Question about Cameras
Fujifilm finepix jx500 white screen
I have a white screen when i turn on my camera. It makes noises when i press the buttons but all i see is white. I've tried turning it off and on again. I've tried recharging the battery and still nothing. Please help!
SOURCE: fUJIFILM FinePix A360
my A360 digital wont turn on it flashes green then goes off i put new batteries in it
Posted on Sep 30, 2008
SOURCE: Camera turns off when I try to take a picture!
Try a Re-chargeable higher capacity battery, I hope the problem will not occur again
Raj Thapar
Posted on Oct 20, 2008
zohail
  • 1223 Answers
SOURCE: i have a fujifilm finepix S5000 when camera is
if u see white screen and lcd show info and signs and pictures also turn out to be blank when u see them on pc
CCD Failure has occured !
dont worry i have the same problem with my S5000 i contacted fuji and they repaired it free of charge bcoz it is a known problem in thousands of cameras of different brands just call them in ur area and they will do it free of charge
see this
http://www.imaging-resource.com/badccds.html
for support in usa or select different region www.fujifilm.com
http://www.fujifilmusa.com/support/ServiceSupportContact.do
Posted on Apr 09, 2009
  • 12 Answers
SOURCE: my camera wont turn on.
If the lens is stuck inside the camera and you hear a motor noise - changing batteries will not help. This has happened because the lens barrel is jammed inside the camera. Unfortunately, you will not be able to repair that issue. If the lens is stuck outside the camera, slightly tilted, and you hear a motor noise; you might be able to save camera. First, only use good batteries (stay away from alkaline batteries - waste of money), go with Energizer Lithium or Duracell Power Pix (you will get your moneys worth and have less problems with the camera). Second, very GENTLY, pull the lens barrel up and in the opposite direction of the tilt (to make the lens barrel straight), you will hear a slight click sound - DO NOT PUSH ON THE LENS BARREL!!!. Put in the new batteries and the lens should retract.
Posted on Oct 10, 2009
  • 11967 Answers
SOURCE: Hi, I dropped my fujifilm
Try these: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Sep 08, 2010
FUJIFILM FinePix JX500 digital camera says memory card protected
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 20, 2013 | Fujifilm FinePix JX500 14MP,5x Optical...
My finepix jx500 does not turn on unless its charging
Had the same problem, took the camera back to the shop. Was mortified when the assistant opened the battery slot, took the battery out, turned it round and put it back in again. And it worked. Make sure the battery isn't the wrong way round (only camera I've ever had where it was even POSSIBLE to put the battery in the wrong way round). Orange label on the battery needs to be next to the orange 'release lever' on the slot.
Nov 23, 2012 | Fujifilm FinePix JX500 14MP,5x Optical...
Can i take black and white pictures with a Fujifilm FinePix JV200 Digital Camera? If so please can you tell me how?
Yes. Press MENU/OK in shooting mode, highlight FINEPIX COLOR (looks like a film canister with leader coming out) and press selector-right. Highlight B for black-and-white and press MENU/OK.
Full instructions are in the "Using the Menus: Shooting Mode" section of the manual under "FinePix Color" (page 59 in my copy). If you need a manual, you can download one from
http://www.fujifilm.com/support/digital_cameras/manuals/#j
Jul 18, 2011 | FUJIFILM FinePix JV200 / JV205 Digital...
I can't change the white balance on my FujiFilm FinePix z70. How can I access this?
Press MENU/OK. Use cursor-up/down to select "WHITE BALANCE."
Be aware that you cannot manually set the white balance in some modes.
Dec 30, 2010 | FUJIFILM FinePix Z70 Z71 Digital Camera
FUJIFILM FINEPIX S5000.No image on viewfinder or LCD.
I think there is a small button on the back of the camera near the bottom that turns the viewfinder off and on I think. It should be in the manual.
It might have gotten bumped while in the bag.
May 24, 2010 | Fuji Cameras
Lcd screen
EBAY has lots of camera parts stores. Just search fujifilm s5600 lcd screen , or parts camera.
Aug 26, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
After taking photos on fujifilm finepix Z1 they
CCD FAilure
Call Fuji in ur region and they will do it FREE of Charge as it is known problem all are doing it free jsut call them
pls rate me WELL !
Jul 07, 2009 | Cameras
Have changed my camera to take black and white photos but need to take colour photos again - fujifilm finepix S5700
Turn the camera on. press "F" button to select F-MODE. Use menu button to scroll down to finepix color. Select STD (standard)
Jan 03, 2009 | Fuji FinePix S5700 Digital Camera
Change from black and white to color
There is a little blue button next to the LCD button, directly above the display screen. There are alot of controls when you press, like color, B&W, shutter speed, etc. Thanks
Sep 29, 2008 | Fuji FinePix S5000 Digital Camera
Cameras Logo
37 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
