Question about Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer
Dryer will not run
Display shows RE5 code
  • Official Brand Answer
  • 4,342 Answers
Hi Carolyn - Error code RES commonly refers to RESUME. Let's trying pressing the RESUME button or START on your dryer. If it proves ineffective, let's reprogram the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn the appliance back on. Once you select an option, the unit should resume to normal operations. However, if the issue persists then the dryer may possibly be experiencing a communication error with the control board or a potential wiring failure. In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the diagnosis of your appliance.
Posted on Jul 12, 2013
Error Code re5, dryer runs but no heat.
Good Afternoon Henry, thank you for your post!
I see that your Frigidaire dryer is displaying an error code of "re5" and will not heat. I have researched our available information for dryer and without having the model number the error code appears to be invalid. I would recommend performing a reset on your dryer and you can do that by unplugging the power cord for roughly ten minutes. If you restore power and continue to receive the error code can you please comment back with the model number? You can locate the serial tag (which lists your model number) on the door frame of your dryer. With that information I would be happy to assist you further. -Matt
Feb 22, 2016 | Frigidaire Dryers
How do i find out what the frigidaire gallery series dryer error messages are
Hello Friend, this is Z. I appreciate your post!
To get the error code your dryer may be experiencing, attempt the following:
Wake your dryer by pressing any button except for CANCEL.
Press and hold the "CANCEL" and "START PAUSE" buttons simultaneously for 6 seconds to show the error recorder code your dryer may have. The error code normally appears in the display as an E followed by two numbers.
If your dryer shoes, E00 it indicates no failure code was detected.
I ask that you please follow up with a comment on the post, at your convenience, to advise if you receive an error and if further troubleshooting is needed.
Thank you!
Jul 17, 2014 | Frigidaire Dryers
What does fault code 99 indicate?
What? 2days? Call the installer! or seller. Could be a gas supply safety problem!
Mar 24, 2012 | Maytag Neptune MDG6800 Gas Dryer
My kenmore dryer is not working it does not show any display of any codes it light ups but it does not run
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 20, 2011 | Dryers
Gas dryer will not start. Model MGDB850WR0 maytag bravo gas dryer serial MY3101043 purchased 2009. lights and display come on, push buttons give tones, but nothing happens when you push start. Display...
heatman101
Aug 08, 2011 | Maytag Dryers
I have a Samsung DV210AE Dryer that is 3 weeks old, everything works on the dryer except no heat and it is not showing any codes what do I need to do. Thanks!
The first thing to check is if you have 240 Volts going into the dryer. The display, lights, and motor run on 120 Volt but you need 240 V for the element.
May 20, 2011 | Samsung 7.3 Cu. Ft. Electric Dryer
Kemore he3 dryer error code E1
Hey fookie you need a thermistor for that dryer. It runs with no heat ?..Let me get a pic for you it is about 25 bucks oh and is part 42 on the pic below
Oct 23, 2008 | Dryers
Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer Logo
377 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
