Question about Dishwashers
Nef built dishwasher power cuts when door is shut
Power cuts out when door is shut
    Problem Solver:
  • 17 Answers
You have an shor circuit from the door switch
Posted on Jul 12, 2013
Elctrolux dishwasher won't start, display won't light. Any suggestions?
Good Morning Friend,
I understand your Electrolux dishwasher, model# EWDW6505GS, seems like it is not receiving power to the control panel. I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and try any cycle. If you are still not receiving any lights, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing your control panel to not have power.. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Electrolux EWDW6505GS Fully Integrated...
MDB7600aws Maytag dishwasher heats up with door shut when off
Your timer is jamming on the heat cycle. When you open the door the door interlock switch cuts the power off and stops the cycle.
Probably if you just close the door again it will heat again unless the machine is started again.
You need to repair or replace the timer.
Mar 16, 2010 | Dishwashers
There is power to the unit, but there is no power to the touch pad
This could be the door switch. Its located behind the control panel. Shut off the breaker to your dishwasher and remove the screws on the inside of the door behind the panel. Locate the door switch and check.
Replace if needed. On some units there are two switches to check side by side.
Dec 28, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
I ran my dishwasher last night and woke up to a very hot dishwasher. The heating element stayed on. I have a GE GLD6760N10SS and when I close the door the element appears to come back on
This sounds like a bad relay or contactor that feeds power to the element. Opening the door most likely cuts power to the entire system. When the door closes, power is going through a relay that is stuck, allowing power when there should not be any. Follow the power line from the element back to relay that feeds it. Hopefully this will not be your control board. Relays are cheap and easy to replace. Computer boards are not. Good luck
Dec 04, 2009 | General Electric GLD6760N Stainless Steel...
Door on Hotpoint Diswasher BF1620 won't shut
To better assist you I need the Hotpoint Model n serial # look like this;
HDA3540NSA Hotpoint® Built-In Dishwasher HDA3500NWW Hotpoint® Built-In Dishwasher HDA3500NCC Hotpoint® Built-In Dishwasher HDA3500NBB Hotpoint® Built-In Dishwasher HLD4040NSA Hotpoint® Built-In Dishwasher HLD4000NWW Hotpoint® Built-In Dishwasher HLD4000NBB Hotpoint® Built-In Dishwasher HDA1100NWH Hotpoint® Built-In Dishwasher
Let me know wish one is yours.
Thank you
May 13, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Maytag dishwasher will not work
Check for broken wire(s) in the harness at the bottom of the front door (near hinge) where it transits from the inside of door to the lower motor compartment. (Design defect causes metal to cut the harness)
Jan 25, 2009 | Maytag 24 in. MDB7650AWS Built-in...
LG dishwasher shuts off, power failure
Did your problems get resolved? I would love to hear what you found. OK?
Jan 06, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Frigidiare Dishwasher
is there anything on the diplay while the door is open?
if not, replace the control board behind the keypad.
Sep 13, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
Top Dishwashers Experts
