Question about Thermo Scientific Genesys 10S Visible Spectrophotometer USB; Singl
Value outside photometric range (message on screen)
How do I retire a Signal out of Range error message?
Go into HP screen menu and turn off the display notification
May 04, 2014 | Lenovo Computers & Internet
Initial value contains and invalid value & the standard value is set (Entry = Double side) (Code S310011)
Hello Peggy,
This error message is Twain Driver error. The cause is that a value outside the range or an invalid character was found among the items in the initial value data file. (Item XXXXX indicated by Entry=XXXXX)
If the file was intentionally changed, the value set for that item may be incorrect. If the file was not intentionally changed, the file may be corrupt. The value has been set to the standard value. The file must be written again, for assistance, please see "Initial Value File" in the "Operator's Guide".
A hard disk check (chkdsk or scandisk) and virus check must be performed regularly.
Hope this helps.
Thanks & regards,
ScanCare
Jan 22, 2014 | Fujitsu Fi-6140 High Performance Color...
How to find domain and range of a function?
The calculator cannot determine that for you. But if you enter a value outside the domain it will display an error message
Let there be a function y=f(x).
The domain of the function is the set of values that x is allowed to take. For example, the domain of the f(x)=x^2 is the whole of the real line: any real value you might think of has a square.
The range of a function is the set of all values that the function can take. For f(x)=x^2 the range is [0, infinity[
Oct 16, 2013 | Texas Instruments TI-84 Plus Silver...
Error code
DS00001 error is a TWAIN driver error which explains the input value is set outside the range.
Cause:A value exceeding the range allowed for an input item was input.
Resolution: Input a value within the allowed range. Refer to the input item or the image scanner specification for the range.
Hope the above information is helpful.
Thanks & regrads,
ScanCare
Aug 12, 2013 | Fujitsu fi-6130 Flatbed Scanner
How to adjust headlights, 05 ford 500
Headlamp Adjustment
Headlamp Aiming
  1. The headlamp aiming procedure depends on what type of beam pattern the headlamp is equipped with. Vehicles may come equipped with visual optical left (VOL), visual optical right (VOR) or SAE only (includes sealed beam type) headlamps. To identify the headlamp beam pattern, look on the headlamp lens. Molded in small letters on the headlamp lens is 1 of the following:
    • SAE
    • VOL and SAE
    • VOR and SAE
  1. Once the headlamp beam pattern is identified, aim the headlamps using 1 of the following methods as applicable.
    • Photometric aimers can aim VOL-, VOR- and SAE-type headlamps only. This is the preferred method of headlamp aiming.
    • Visual or screen method aiming can be used to aim VOL-, VOR- and SAE-type headlamps only.
    • Mechanical aimers cannot be used with VOR- or VOL-type headlamps. Aerodynamic lamps that can be aimed mechanically have 3 nibs molded into the lens of the lamp.
    • Photometric Aiming
      1. For the photometric aiming procedure, refer to the appropriate photometric headlamp aimer instruction manual.
      Screen Method Aiming
      All headlamp types NOTE: Horizontal aim is not necessary for VOL or VOR headlamps.
      NOTE: Consult your state vehicle inspection manual for recommended tolerance ranges for visual aiming.
      NOTE: The sight shield may need to be positioned or removed for access to the adjusters.
      1. Before starting headlamp adjustment:
        • check the tire inflation.
        • check that no other load is in the vehicle other than a half tank of fuel.
        • check that the headlamps are clean.
        • check for correct headlamp operation.
        • check that the vehicle is on level ground.
        • if the vehicle is equipped with air suspension, make sure that the switch is on.
      1. NOTE: The vertical wall or screen must be a minimum of 2.4-m (8-ft) wide.
        Park the vehicle on a level surface approximately 7.6-m (25-ft) from the vertical wall or screen directly in front of it.
      1. NOTE: The center of the lamp is marked either on the lens (circle, crosshair or other mark) or on the bulb shield internal to the lamp (crosshair or other mark).
        Mark a horizontal reference line on the vertical wall or screen.
