Question about Euro-Pro Shark 9110 Sewing Machine
My machine has come to an almost stop when pressing the foot. What should I do. I don't see a place to oil it.
  • Euro-Pro Master
  • 7,365 Answers
Check to make sure the foot pedal is plugged into the machine correctly
also the foot pedal may need to be checked at a sewing machine repair shop to see if there is something wrong with the wiring or electronics.
Posted on Jul 12, 2013
How to thread kenmore sear roebuck sewing machine model 158. 1789181 got at auction no books
Sears carries a lot of manuals for their machines, although usually not free. In the meantime, there are many threading videos that demonstrate machine threading. Machines of similar models will thread similarly.
Threading mom old kenmore sewing machine
Kenmore 158 17550 Sewing Machine Tutorial
Probably best to raise the presser foot when threading so the thread will seat in the tension disk.
Before trying to sew, be sure to oil your machine with fresh, good quality sewing machine oil. Open the top, the side near the needle bar, and turn it on its back to get the underside. Place a couple drops of oil every place that metal rubs on metal. Adding hot air from a handheld hairdryer will make the oil effective quicker.
Be sure to install a brand new needle and use good quality thread--not old or bargain bin variety!
On the top left, there is probably a push button. This is the presser foot pressure adjustment. When the machine is stored, this pop-up button should be released (press down on the outer ring). Being stored with the pressure full on will eventually compress the spring that provides the pressure. Also, be sure to store the machine with the presser foot in the down position (preferably on a piece of scrap fabric). Avoid running the machine with the presser foot in direct contact with the feed dogs as this will wear the feed dogs and also create grooves in the presser foot.
Kenmore 158 1601 Sewing Machine Cleaning oiling and Maintenance
Jul 29, 2016 | Kenmore Sewing Machines
Why riccar a303 sewing machine just stop running?
Difficult to advise. Can you operate it manually by turning the handwheel clockwise? Does the motor make noise when you step on the foot control but the needle does not move?
It appears to be a mechanical machine. If so, it could need a good cleaning and oiling. That is probably a good place to start. (Consult your owner's manual and use ONLY fresh good quality sewing machine oil.) Could be a multiple of other things, ie loose/broken belt, foot control failure, carbon brushes or capacitor, electrical problem, motor problem... Probably best to take it in for service.
Nov 27, 2015 | Riccar Sewing Machines
Remove sewing maqchine case
Plate on bottom: Remove screws. Keep screws in safe place and oil moving parts with good quality sewing machine oil. Zoom with spout for sewing machines & servers is what I use purchased online...lubricate gears with Singer lubricant (in tube). Tip machine back onto a towel to remove screws. Just one drop oil on moving parts & dot of lube gear only if not showing signs of grease already. Please remove bobbin and presser foot before cleaning/oiling. One drop oil then generously SMEAR oil on oscillating hook, open right front door & one drop top of needle bar. Clean out race shuttle for lint, fuzz balls, broken threads with soft sewing machine brush & clean your feed dogs gently with bristles too. Hope this helps. Do not clean machine near children or curious pets! I run my machine with pedal on table top so I don't accidentally step on it. Control with right hand to see moving parts. At your own risk, of course. Safe and effective but only if you are extremely careful. Replace all screws securely. Put in new needle all the way UP into needle bar groove, presser foot UP turning handwheel towards you, flat end of needle to back, Thread Front to Back of needle.. Keeping presser foot raised @ highest position ensures thread locates the tension slots properly. Jimmy
Apr 07, 2012 | Singer Sewing Machines
Kenmore 385. 15343600
Remove bobbin, presser foot, needle. Tip machine back on towel gently. Unscrew plate--don't lose screws! Do not service in presence of children and curious pets. Put foot pedal next to you on tabletop. Use Zoom Sewing Machine oil. Any part MOVING that are NOT gears get one drop oil. Any DRY ONLY gears get dab of Singer sewing machine lubricant. Replace screws. Secure screws. Open left front compartment & one drop oil @ top of needle bar. Open race shuttle (where bobbin case fits in). One-half drop oil of on oscillating hook (bottom left - hand corner...smear that oil around! Insert NEW needle all way UP in needle bar groove, flat needle shank toward back. Turn handwheel towards you and raise. Raise presser foot so that threading locates all tension slots a's you pull thread TAUT from spool to each tension slot and left to right through silver, metal take-up lever, and down to tension bracket, pass needle, then pull 6" thread towards you and thread from FRONT to BACK of needle. Place bobbin into case and "thread" it. Set presser foot on DOWN position. Turn handwh towards you, dipping needle into needle plate. Make loop with bobbin thread, pull towards you. Place a good 7" underneath presser foot (both threads). Let machine RUN on 24" scrap to distrubute oil/lube. That's it! Jimmy
Apr 05, 2012 | Sewing Machines
How do you use the sliding button hole attatchment
attach the sliding foot by clipping off the current one, placing the sliding food onto the needle plate, lining up the clip with the attchment point and lowering the pressure foot down onto it so it clicks in.
