Question about Car Audio & Video
Seaworthy marine stereo
I have a Seaworthy Marine Audio System (SEA MBB 126) and the buttons (rubber) don't work. You can't change the station or mode. Thoughts?
2 Suggested Answers
  • 78 Answers
SOURCE: have current, says AM 12:00, will not do anything else.
make sure both constant and switched power leads are getting at least 12v+, usually red and yellow.
Posted on Jul 08, 2009
Can't get FM to work on my Seaworthy 2300 Marine radio. CD works fine.
is the unit new? do you know how your FM antenna is wired. are you trying to pickup signal 50 miles offshore? Do you get AM?
Aug 26, 2016 | Car Audio & Video
1995 reverse gear don't work.
Never give up on a ****** until you've tried the `sea-foam' TRANSMISSION treatment in it. IF FLUID LEVEL is okay, and LINKAGE is hooked up correctly, One can of sea-foam is okay,for smaller trannies.IF the sea-foam fixes it,you might wanna change the fluid and filter. don-ohio
Sep 05, 2011 | 1995 Honda Accord
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
My JBL Marine Hot tub Sterio quit working suddenly?
JBL is at best a low quality marine grade brand of stereo. It is now garbage. I have worked on hot tub stereos for many years, PolyPlannar is the only one that is any good. If it was bought 30 days ago, where's your warranty?
May 31, 2010 | JBL Am/Fm/Cd 180 Watt Marine Audio System
I live in Australia and my seaworthy sea2300 only picks up AM stations by 5s eg. 1000, 1005, 1010 etc but the stations here are 1116 1278 etc
generic solution to all moving mechanical parts with grease dried up / solidefied grease, need to be clean and apply little grease (lubricants)
Mar 25, 2010 | Car Audio & Video
Matching wires from Seaworthy Marine Radio to Clarion M109
yes you dont need the orange but the yellow in the main power red is the iginition.
Jul 23, 2009 | Car Audio & Video
SEA2300 +ESP - cd disc stuck in player
disconnect the power and open the side where the cd motor is and remove manually
Jun 20, 2009 | Sea Worthy 9001G Marine Casseiver...
Have current, says AM 12:00, will not do anything else.
May 03, 2009 | Car Audio & Video
Clarion RAB250D w\casset need to set clock and stations.
While pressing the BAND button, press the DISP button for 2 seconds or MORE to enter the clock editing mode.
To move between the hour and nimute fields, use the left (hour) and right (minute) buttons.
To store the clock setting, press the BAND button.
Also to change between manual tuning and seek tuning press and hold the BAND button for 2 seconds of more. "SRCH" will appear in lower side of display when in search mode.
To preset a station manually press the BAND button to select the band at which to store the station (AM, FM1, FM2, FM3).
Tune to the desired station to be preset
Press and hold the corresponding preset button (1-6) for at least 2 seconds to store the station into memory.
Apr 26, 2009 | Clarion RAB250D
Car Audio & Video Logo
75 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
