Question about Rayovac Purple 7 1/2" Hanging Camping Flash Light Lamp Lantern
Can I buy this lantern from this website? And, where can I buy bulbs for it?
How do I get to the bulb?
Unscrew the head assembly. In the back of the assembly is a small plastic nut. Unscrew this and the bulb should fall out into your hand.
Nov 01, 2014 | Energizer Eveready Utility Lantern Uses 6V...
How do I change the bulb of the 6V Eveready Lantern if bulb won't come out
Drop a couple of drops of WD 40 on the bulb retaining ring. Let site overnight and in the morning it will easily unscrew. Note: be sure you use only a couple of drops as you don't want to get it on the reflective lense
Sep 27, 2014 | Energizer Eveready Utility Lantern Uses 6V...
How to test a flashlight bulb
To test a flashlight bulb you use an Ohm meter which will detect a broken filament or an open circuit within the bulb. If the bulb is bad it will read "OL" if it's good it will read "00.0"
Jun 14, 2014 | Energizer Eveready Utility Lantern Uses 6V...
Where can I buy mini-lantern candle holders. I think they would look really good at my wedding.
I saw some very cute lanterns on the New Favors website http://www.newfavors.com/index.php?l=product_detail&p=763. You can use different colored tea lights to add to the effect.
Feb 03, 2013 | Crafts & Hobbies
Rayovac 360 sportsman lantern wont work
Since batteries and bulbs are new/ok, check for a bad connection. In older version using 4 lantern batteries, open the battery compartment by unscrewing the knob on top of lantern. The lantern bottom comes off once unscrewed (of course you did this to change batteries). There is a "C" clip on the lantern center shaft; remove this by prying with screwdriver or with pliers. Carefully raise the battery contact plate and check slip-on wire connections. Clean as needed (Scotch-Brite works well) and reconnect. Squirt some contact cleaner in exposed switches, work switches back and forth. Inspect circuit board for obvious corrosion or damaged parts (this damage may "total" the lantern). Re-install plate aligning grooves with ribs. Install batteries and test.
Nov 01, 2012 | Camping, Backpacking & Hiking
How do I change the bulb of the 6V Eveready Lantern?
If it is the yellow floating lantern you have to remove the black plastic stub on the underside of the reflector using needlenose pliers to wiggle and slightly pull until it releases and the bulb will come out.
Jan 06, 2011 | Energizer Eveready Utility Lantern Uses 6V...
Cant figure out how to take apart to replace bulb
More information is required in order to answer your question. However, the following link will take you to the Coleman website for battery powered lanterns. www.coleman.com/coleman/parts/product_category2.asp?category_id=170
Jul 19, 2010 | Coleman Rugged Battery Powered Lantern...
Rayovac Purple 7 1/2" Hanging Camping Flash Light Lamp Lantern Logo
271 people viewed this question
Top Rayovac Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Rayovac Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