Now, does your machine have a little lever device to the left and just behind the pressure foot, have a look for it. If yes, then pull it down, this is the buttonholing trigger and it connects with the sliding foot to trigger the reverse and stitching of the second side.
Program the machine for button holing, this might be pushing in a numbered code, on my 6500 there are five buttonholes and they each have a code that I enter.
Place your fabric test sample under the pressure foot and put the button into the back of the pressure foot, there is a little ratchet device that closes up holding the button firmly to get the right dimensions.
I always do at least 2 test buttonholes using same fabric, usually 2 layers with interfacing between.
Start the buttonholing sequence by pressing on your machines foot control, it should sew backwards away from you down the first side of the buttonhole, and the trigger should connect with a bit on the slide foot triggering the machine to stop, sew the bar tack, and then reverse and sew the otherside and final bar tack.
That's how it goes on my 6500, I hope this applies to your MC10000 too, it should be very similar. Your machine probably has at least 3 or 4 different types of buttonholes it can do. If you don't have a manual for it, it probably is worth sources one as these machines have lots of features to use.
Jun 12, 2011 | Janome Memory Craft 10000
How to sew buttonholes
First thing you'll need to do is switch the presser foot.
Your machine should have come with a specific button hole foot.
(might have an R on the bottom)
To snap off:
Raise the needle and presser foot.
Press the red button on the back of the foot holder
and the foot will drop.
To snap on:
Place the presser foot so the pin on the foot lies just
under the groove of the foot holder.
Lower the foot holder to lock the foot in place.
Select which buttonhole style you would like to stitch.
This can be done by selecting a mode (buttonholes are 06-08)
and then adjusting to the desired length and width.
After you do this, lower the presser foot and hold the foot pedal down.
The machine will automatically sew the buttonhole and stop when it is finished
All you'll need to do is just cut the thread after.
Hope you found this information helpful.
Mar 17, 2011 | Janome DC3050 Computerized Sewing Machine
I pulled out the lubricating strip under the bobbin
Bobbin Winding 1 Put spool of thread on spool pin. ] Use spool cushion when using cross wound thread. ] Use spool cap when using parallelwound thread. 2 Lift thread guide bar all the way up, and run thread through triangular thread guide as shown in drawing. 3Run thread through bobbin winding thread guide as shown in drawing. 4 Run thread through top thread notch 1, and align bottom thread notch 2 with guide pin on bobbin winder shaft. 5 Press bobbin stop up against empty bobbin. If the bobbin stop does not slide easily between the top and bottom of the bobbin, check that the bobbin is seated properly with the guide pin (4) inserted into the lower notch 6 While holding the end of the thread, step on the foot controller for a few seconds. Once enough thread has wound itself around the bobbin to hold itself in place, release the foot controller and trim the excess thread. 7 Stop winding when bobbin Begin
8 Manually move bobbin stop back to original position. 9 Cut thread and remove bobbin.
bobbin insertion 1 Lift slide plate (and open bobbin door). 2 Put bobbin into the bobbin case. ] Run thread through thread notch and under latch spring, so that a length of about 10 cm is exposed. ] Use a bobbin case with an idling prevention spring. 3 Pull the latch lever of the bobbin case out and push the bobbin case into the shuttle race and release the latch lever. ] If the latch lever is not all the way on the hook, it may fly off during sewing and cause lower thread breakage. 4 Lower slide plate and close bobbin door, following numbers 1 2 above in order. 6 While holding the end of the thread, step on the foot controller for a few seconds. Once enough thread has wound itself around the bobbin to hold itself in place, release the foot controller and trim the excess thread. 7 Stop winding when bobbin is full. Take foot off foot controller. * Place the thread end so that it does not protrude from the bobbin. Bobbin Stop
so this will be ok and no need to worry about this
Jun 23, 2009 | Singer CE-200 Quantum Futura Computerized...
Machine stops after 2-3 stitches
open your bobbin case and un jam it thread wound around the center
Dec 02, 2008 | Necchi 3537 Mechanical Sewing Machine
Brother XL-4012
ok,,when you press the foot peddle you will hear a continuous noise like a motor running that means its not the foot peddle, if not peddle is dying or motor carbon brushes are worn, this is a simple fix, we just need to narrow it down
Jan 16, 2008 | Sewing Machines
Euro-Pro Shark 9110 Sewing Machine Logo
44 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
