Question about Bodum Bistro K11179 Electric Hand Blender, Blender Stick and Accessories
Bodum drive coupling
The nylon drive coupling connecting the motor to the drive shaft has shattered. Does anyone know where replacement parts can be purchased? I'm located in the UK. Thanks in advance.
  • ashcroftr
    ashcroftr Jul 12, 2013
    I've already tried the manufacturer and also Amazon etc but to no prevail
Blender teeth shattered
Coupling teeth??? Replace coupling, if the teeth on the blade part of the coupling are also damaged then you will need to replace the blade assy as well as that coupling only comes with the blades.
Feb 06, 2014 | KitchenAid Blenders
Replacement end coupling
Possibly an appliance parts supplier can help.
Nov 27, 2013 | Waring WSB40 Blender
Replacing rubber drive coupling
My coupler was split in two, and I couldn't screw it off. I had to do the following:
1. Take the blender apart (mine had 2 screws on the bottom). 2. Remove the motor housing from the blender (mine was loose from removing the two screws earlier). 3. Remove the fan by removing the fan nut. 4. Take apart the motor housing. Mine had two machine screws with 1/4" hex heads holding a bracket that tied the two ends together. Once those two screws are removed, you can take the motor out of the housing. Be careful on the fan end of the motor, because it's got two spring loaded brushes that will come together once the motor is pulled through. 6. Once you have the motor out of the housing, you'll have something to grab onto so you'll be able to unscrew the broken coupler. I used a pair of channel locks and gently grasped the motor body, and then just used a regular pair of pliers to grab the broken coupler. It's regular thread (lefty lucy righty tighty), so twist accordingly.
Once you have the coupler off, just put everything back together. The hardest part is holding apart the spring loaded brushes while you push the fan end of the motor shaft back through the motor housing.
Took me about 20 minutes to do everything.
Good luck.
Nov 20, 2008 | Oster 4093-8 Osterizer Classic Blender...
Oster 6700 Blender
The only thing I can think of is to try to repair the separated rubber with one of the special adhesives.
This may not be physically, ie, damaged beyond repair, but if you think it might be repairable try something like JB Weld. They make an adhesive that sets up in 4 minutes. I have fixed some weird breaks with this stuff.
Hope this might help Good Luck Loring
Oct 25, 2008 | Oster 6700 Work Top Blender
Bamix hand blender 2 speed
I found this rubber drive coupling on mendshed which were helpfull enough to place it on their ebay site for shipping outside of the US. Check if it looks like yours first. One end the tapered end screws into the drive shaft the other end just fits in the rectangular shaft of the motor.
Sep 08, 2008 | Bamix Blenders
Philips Hand blender
My wife picked ours up at a rummage sale, and we've grown to love the little thing for making single servings of banana milk shake. (half a frozen banana, cover with milk, a drop of vanilla, and about one minute with the hand blender blade!) When my youngest boys dropped ours, I gathered up the pieces of plastic that connect the attachments to the motor shaft, and carefully super glued them together. I then wrapped the plastic piece with fine nylon thread and a thin layer of super glue and placed it back onto the motor shaft, then let it sit for 24 hours. It is now permanently attached to the motor shaft and good to go. Too bad Philips doesn't care enough to support their customers with a part their engineers designed to break and save the rest of the product. I'll remember this about Philips products when I buy an HDTV.
Aug 14, 2008 | Philips HR1358 Handheld Blender
The blender coupling on my oster snapped in half. I have the replacement part already I just cannot figure out how to get the broken coupling off the base of the motor. I also got a replacement square...
10-01-2009 Sara - see solution for rlaymon 1-9-08 "Top part of base broke off" by TanyaCS on 1-20-08 - good ideas. I just fixed mine - 2 hour job + half hour to put a new cord in. Like TanyaCS my broken coupling was rusted to shaft - used WD-40 twice and let sit - meanwhile took out motor and removed fan - kept screws and washers in order on workbench (kitchen counter) - the fan hole is "D" shaped - fan end of shaft also "D" shaped - I filed a "flat" on the other side of the factory "flat" (side of 'D' that is straight) - Used big pliers on broken coupling and adjustable wrench on on the "flats" on fan end of the shaft. Broken end came right off. New cord is 18 gauge extension cord capable of at least 6 amps. Cut off the un-needed end. Or order a replacement cord $4 when you order the rubber drive coupling $4, pin with slinger washer $3. Bet you also need new rubber feet - didn't buy for mine - wish I had. Bert
Jul 11, 2008 | Oster 465 Work Top Blender
The magnet for the speed sensor in my kitchanaid blender
what I can do for you is you should refer to your manufacturer/ store owner of your device for safer procedures.ok?
Jan 22, 2008 | Braun MR 290 MultiQuick Handheld Blender
Blender-motor side 6-lug interface with pitcher shattered. Replacement part avail?
Is the shattered part able to be "recreated" with a bit of superglue or similar? not to use as such, but just so you could take it to any reasonably competent machine shop and get them to copy it in a similar material. Try http://www.tritronicsinc.com/aca.html and they may be able to help with a relatively common replacement part such as this. Another route to go is to try and find a similar model that isn't working and cannibalise - any local domestic electrical repair shop might be worth a try, or internet exchange forums. Good luck
Feb 12, 2007 | Betty Crocker BCF1357 Work Top Blender
Bodum Bistro K11179 Electric Hand Blender, Blender Stick and Accessories Logo
Top Bodum Blenders Experts
eyecam
Are you a Bodum Blender Expert? Answer questions, earn points and help others
