Question about Cell Phones
My iPod 4g touch is stop working after dfu mode when IPod is on recovery mode I connect with pc no iPod found in iTunes and black screen I try to restore with holding power and home at same time but nothing's happen my iPod is dead now anyyyyyy help from dudes.
Have you try to press home and power button during 20 secs?
Posted on Jul 14, 2013
  • Aimal Khan Jul 15, 2013
    Yes but nothing's happens iPod not Turing on
sknerdish
  • 53 Answers
SOURCE: iphone is complete dead
get(4!!!!!!!!!!!!!!!!!!!!!!!!!!!!!) conecters
Posted on Feb 18, 2009
drsde
  • 36 Answers
SOURCE: I have a IPhone 3g
Find your solution from the list,
Apple Iphone Smartphone
Codes:
Software & Hardware Problems
Find Your Solutions for other Apple Products:
Apple Iphone 3G
Apple iPod Touch Digital Media Player
Posted on Aug 08, 2010
dasgt
  • 35 Answers
SOURCE: My iphone 2g does not respond to "touch at all" it
Codes:
Find Your Solutions for Apple Products:
Apple Iphone 3G
  • 11 Answers
SOURCE: I have in iPod Touch 3rd Gen with blackra1n
You will probably have to reset your whole iPod, which WILL delete everything.
Posted on Sep 08, 2010
tbirdfan1
  • 3051 Answers
SOURCE: I went to use my
hELLO THERE:
Many people think that it's a pressure problem, and the fact that the iPod is not picking up the pressure you apply when you touch the screen to perform a task. However, the screen on the iPod Touch is not pressure-activated but rather, heat-activated. This means that when you touch the iPod screen, the sensors inside the Touch pick up on the heat from your finger and follow it to wherever it goes. If it can't pick up the heat, it won't be able to do much for you. Luckily, because it's the heat sensor, the problem can sometimes be very easily corrected.
Oftentimes, this problem occurs when people are outside on a very warm day and are trying to use their iPod Touch. Because the surrounding air is just as warm, or hotter, than the temperature from the tip of the finger, the sensors can't differentiate and so, they don't respond when you touch the screen. So, just move to a cooler place and you should be able to operate your iPod Touch again. Some also suggest turning your iPod off and on and waiting a few minutes before trying again to see if it will work.
Unfortunately, if those solutions don't work for you, you might be out of luck and might just have a defective screen. If this happens, the only solution sadly is to return your iPod Touch to Apple and hopefully, you're still under warranty to get a new one.
Posted on Nov 13, 2010
How do I reactivate it.And I forgot my security code.
Place the iOS device in Recovery Mode and then connect to your computer and restore via iTunes. The iPod will be erased.
iOS: Wrong passcode results in red disabled screen
If recovery mode does not work try DFU mode.
Feb 15, 2015 | Apple iPod touch
I Pod Touch showing USB cable and an arrow for iTunes. I tried to Charge it or put it into DFU mode Hold the lock/power button for 15 seconds Then hold the lock/power button and the home button without...
sorry, that is the incorrect way to enter dfu mode. here is the correct way.
Step 1. Plug your ipod into your computer.
Step 2. Power off your ipod.
Step 3. hold the power button down for 3 seconds.
Step 4. while holding the power button, press and hold the home button for 10 seconds.
Step 5. While still holding the home button, release the power button AND CONTINUE HOLDING THE HOME BUTTON for 15 seconds.
your computer should recognize the device as in dfu mode, install the driver needed, and from then on, you should be able to restore.
Sources- i have had an ipod since the very first one, and i have extensive knowledge of jailbreaking and restoring troubles.
Sep 02, 2013 | Apple iPod Touch iTouch 16GB WiFi MP3...
How do i enable a disabled ipod that says disabled connect to iTunes
Connect to iTunes using usb to restore the device.
If this does not work you can try putting it into Recovery Mode and DFU Mode using these instructions.
Mar 05, 2011 | Apple iPod touch
Getting message error -40 cant connect to itunes on my ipod 2g a1288
1. First, Open up iTunes, plug in your iPod Touch/iPhone to the CPU's USB port. Turn on your CPU's speaker and make sure it is loud enough that you can hear it.
