Question about Microsoft Windows 95 NT 4.0 Workstation
PC PROBLEM IM HAVING PROBLEM IN INTERNET CONNECTION MY PC IS HAVING WINDOW 98 ON CLICKING IN-EXPLORER ON TASK BAR I SEE DLL PROBLEMM
Try disabling script debugging,for this you need to go to tools,internet options,on the advanced tab,you find browsing section, select disable script debugging and check it up click ok and restart the pc,if it doesn't work this way upgrade your explorer to internet explorer version 6
Posted on Aug 27, 2007
    Problem Solver:
  • 7 Answers
Reinstall the explorer and try internet explorer 7.
SOURCE:
Correction on the previous question. I have lost internet explorer, can any tell me how to get it back. Thanks.
if this is windows 7 go to start menu and type in the search bar "internet explorer" without quotes. once you find it right click on it and pin to task bar.
Sep 27, 2013 | Computers & Internet
Tip
Cannot Print from Internet Explorer
Issue: Cannot Print from Internet Explorer
Symptoms : When you attempt to print a document or look at it in print preview, you may receive the following error message:
Line: 539
Char: 2
Error: Invalid argument.
Code: 0 URL: res://C:WINDOWSSYSTEMSHDOCLC.DLL/preview.dlg
CAUSE : This issue can occur if the Iepeers.dll file is corrupted or is the incorrect version
Resolution: To resolve this issue, replace the Iepeers.dll file. To do this, follow these steps:
1. Restart the computer in MS-DOS mode or with a startup disk.
a. For Windows 98 and Windows 95 , click Start, click Shut Down, click Restart the computer in MS-DOS mode, and then click Yes.
b. For Windows Millennium Edition (Me), use a Windows Me startup disk and click Start Computer without CD-ROM Support.
For additional information about how to create a Windows Me startup disk, click the article number below to view the article in the Microsoft Knowledge Base:
267287 (http://support.microsoft.com/kb/267287/EN-US/) How to Create a Startup Disk in Windows Me
2. Type the following commands, pressing ENTER after each command:
c:
cdwindowssystem
ren IEPEERS.dll IEPEERS.old
exit
3. Extract a new copy of the Iepeers.dll file to the WindowsSystem folder. You can extract the Iepeers.dll file from the following location:
The IE_5.cab cabinet file included with Internet Explorer 5.5 for Windows 98.
4. Register the Iepeers.dll file. To do this, click Start, point to Run, and then type the following line:
regsvr32 IEPEERS.DLL
5. Click OK.
6. Restart your computer normally.
on May 30, 2008 | Microsoft Windows Vista Home Premium with...
Hidden Folder virus in PC not in USB
I have faced same problem. Shortcuts everywhere.
Not once, many times.
I tried many solutions.
Shortcut Virus Remover is the best solution I found.
A 100% free simple application.
You can download it from this link - Shortcut Virus Remover
Place it in your pen drive and double click to run.
Press Enter to confirm its process.
That is all.
Shortcuts will remove and your data will be back in a second.
Jul 20, 2013 | Microsoft Security Essentials
Script error 1791 ieframe.dll
- Manage add-ons in Browser WebRepOverall ratingThis site has no rating(not enough votes)
- Remove third party tool-bars and extensions
- Disable Protected Mode
a) Click the Tools icon in Internet Explorer
b) Go to Advanced tab and select the Security section and uncheck the checkbox beside Enable Enhanced Protected Mode (requires restarting Internet Explorer)
c) Click on Apply, and then click OK.
d) Close all open Internet Explorer windows, and then restart Internet Explorer.
Hope problem is fixed.
If problem still occurs then scan PC with a best registry cleaner like Intel Software Partner Reginout.
Dec 03, 2012 | HP Computers & Internet
Task bar start button keeps disappearing from dell computer running windows 98
mcdevito75 here You can try to left click anywhere it"s empty within the task bar itself, and check the lock task bar. Hope this helped.
Jul 14, 2010 | Microsoft Windows 98 for PC
I can not start Internet explorer. I click on the icon and it does not start.
Hey,
1. try to open the windows explorer and in the address bar type the address of any website.
2. right click on the task bar and then choose the option task manager, select the tak processes and then check for instances of the application iexplore. In casse there are multiple, select one and click on end process. repeat the same for all instances
3. In case still inaccessiable, try to restart the computer.
4. If the issue still persists, try uninstalling the application using the control pannel and add remove programs, Add remove windows components.
If the problem still persists, use a different browser
Jul 12, 2010 | Microsoft Internet Explorer 8
Internet explorer task bar missing
Try pressing the left Alt key alone. Does the menu bar appear?
Try right-clicking the area where the menu bar is supposed to be. Try different spots around the upper part of the window, eventually you should see in the context menu an option to turn on the menu bar.
Jul 09, 2010 | Dell Dimension 8400 PC Desktop
M3plugin.dll
Error loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll The specified module could not be found.
pentium iii windows XP
the specified module could not be found m3plugin.dll it appears on startup on windows xp and i want to fix it
Jul 28, 2008 | Intel Motherboard
Can't show task bar in window 98
you could try fixing it through registry
note: before thinkering with the registry make sure to backup your important file a do a full backup of your system registry.
click on Start>Run
and type:
regedit
when registry editor appeared...right click on My Computer(on the right panel)and choose export(this will save a backup copy of your registry) and save it...
now..look for the fallowing registry key and delete it:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\StuckRects
When you restart Windows, the taskbar is automatically recreated.
hope this helps...
^_^
Jul 24, 2008 | Microsoft Windows 98 for PC
Can not run Unicode version of ATL.DLL on Windows 95.
hi,
http://www.fix-all-dll-errors.com/msoeres.dll/
u can go to this site...this will help in case of missing or for downloading dll's or also if there is errors in dll's..!
I also registered few dll's from this site...worked in my case :)
Apr 15, 2008 | Microsoft Office Outlook 2003 for PC
Open Questions:
AOL MAil TelePHoNe %,/%+{1=855=536=5666}#[email protected]@# NuMbER IOWA This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Oct 21, 2019 | AOL Computers & Internet
See all Microsoft Windows 95 NT 4.0 Workstation Questions
Computers & Internet Logo
79 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
