I seem to be having a problem with my samsung galaxy express. i have had it for a week or two and the wifi worked fine but just today everytime i try to connect it says "connecting" for about 30 seconds and then says "saved, secured" and doesnt actually connect. i have tried everything but nothing seems to work! any suggestions?
    Top Expert:
  • 12,223 Answers
Disconnect the power cord from your outlet box, and wait for 45 seconds. and connect again. use small pencil eraser and make click to the small switch in the router for complete reset. and try again.
However if the problem persist run the utility in network for diagnostic and repair.
you can restore by going to control panel and use the utility system restore put the last days that you know was working good and ready.
You must be sure that internet supplier is working good. You mus reset the MODEM with your broadband in case if the problem persist use the disk coming with the MODEN.
God bless you
Posted on Jul 12, 2013
3 Suggested Answers
im4um2
  • 77 Answers
SOURCE: My wireless is connected, actually has an excellent signal, but i cannot browse any webpage
Ok let's try something for you. Going into your internet settings and clicking on tcp/ip properties, go ahead and write down the ip address assigned to you from your service provider. Once you have done that let's connect the modem into the port labeled WAN and then connect the computer to one of the other ports labeled 1-4. Now in an open internet explorer type 192.168.0.1 or 192.168.1.1 one of these will open a window asking for username and password. Both should be admin. Once we are in the web based settings of your router you need to check the status of your router. On that page you should see the same ip address that you wrote down. If not go ahead and release and renew and see if you finally get the ip address to be the same. Once that is established you can check your ip address on your computer by going to the internet options and checking it. It should be somewhere between 192.168.1.2 through 192.168.1.256 (those number depend on the parameters of your router i.e. how many wireless devices are able to connect to your computer.) Silly question but do you have a wireless adapter on the computer that you are trying to connect? Laptops (new) usually have them built in and they must be turned on. Desktops require installation of a wireless adapter. Router's are basically looked at by your service provider as a computer behind your modem, they assign an IP address to your modem, whether you connect a computer or a router to your modem your service don't see the difference, it still assigns. Once the router receives the ip address from your service provider, it then has the duty of assigning IP addresses to all of the devices you wish to connect to the internet and each other.
Hope this helps
Good Luck
Posted on Jul 07, 2008
  • 186 Answers
SOURCE: I'm trying to just connect
on the initial setup and installation of the router you had to enter a password whatever the password is that you entered for the wireless account its the same password.
Posted on Feb 01, 2011
On my galaxy s 5 phone it started today dropping the WiFi signal every 2-4 seconds and I can't do anything that is done through the WiFi
You should test the connection with another phone, tablet or wireless computer, to exclude the router. If the other device also suffers from the connection, you know it must be the router. Only when you 100% certain (Don't make assumptions, always test) it is not the router, you could start with the phone, like to reset it or setup the complete connection again.
B.t.w. when your phone does connect to another router and works fine, agin that would be prove your router needs all the attention.
Feb 06, 2015 | Samsung Galaxy S
Why does my Samsung S3 galaxy tab keeps disconnecting from wifi?
I encountered the same problem when streamed something through wifi. The solution was in wifi (on the transmitter side) settings. Having no idea what wifi point you're using have no suggestions
Sep 02, 2014 | Cell Phones
Wifi can not turn on
Can you return it to the place of purchase.
Sep 02, 2014 | Samsung Galaxy Note 3 lll SM-N900 Factory...
Internet connection not working
could be your router, need to call company who you have internet with
May 14, 2014 | SumacLife Green Moisture Resistant...
Galaxy problems
my phone keeps on hanging everytime I try opening any applications, how can I fix this?
Jan 02, 2014 | Samsung S5830l Galaxy Ace Black Unlocked...
I have a Samsung Galaxy 2 and it was connected to WiFi for the last 8 months and was working fine. Now it's not connected and when I try to turn WiFi on it says connecting to WiFi but doesn't connect and...
you can try to restore default settings in the system options and see if that works, try to back up any work or games you have installed onto the pad as a system restore will delete them. best regards
Oct 30, 2013 | Samsung Tablets & eReaders
I have a galaxy s3 and everytime I try going on to my wifi it says authentication error can any one help
It's probably because the password has been entered incorrectly.
In Wifi settings -> long click on the WiFi name, then click "Modify Network config", then enter the password again.
If that doesn't work, then check all the WiFi settings in that "Modify Network config" list of settings.
Sep 21, 2013 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
Cannot connect to internet via wifi
try to turn airplane mode on and off and try it again or change the date on your phone to the current one
Apr 19, 2017 | Samsung Galaxy Prevail
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
