Question about Craftsman Garden
Stall restart mower stalls out almost like it is out of gas but as soon as it stops running I can turn the key and it restarts and runs for a few more minutes then it does it again. already changed the oil, oil filter, fuel, fuel filter, and plug even changed the gas lines. any thoughts
  • Craftsman Master
  • 2,239 Answers
Many ride ons have a breather in the filler cap to stop a vacume in the fuel tank, try just slackening off the fuel filler cap and see if it runs ok, if it doed just replace the filler cap
Posted on Jul 12, 2013
buffalonyman
  • 1865 Answers
SOURCE: John Deere L118 / 22hp Briggs stalling when it is hot
Have you replaced the fuel filter?
Posted on Aug 08, 2009
SOURCE: Riding lawnmower wont run long
Check for dirt in gas tank some times stuff will fall in when filling and block the hole in bottom of gas tank and wont let gas flow clean everything out and see if it works. Also check that all kill switches are tight and not moving.
Posted on Oct 10, 2009
nova2nv
  • 197 Answers
SOURCE: Stalls after 20 mins. of running fine. (Starving for gas)
From the rear of machine look at the top left of fuel tank for the fuel line.Where line comes out of tank see if it is pinched where it goes down between frame and tank,grab line and see if it moves freely.If that is OK loosen fuel cap after 10 minutes of run time to see if your vent hole in cap is working.These are 2 common problems for the L series mowers.
Posted on May 22, 2010
  • 252 Answers
SOURCE: Craftsman lawn tractor, LT2000, 18
hi there
here is web site for manual and parts diagram
http://www.hammerwall.com/Download_Manual/12377/
have the valves been adjusted correctly ? or could have a tight valve clearance
and when gets warm holds valve open - looses power
your engine will be 31p777 intek ohv avs
run the piston to tdc on compression stroke , then turn piston past tdc & set piston is 1/4 inch down the bore on power stroke this eliminates decomprssor lift from the setting
intake should be 0.003 Thou
and exhaust 0.005t thou
then check the carburettor main jets and emulsion tube and pilot jets and air bleeds and progression ports for obstruction etc for restriction / blockage
check fuel flow from tank to carb , check that the fuel solenoid has got continual 12 volt supply
when switched on and does not go o/c cutting fuel supply to main jet
have a look let me know
cheers hope it helps
pauly 46
dont forget the thumbs rating
Posted on Jun 09, 2011
philwalker78
  • 605 Answers
SOURCE: I have a Husqvarna 48
Hi, when it plays up try loosening the fuel cap. It is vented and may be blocked. Also the fuel cutoff solenoid in the bottom of the carby is renouned for shutting off sporadically. You can test this theory by removing the small sealing rubber from the tip off the solenoid and replace the solenoid if it fixes the problem. Hope this helps, regards Phil.
Posted on Jul 21, 2011
Toro Proline 52" stalls out after warming up
Do you know if that unit has a fuel pump or not? If not, then engine vacuum is what draws the fuel in ... but only IF the hoses involved DON'T have any cracks or splits, and they fit TIGHT on the ports to which they connect! Try using an eye dropper and squirt a little gas in the air intake under the air cleaner. Does it fire then?
Apr 19, 2017 | Garden
Craftsman LT 1000 mower I am having problems with
I have a LT 1000. I drilled out the holes in the gas cap. If they plug, you will notice the gas tank gets sucked in from the vacuum.
Gary
Sep 20, 2011 | Craftsman Garden
My ride on runs well for about half an hour or less then starts to lose power then stall will restart and then stall again in a few minutes
Try loosening the gas cap just as it begins to lose power. If this clears the problem, clear the vent holes in the cap.
Gary
Feb 06, 2011 | Yard Machines Garden
Jeep liberty 2002 3.7when starting cold starts-stalls unitl hot
Check the temperature sensor feeding the ECU and O2 sensor.
Apr 12, 2010 | 2002 Jeep Liberty
Yard machine mtd 123cc mower stalls after starting it runs for a few seconds and then stalls. Previous to this it only ran on choke but when you took the chock off it stalled also. Now it stalls even when...
dirty gas. the fuel bowl likely has junk in it which plugs the jets as soon as it starts. you may get luck just emptying the carb bowl but a good carb clean and new gas will do the trick. (dump out the old gas
Aug 16, 2009 | Mtd 22" Yard Machine Push Mower
Lawn mowewr wont restart
Check the gas cap. Loosen it a bit and try again. There is a vent built into it the hole on top plugs up ans stops the fuel flow.
Eric
Jun 24, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
46 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
