Question about Cell Phones
Samsung aqua jet washer will not power on - Cell Phones
    Top Expert:
  • 12,223 Answers
Please see this steps and fix it. God bless you
Drained/dead battery
Plug your iPhone into your computer or wall adapter to charge. If it does not charge when connected to either of these, you probably have a dead battery. The battery will need to be replaced with a new one.
Bad display
It is possible that it appears nothing is happening because the display is bad. If the iPhone sounds like it is working properly but nothing is visible, it is possible the display is bad and must be replaced. Unfortunately, the LCD and glass panel are fused together, and must be replaced as one unit.
Bad logic board
If nothing else works, your logic board is probably bad and needs to be replaced.
Posted on Jul 12, 2013
Will not spin or anything can hear a humming noise like it wants to but nothing. Brand new
brand new out of the box new-- get a technician to do a warranty service call because if you try to fix it ,it may void the warranty.
May 07, 2015 | Samsung 5.0cu ft Extra Large Top-Load...
Errpr code 4e on samsun aqua jet vrt
A 4E code on Samsung washers means that the washer isn't filling properly or the sensor isn't detecting the water flow. First, make sure that the water shut-off valves are open. Next make sure that the drain hose outlet is positioned above the fill level of the washer. (This avoids the water being suctioned out of the tub.)
Turn off the shut-off valves and disconnect the fill hoses from the washer and the valves. Clean the filters in the washer and at the valves. Reconnect the hoses to the valve and place a bucket under the other end. Open the valves and check that you have good water flow from both hoses. You may want to replace the hoses. (Some washer fill hoses are designed to clamp shut if they detect a leak. This anti-burst feature will reduce the water flow to a trickle. Since the washer fill sensor detects the amount of water in the tub within 8 minutes, that will trip the error.)
If the washer isn't filling and there is plenty of water coming from the water line, the fill valve probably failed in the closed position. If the water level is rising, then the sensor is probably faulty.
Please add a comment with the full model number of your washer. Then I may be able to point you to the parts. If the washer is under warranty, contact Samsung.
I hope this helps.
May 01, 2015 | Washing Machines
Which side is the motor on of an aqua sense tub made by aqua glass that jets the water
when approacing a spa for the first time i allways use my ear to listen for the loudest noise area when spa is running before i remove skirting , then its usually self evedent that mfg has added a access panel that was previously hid from normal view
Sep 25, 2014 | Pool & Spa
Power supply will not turn on
make sure outlet has power if so check for fuses if no fuses need new power pack
May 25, 2014 | Aqua Products Aquabot Turbo T-jet By
What does dc Flashing on my Samsung aqua jet dryer mean?
A "dc" error occurs when a Samsung washer is unable to spin due to an unbalanced load. Redistributing the items inside the washer and pressing the "Start/Pause" button typically clears this error
Nov 11, 2012 | Washing Machines
Looking for a replacement hose end washer for the aqua cannon.
Local hardware store had an acceptable replacement part. Thanks
Oct 12, 2009 | Aqua Cannon Adjustable Power Sprayer
Aqua glass whirlpool tub leaks. looking for closure caps to close off the jets for good.
To my knowledge there are no closure caps for your tub; you can however purchase new jets with new seals if the tub is leaking through the jets.
Aug 29, 2009 | Home
Where can I purchase a replacement soap bottle?
Contact:
Roberta's, Inc.
24 W. Franklin Street
Shelbyville, IN
46176
(800) 428-9726
(317) 398-4453
http://www.robertasinc.com
May 24, 2009 | Aqua Cannon Adjustable Power Sprayer
Cell Phones Logo
42 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