        1. Measure the center of the headlamp height to ground and record the measurement.
        1. Make a 2.4-meter (8-ft) horizontal mark (using masking tape) on the vertical wall or screen at the same distance from the ground as previously recorded.
      1. NOTE: This procedure should be done in a dark environment to effectively see the headlamp beam pattern.
        Turn on the low beam headlamps to illuminate the wall or screen and open the hood.
      1. NOTE: For SAE-type headlamps, the appearance of the beam pattern may vary between vehicles.
        On the wall or screen, locate the high intensity area of the beam pattern. Place the top edge of the high intensity zone even with the horizontal reference line.
      2. SAE-type headlamps
        1. In addition to the horizontal line marked in Step 3, a pair of vertical lines must be marked at the center line of the headlamps on the wall or screen.
          1. Mark the center line of the vehicle on the wall or screen.
          1. Measure from the center of the headlamp to the center line of the vehicle.
          1. Make two 1.5-meter (5-ft) vertical marks (using masking tape) on the wall or screen at the same distance from the vehicle center line as previously recorded.
        1. On the wall or screen, locate the high intensity area of the beam pattern. Place the left edge of the high intensity zone even with the vertical line corresponding to the headlamp being adjusted.
How To Aim Headlights EricTheCarGuy
Jan 15, 2011 | 2005 Ford Five Hundred
Ive been doing inverse sine, inverse cosine, and inverse tangent problems for a few hours now but all of a sudden when i put in this one problem it gives me: ERR:DOMAIN. im not sure what is wrong... I've...
Since you are familiar with sines, cosines, you know that their ranges (interval of values) varies from -1 to 1. The inverse functions of sine and cosine tkae their values in that very domain, [-1,1].
However you fed the arc sine function (sin^-1) a vlaue of (25/20.48) and that value is obviously larger outside the [-1,1] domain, hence the DOMAIN error message.
No such domain limitations exist for arc tangent (tan^-1) because the range of the tangent function spans the open interval ]negative infinity to positive infinity[.
Nov 02, 2010 | Texas Instruments TI-84 Plus Silver...
I have a 2000 ford mustang can you adjust the headlights and how do you do it
SECTION 417-01: Exterior Lighting 2000 Mustang Workshop Manual GENERAL PROCEDURES Procedure revision date: 12/09/2002 Headlamp Adjustment Headlamp Aiming
  1. The headlamp aiming procedure depends on the type of beam pattern the headlamp is equipped with. Vehicles may come equipped with visual optical right (VOR), visual optical left (VOL), or SAE only (includes sealed beam type) headlamps. To identify the headlamp beam pattern, look on the headlamp lens. Molded in small letters on the headlamp lens is one of the following:
    • SAE
    • VOR or SAE
    • VOL or SAE
  1. Once the headlamp beam pattern is identified, aim the headlamps using one of the following methods as applicable.
    • Photometric aimers can aim SAE, VOR and VOL type headlamps. This is the preferred method of headlamp aiming.
    • Visual or screen method aiming can be used to aim SAE, VOR and VOL type headlamps.
    • Mechanical aimers can be used only with SAE type headlamps. Lamps that can be aimed mechanically will have three nibs molded into the lens of the lamp.
Photometric Aiming
All headlamp types
NOTE: Horizontal aim is not necessary for VOR or VOL headlamps.
    • Check the tire inflation.
    • Check that no other load is in the vehicle other than a half tank of fuel.
    • Check that the headlamps are clean.
    • Check for correct headlamp operation.
    • Check that the vehicle is on level ground.
    • If the vehicle is equipped with air suspension, make sure that the switch is on.
  1. NOTE: The vertical wall or screen must be a minimum of 2.4 meters (8 feet) wide.
    Park the vehicle on a level surface approximately 7.6 meters (25 feet) from the vertical wall or screen directly in front of it.
  1. NOTE: The center of the lamp is marked by a 3 mm (0.12 in) circle on the headlamp lens.
    1. Measure the center of the headlamp height to ground and record.
    1. Make a 2.4 meter (8 foot) horizontal mark (masking tape) on the vertical wall or screen at the same distance from the ground as previously recorded.
