Question about Tools & Hardware - Others
Ryobi ebs-1310v bearings
Bearings on ryobi ebs-1310v belt sander are shot. stripped down but cant get motor (winding) unit out to get at bearings. exploded parts diagram shows surclips but none visible. any ideas please?
danny_murray
  • 55 Answers
SOURCE: power tool switch
Call this number they are in ohio but have in the past been able to help out 937-325-6441 give them the part number and tell them you have not been able to locate the part
Posted on Dec 04, 2008
efs_perpends
  • 1996 Answers
SOURCE: I have a ryobi belt sander EBS81321K Serial no
Is that a BE321VS belt sander? I'm not getting any hits on that number you listed, and Ryobi is a little picky about what model number you use to search their parts database...
If it is, try this link to see a page where you can access a parts list. http://www.ryobitools.com/support/parts_batteries
Click on the button to go to the Power Tools Parts Store, then click Repair Parts Catalog, then agree to terms and enter the catalog page. Select the Model tab, type 321 in the box and press Search...
That brings you to a page listing the BE321VS sander.
Select Illustrated parts list and click on belt sander. This will open the parts view. From there you can scroll down to see if that is in fact your sander, and if so, scroll down to part 23, and select the switch (#760390001) and add it to your cart. Now close the window with the part view, and navigate back to the page titled "Ryobi Electronic Parts Catalog" (a tab on your browser), click on shopping cart at top, and when that opens click on the button to proceed to checkout and enter your info and pay, etc.
The cost of the switch is $4.44 USD. This web site will only ship to a street address in the US, so let me know if you reside elsewhere....
Posted on Mar 27, 2009
efs_perpends
  • 1996 Answers
SOURCE: BROKEN RUBBER BELT FOR BELT SANDER
Maybe you can use a linked belt to replace it. Check the width of the old drive belt, and give these folks a call: Lee Valley
Posted on Apr 02, 2009
comax
  • 154 Answers
SOURCE: Bosch 3107DVAS Random Orbital Sander not working.
You must replace the fan assembly. The part number is
2606610901
Hope this helps
Posted on May 05, 2009
  • 384 Answers
SOURCE: I have a Ryobi 4x36 Belt Sander (BD4600). I've
Look for plastic build up in the motor. Try to air blow motor and belt drive.
Posted on Jun 16, 2009
How do you adjust the belt tension on the Ryobi BE321 belt sander?
Usually there is no belt tensioner on by sanders. Only alignment adjuster. Must use exact size belt.
Jan 06, 2015 | Ryobi Tools & Hardware - Others
Ryobi belt sander
is the motor turning the drive roller if not it could be brushes or new bearings ,or the other roller might need oiling ,and if none of this is right it may be the wrong size belt cheers
Mar 05, 2014 | Tools & Hardware - Others
Ryobi ebs 800 belt keeps sliding off
I have exactly the same problem. Did you find a solution to this??
Oct 10, 2012 | Tools & Hardware - Others
My makita 4"X24" sander makes
http://www.ereplacementparts.com/makita-9404-belt-sander-parts-c-97_103_535.html
I would say you have a bearing going out ether on the motor this web address will take you to a good break down of the housing I would say you need a motor bearing it will also give you a parts # but if you have a bearing supplier somewhere ( I look in yellow pages for electrical motor repair) you might find the bearing for a cheaper price just remember to take the old one with you so you are sure to get the same size. I have found bearing and belts for my table saws are the same as for some clothes washers for about 1/2 the price as ordering from sears
good luck
Pat
Oct 29, 2010 | Makita 9404 4'' x 24'' Belt Sander
I have a Ryobi BE-321 belt sander. The drive belt is strtipped. Are replacement belts still available?
Yes, you can purchase a new belt here:
http://www.ereplacementparts.com/ryobi-be321-belt-sander-parts-c-7931_7932_15013.html
Luke
Oct 27, 2010 | Tools & Hardware - Others
My Model # 362 Belt sander keeps breaking belts after just a few minutes of continued use. Why?
This is usually indicative of someone pushing down on the sander too hard while sanding. The motor in this sander is strong enough to pull the belt around even with too much pressure on the sander. This causes excessive heat to build in the sanding belt and sander shoe which causes the belt to break down prematurly. It's also very hard on the sander's bearings and motor. Use an appropriate sandpaper grit that will do the job without excessive pressure on the worksurface. This will make your sanding belts and sander work longer and cooler.
Sep 13, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
How do you replace the drive belt on a ryobi type be321
I tried the model number and can't find it on their site, but if this is a belt sander or planer you can "roll" the new belt in place without loosening anything. If this is another tool let me know and please give me all the information (tool type) and I will check further.
Aug 23, 2009 | Ryobi Tools & Hardware - Others
Belt slipping
I have a Ryobi sander with a belt slipping issue as well. The problem seems to be in the design, not on the user end. The drive barrel is made of a semi-hard, non-gripping material. Wood dust becomes a final release agent that breaks any grip that the barrel may have had.
To compound the problem, the more the belt slips the smother the underside becomes allowing for greater slippage.
I now know why this model was the least expensive unit. >.<
Jan 08, 2009 | Tools & Hardware - Others
Tools & Hardware - Others Logo
35 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
