My new candy washer will not spin
Its gc4 2d
I have a candy CN105 washer 1000rpm and when it gets near the spin cycle at the end of a wash it stops before the spin and also sometimes during a wash cycle the dile starts moving round on its own so i...
Sounds like you need a new timer board/control package.
Most parts for modern washers cost almost as much as the thing is worth.
Then after you invest a lot of time and money you still have an older junk washer. Unless it's a simple filter or rubber gasket, I buy a new machine.
In the long run you will be ahead.
Nov 19, 2017 | Candy CNW136 Front Load Washer/Dryer
Spin cycle works with nothing in the drum but not with clothes in
if your washer does everything but spin, it is a door lock problem. Note: The door does lock, but does not send the correct signal allowing the washer to spin!!
Dec 31, 2010 | Candy CN146 Front Load Washer
I bought a candy washer 2 days ago and when it spins it bounces around n is very loud. also it makes a squeaky noise when drum turns as if the seal is to tight against the drum, please help . sal.
Make sure the shipping bolts have been removed, and make sure there is no polystyrene packing that needs to be removed.
Make sure the washer is absolutely level as well.
If all else fails, then I would recommend you contact the supplier, and relate the problem to them, more so as it is a new washer.
Hope this helps.
Jan 18, 2010 | Candy Washing Machines
Making a noise when spinning like there a coin inside
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
hdgket
Nov 29, 2009 | Candy CNW136 Front Load Washer/Dryer
My candy go1682 makes a very loud banging noise on spin,it almost sounds like a plane taking off. julie
Suspension/Damping stut has failed , you need a new one pronto
Worst case is that the inner drum has come loose from the mounting on the back
Oct 02, 2009 | Maytag MAH6500 Neptune Front Loading...
Candy go482 washer won't spin
I ahve Exactly the same problem, Also bought from Cometand also had 2 engineers out.
Apr 08, 2009 | Candy Washing Machines
Washer/dryer problems
If you can locate the filter, remove and clean it.
They are usually found at the bottom front, behind a removable plastic panel.
Plz rate my solution,
Thanks.
Jan 13, 2009 | Candy CNW136 Front Load Washer/Dryer
Hot wash programme won't work.
more than likely that your timer dial has a fault on it to replace your timer dial is alot if u need the 90 degree wash then you really are better off buying a new washer just as cheap to do it this way sorry for the bad news theres nothing you can really do sorry yet again m8
Dec 11, 2006 | Candy AQ130 Front Load Washer
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