  1. NOTE: For SAE type headlamps, the appearance of the beam pattern may vary between vehicles.
VOR type headlamps
  1. NOTE: The appearance of the VOR beam pattern may vary between vehicles.
    Identify at the top edge of this high intensity area a distinct horizontal cutoff in the beam pattern. If the top edge of this cutoff is not even with the horizontal reference line, the headlamp beam will need to be adjusted.
VOL type headlamps
  1. For VOL type headlamps, there will be a distinct cutoff in the left portion of the beam pattern. The edge of this cutoff should be positioned 50.2 mm (2 in) below the horizontal reference line.
    1. Horizontal reference line.
    1. Top edge of the beam pattern.
    1. High intensity zone.
Mechanical Aiming
  1. For the mechanical aiming procedure, refer to the appropriate mechanical headlamp aimer instruction manual.
2010&c18=modelyear&c20=n304745&c35=wsm%2cheadlamp%20adjustment%2csyb%2c417-01%2cgeneral%20procedures&pid=wsm%2ctitle%20page%202000%20mustang%2csyb&pidt=1&oid=functiononclick%28%29%7bdosearch%28%29%3b%7d&oidt=2&ot=img&oi=27&s=1600x900&c=32&j=1.3&v=y&k=y&bw=1171&bh=582&ct=lan&hp=n&[aqe]
Apr 07, 2010 | 2000 Ford Mustang
Screen says "OUT OF RANGE H:27.8K V: 62.0
That's the monitor telling you it's getting a signal it can't handle. The H and V values are the horizontal and vertical frequencies that control the display. They change depending on your computer's video card settings. The monitor can be damaged if run at frequencies outside its safe range, and it displays the message you're seeing to protect itself.
Start your computer. When the manufacturer's splash screen (logo screen) comes on, press the F8 several times. This will get you to a startup options menu. Select "Start in VGA mode" from the list. Windows will start up then with settings every monitor can handle, and you'll be able to see again.
You might have a game or other graphics application that changes video settings to something the monitor can't handle. If this is the case, and those settings are required, you'll need to invest in a monitor with a greater settings range.
Feb 04, 2010 | Hyundai ImageQuest QV770 17 in.CRT...
Need to adjusted headlights how do you do it on a
there are little screws with hex head or torz head. one for lateral, one for up/down.
shine on garage door.
Headlamp Aiming
  1. The headlamp aiming procedure depends on what type of beam pattern the headlamp is equipped with. To identify the headlamp beam pattern, look on the headlamp lens. Molded in small letters on the headlamp lens is one of the following:
    • SAE
    • VOL
    • VOR
    • Photometric aimers can aim SAE, VOL and VOR type headlamps. This is the preferred method of headlamp aiming.
    • Visual or screen method aiming can be used to aim SAE, VOL and VOR type headlamps.
    • Mechanical aimers can only be used with SAE type headlamps. Lamps that can be aimed mechanically will have three nibs molded into the lens of the lamp.
Photometric Aiming
All headlamp types
    1. Make a 2.4 meters (8 feet) horizontal mark (masking tape) on the vertical wall or screen at the same distance from the ground as previously recorded.
VOR type headlamps
VOL type headlamps
Mechanical Aiming
Jan 18, 2010 | 2000 Mercury Grand Marquis
Unsupported video signal
It is possible that Jewelquest changes the screen resolution to one that is not supported by the TV. I am not familiar with Jewelquest, but the typical reason for the unsupported message is a resolution outside of the supported range. The supported resolutions should be listed in the owner's manual. Dan
Jun 12, 2009 | Toshiba REGZA 47HL167 TV
Thermo Scientific Genesys 10S Visible Spectrophotometer USB; Singl Logo
87 people viewed this question
Top Thermo Scientific Genesys Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Thermo Scientific Genesys Office Equipment and Supply Expert? Answer questions, earn points and help others
