Question about Hobart Dishwashers
Probe error BSTR - Hobart Dishwashers
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Oven keeps asking for probe
connect probe and insert probe
Jul 26, 2015 | Kitchen Ranges
Hobart model cl44e probe error??
i changed the circuit boar and am getting error codes
PROBE ERROR-WSH
PROBE ERROR -PW
PROBE ERROR-DR
PROBE ERROR-BSTR
SOME BODY CAN HELP ME TO RESOLVE THIS TROUBLE
Jan 26, 2013 | Hobart Dishwashers
Hobart LXI Dishwasher a P3 code is flashing, seems to be working alright. Thanks to any help
the p3error is an open or shorted booster thermistor.take off btm panel on the right side is the bstr, do when cold and no power to mach.,TURN OFF BREAKER, ON THE UPPER RGT CORNER OF BSTR YOU WILL SEE THE THERMISTOR.unplug from harness use7/16 wrench to unscrew from bstr. well,get new therm.and installyou can get @ any hobart office in your area, part#328994. dont forget to vote, thanks, monomoy
Mar 11, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
No heat on rinse cycle HOBART AM14C Dishwasher
3 Con, is the booster heat contactor. If it is chattering, the fault will be in the booster. There are a few different boosters in the AM14. can you post the ML number from the data plate, or describe if the booster is a square Hatco HCM-10, or a round stainless booster with a 13 kw multi wired element.. All boosters use a low water cut off circuit, a high limit thermostat and a control thermostat. The old Hatcobooster uses mechanicqal components, where the new rount tank uses probes and a control board. The board has 3 leds. red is calling for heat, yellow is open thermistor, and green is shorted thermistor.
AM14's had a variety of different control circuit voltages, ranging from 240/208/120 and 24 volt AC. Check the transformer secondary for correct output to controls, trace through circuit until voltage pulses. If new style, it could be just scaled up probes not reading water. Drain the tank with the power off before removing probes.
Jul 03, 2009 | Hobart AM14C-155 Dishwasher
HOBART AM15 DISH WASHER ERROR(E1)
After checking the service manual, I find no code for E1. There is a P1, or other E codes. Please list ML number.
Jun 14, 2009 | Hobart 29 in. AM15-1 Free-Standing...
Sr24h dishwasher will not heat water, we have 110 volts to contacts but they will not close in cycle to turn on heater?
if you have voltage to bstr. contactor coil and contactor is not pulling in the coil must be bad on the contactor. try pushing in thecont. manually to see it is not bound up mechcanically, if you can do that replace bstr cont. because the coil is open. dont forget to vote, monomoy
Apr 22, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwashers Logo
154 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
