Why is my volume not working on my speakers but coming out the tower
    Brigadier General:
  • 3,400 Answers
GO TO SERVICES AND RESTART WINDOWS AUDIO.
Posted on Jul 12, 2013
I have the infinity rs8a tower speakers and they sound good but when I turn the volume up the subs turn on and off on both towers
When sub-woofers are overdriven (played too loud) they create a lot of heat. You can try using an external fan or improve the ventilation around the speakers. Most good speakers have thermal cut offs that prevent permanent damage.
Mar 17, 2014 | Audio Players & Recorders
I'd like to hook up 2 auto speakers, 4 ohms @50 watts each, in place of my 2- 4 ohm computer speakers with built in amp by sony, the little towers with volume knob. Do you think it will work ok?
it will work fine. the original equipment is 4 ohm but wattage is not stated. likely the original equipment is less than 50 watts. Therefore things should be fine. Start out at low volume and increase gradually. If you hear distortion, turn it down.
Feb 24, 2014 | Audio Players & Recorders
How to double check speaker hook up on asus desktop computer
maybe they have the volume muted. Check to make sure the volume is not muted and that the speakers are plugged into the light green port in the back of the computer.
Make sure the volume on the physical speakers are turned on and turned up. And make sure the volume in the Audio Sound Properties it turned up and not muted.
If you see the speaker megaphone at the bottom right near the time click on it to adjust the properties.
You can click Start/Control Panel and look for Sound or Audio properties.
May 02, 2012 | ASUS Computers & Internet
I just bought Bose Companion 2 speakers which I don't know how to connect to my HP Pavillion desktop PC. The pdf instruction booklet does not help. There are multiple jacks (6) at the back of the tower...
You need to connect the speakers to the green jack in your PC.
Check your system sound volume setting to make sure it's not set to MUTE or the volume slider is on or near the lowest position - you don't specify what system you have on the PC so I can't give you an exact pointer but Volume Control generally is found under Programs -> Accessories -> Entertainment.
Please come back and rate the solution if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Jul 24, 2011 | Bose Companion 2 Series II Multimedia...
No sound from this monitor. I have everything plugged in , volume icon is turned all the way, mute is off, adjusted speaker levels, etc on my desktop.
Firstly,
You need to check if the green cable from the computer tower is blugged into the back of the monitor (The cable looks the same at both the ends) this is for the output to come through the monitor.
If that is plugged in and if not working, Try a headphone on the tower and check if the sound is coming from the headphone, If yes, You will have to adjust the volume on the monitor or the speaker of the monitor might have gone bad. If there is no sound coming in, Then the problem is with the tower and not the monitor.
Dec 02, 2010 | Acer X193W LCD Monitor
My hp tower has a built in speaker how do I turn it off. I just want to hear sound from my speaks not the built in speaker
You have 2 options.
The easy one is: double click on the audio device at the task manager in order to open the audio mixer, try to locate the (internal) speaker slider and slide it all the way down. If the speaker slider is not viewable choose option and try to locate it at the new window in order to enable it and come viewable and then change it's volume. If the above method prove not to work you have to follow the hard way.
Open up the case. Locate near the front side of the tower the built in speaker. It has one pair of cables that are connected with a small plastic connector at the motherboard. Unplug the connector; maybe there is a clip in order to unlock the connector, use a small screwdriver with care not do make any damage at the motherboard. Close the tower and enjoy the sound from your speakers without the interference of the internal speaker.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Sep 04, 2010 | HP Compaq Business Desktop d330 Slim Tower
Hi, I have a pair of Polk RT1000i powered towers and one now makes a constant loud humming or buzzing sound. It is not hooked up to the receiver. It does it as soon as its pluged into the wall. Any...
the volume on the speakers are too high. try to put make the speakers the master volume(whatever device you plug in into your speakers make that device's volume go all the way up and then adjust the volume on the speakers to what ever volume you desire.had the same problem with my computer speakers
Jan 16, 2010 | Polk Audio RT1000I Speaker
My Emachine is only 2-3 yr's old now & I have never had sound. It was the cheapest one & on sale. I must have chose one that did not have a sound board. I can not put in a sound board by myself...
Are you sure there is no onbaord sound it should look like microphone or headphone socket holes. If it does then you are needing the correct driver. Open the tower and check what motherboard you ahve then post again for the correct driver.
If there is no sound onboard then it is very simple to install a pci soundcard anf they are very cheap. I certainly wouldn't go buying a new tower for just sound. Google on installing a pci card and you will see how easy it actually is or ask a young friend they know heaps about computers.
Oct 05, 2009 | E-Machines eMachines Desktop PC
Have external gateway speakers
First make sure your sound cards are working properly. 1) Check the master volume of your PC. Go to start menu, control panel, sounds speech and audio devices, sounds and audio devices - i) In volume tab click the speaker volume and check whether all the left, right, etc.. volumes are in medium or high. ii) In audio tab click the volume tab of sound playback and make sure that the master volume is not in mute and all the volumes are either in medium level or at 100%. After making these changes try playing any music. Even if the problem persists go and get your sound card checked in an authorised service centre.
Thanks & Regards,
Shiva
Sep 11, 2009 | HP (ZD929AA) Computer Speakers
Volume
oh i see the first question was way to vauge to really answer. it sounds that this is a powered speaker meaning it requires that 12v that you are reading and wont work without it. i am assuming that the cord coming from the speaker is a male end that plugs into female if that is the case it will be difficult to find an adapter to plug into the wall as those have male ends as well. if there is a female plug on the speaker you should be able to find an adapter that plugs into the wall outlet(transformer) just be sure to match up all specs i.e. 12v 1.0a
Nov 19, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
David Payne
David Payne
