Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Starter will "bump" but will not turn motor. - Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
    Scholar:
  • 61 Answers
Can you give us anything more? Such as have you tried jumping it with a known good battery? Has any voltage readings been taken? If so where? If you pull the plugs out will it turn over? We really need to know if any diagnosis at all has been done in order to attempt to help you out.
Posted on Jul 13, 2013
Can a car with a broken starter motor be jump started?
If it's the starter motor itself that's knackered it won't start with anything, other than a bump start. Jumping won't knacker the battery though, and if the starter is seized it just won't turn over. Hook it up and give it a go, it won't do any harm. Worst case only give it five or six turns. If it turns over' at all' it's going to be fine.
Apr 04, 2016 | Cars & Trucks
Why will it start only if I just bump the key?
What I understand from your posting is that if you use the key to start in the normal way, then it will not start, but if you turn the ignition on and 'bump start' the vehicle without using the starter motor, the vehicle starts. If this is correct, then the problem is that the starter motor is consuming all the power for itself and the resultant voltage drop means that the coil and ignition are left wanting for power. Thus you don't get a good enough spark when the starter is engaged. The causes could be a number of things:- a weak battery, dirty or incorrectly set spark plugs, bad ignition leads causing tracking, badly set points gap or dirty points. bad starter motor (worn brushes or 'leaking' coil windings).
Personally, I would start with getting the ignition system up to scratch, new points and plugs, then correctly adjust the ignition timing.
Rgs. Bob
Jan 10, 2016 | Cars & Trucks
Where is the starter relay on a 1994 Mazda?
a solenoid is usually attached to the starter motor
it a small cylinder on its side
if its not there then it will be mounted to the engine firewall and its square with three connections and a bump in the middle
on old cars you could press the bump and turn it over
Apr 19, 2015 | Cars & Trucks
98 honda crv wont start unless bump started, starter motor?
will it start with a boost? either the starter motor or the battery. take the battery to auto zone and they will test it for you.
May 24, 2010 | 1998 Honda CR-V
I have a 1998 f-150 4.2l v-6 tryed to start it today it turned over and did not catch. turned key to try again it bumped the starter but would not turn the engine over. I tryed jumping it but I knew I had...
When you say 'it bumped the starter but did not turn the engine over' and 'it bangs the starter' it sounds like you mean it hits the flywheel and will not turn the engine. If it engages and does not turn the motor you need to try to manually turn both directions. Do not have the key in the ignition. If it won't turn you may have a froze up motor.
If you mean the starter spins freely but won't engage the engine - than you need a new starter. Let us know what you find out.
Mar 06, 2010 | 1998 Ford F150 Regular Cab
Hey there, I have a P reg Audi A4 avant sport. The initial problem was that the ignition key did not spring back from cranking the starter motor, I believe this has caused my bigger problem which is that I...
It sounds like you have 2 problems.
The first is the ignition switch. Call or visit your Audi dealer and ask about a recall for your ignition switch. I believe it should be replaced under recall.
Next, it sounds like the starter solenoid is not engaging. The starter has probably been damaged due to the faulty switch.
The third, and I hope it is not the case, is that the teeth on the flywheel which engage the starter are damaged and missing.
Once the starter is removed it will be obvious if there is damage to the flywheel.
Good luck.
Dec 14, 2009 | 1998 Audi A4
Push starter botton and sometimes it bump the
Probably a dirty contact in the starter switch on the bars, strip down inspect and clean, replace if broken. Maybe a flat or discharched battery, charge or replace battery. Loose cable to the starter, check and tighten. Relay faulty, replace with new. Starter soleniod fauly, replace. Starter motor fault, remove, inspect and repair, replace if required.
Oct 02, 2009 | Harley Davidson FXSTS Springer Softail...
When ignition turned, just get a click. All other electrical works, radio, power windows, etc. I think it's probably the starter.
YOUR STARTER MOTOR HAS GONE MATE TRY BUMP STARTING IT BET IT GOES,TRY TAPPIN YOUR STARTER MOTOR WAE A HAMMER IF NO GOOD GO GET ONE FOR A FIVER AT A SCRAPPY.
Jun 01, 2009 | 1995 Toyota Camry
Kawasaki zzr600e wont start
If you are not getting the starter to wind after pressing the start switch check these probs.Have you checked the fuses for the ignition switch? Check all fuses. Track the wiring from switch and check all plugs and connections.  Turn ignition on and try clutch starting the bike to see if the motor will run once it is cranked over. If you need to bump it, make sure all your connections and wiring are all making good contact. You must conduct a process of ilimination in order to rectify the fault. good luck.
May 13, 2009 | 1996 kawasaki ZZR 600
Starter not work but can bump start nissan sunny "N" reg
Rock your car back and forth. The starter is stuck between teeth. I had a jeep that had the same problem. It had teeth missing on the starter motor. This seemed to do the trick
Oct 18, 2008 | 1995 Nissan 240SX
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
23 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