2. Hold down the Home button (top left for iPod Touch and top right for the iPhone with the screen facing you) and the Power button (located on the front bottom of your iPod Touch/iPhone) simutaneously, until the screen goes black and the device turns off. (past the red slider/slide to power off screen)
3. Now let go of the Power button, but continue to hold the Home button. Your iPod Touch/iPhone should have turned off and the screen should not be on.
4. After around ~10-20 seconds, you will hear a noise (beep/ding) from your CPU as if it had just recognized a new hardware device, now iTunes should recognize it in DFU mode.
5. After iTunes recognizes the iPod Touch/iPhone, let go of the Home button otherwise it will go into recovery mode and you will have to do the entire DFU process over again.
6. You will know when you have put your iPod Touch/iPhone correctly into DFU mode when the display is blank and that you do not have anything on your device.
7. Restore ipod using itunes
Feb 26, 2011 | Apple iPod touch Second Gen (8 GB,...
Ipod keep freezing with only the apple showing on screen...wont do anything else...says port is not found
1) Start iTunes.
2) Power the device on by holding the sleep/wake and home button for about 10 seconds. Release the sleep/wake button, but keep holding the home button.
3) If you did it correctly, the device will be showing either a connect to itunes screen (recovery mode) or a black screen (DFU mode) We are trying for DFU mode here, but recovery may work too. Connect the ipod to your computer. iTunes will tell you that it has detected an iPhone or iPod touch in recovery mode.
4) If you see the iTunes icon and cable on your iPhone, your device is not in DFU mode, but in recovery mode. Your device's screen will be black when you are in DFU mode. I always have to try this several times so succeed.
5) Connect your device back to your Pc/Mac and press SHIFT+CLICK (pc) or COMMAND+ CLICK on the restore button.
6) Select the firmware version you'd like to install from your computer. You can google for ipod touch firmare to download the file, or just let it update right from apple.
7) Wait for a couple of minutes and your iPhone/iPod will be as new.
Jan 07, 2011 | Apple iPod touch
My ipod touch is disabled because i tried my
put it into dfu and restore it. youll lose everything but youll still get on it. just google how to get into dfu i think its like hold power button 10 seconds home button with power button 3 seconds and home button for 30 seconds. then itunes should say that it found an ipod in restore mode or something.
Nov 30, 2009 | Apple iPod touch
My ipod touch is disabled and i cant hook it up to itunes cause it needs a code but its disabled and is stuck at the disabled screen.
you will need to put your touch into recovery mode aka DFU mode.
Here are the steps:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Iphone and itouch dfu mode
Plug the usb cable into the Ipod and NOT into the computer.
Hold the Home Button down for 5 second (do not release it)
Then Press and hold the Power Button for approx 10 secs (count them out)
Your iPod will reboot.
Release the power button and continue holding the Home button for an additional 27secs.
You may see the screen go blank or not.
Plug the USB end into the computer with itunes open.
Your ipod will mount in recovery mode.
Restore it and Your all set.
Jun 16, 2009 | Apple iPod touch
Unlock ipod touch
what you will need to do is put the touch in recovery mode aka DFU mode and restore it.
Download iTunes and install it.
Here is the procedure for DFU mode:
If this post helps you, please leave a vote in fixya
May 24, 2009 | Apple iPod touch
Stuck on black and white Apple logo screen
Solution 1) Press Hold/Sleep & hold buttons at same time for 20 seconds, This may fix you problem.
If problem is still alive follow solution 2
Solution 2) Press Hold/Sleep & hold buttons at same time for 10 sec. & then leave only Hold/Sleep button keep home button pressed & connect you ipod to PC, That means you have to bring your ipod in DFU mode (Recovery mode) Check out this video for getting ipod touch in DFU mode http://www.youtube.com/watch?v=bITIiGswjFI
. itune must be run on PC.
It will ask you for restore. Accept Restore you ipod touch request by itune. Wait for few minutes while ipod being restored.
This process will solve your problem 100%. I have solved same problem for ipod touch. Follow this video http://www.youtube.com/watch?v=AQk4-krrNVk
Thanks.
If my solution help you please vote up me.
May 22, 2009 | Apple iPod touch
Cell Phones Logo
46 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
