes and comes with a lot of...
They are prone to bad solder connections on the power regulators and output ics. should only be a labor charge. est $60 -100
Not very easy to take apart, need to remove several screws on rear of unit, remove front grill remove some screws on front. disconect connectors remove amp and power supply board, resolder bad connections and re-assemble. I've done several would take me 30-45 min.
Nov 12, 2009 | Sony SA-VA1 Rear Speaker
Partial sound from my JBL E60 Towers
Are there 4 inputs on the back of the speakers? If so, you either need to hook up all four, or connect the upper and lower inputs to each other. The speakers come with gold plates that connect the upper and lower inputs, but you can just use speaker wire to connect them. At least that is what I did on the used set of speakers I bought when one plate was missing.
Mar 27, 2009 | Yamaha HTR-5830 Receiver
Speakers sound quiet and unclear
You probably burned tweeters and damage midranges but before disasembly check equalizer
Feb 27, 2008 | Audio Players & Recorders
MY MONITOR SPEAKERS
as you say that old speaker is working from the same tower means your computer is ok.
the problem is in speaker only.
plz chk that while shifting some wire must have broken or loose or speaker not connected properly.
ultimately chk connection.
Oct 17, 2007 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
