Question about Canon BubbleJet i9950 InkJet Photo Printer
Printerhead By starting up the printer, the printerhead was as usual moving to te left. But this time he never came back.
When the printhead moved left did it hit the left hand travel stop really hard? If so it's probably the same thing that happened to mine-a failure of a travel sensor, which is part of a circuit board. Turned out to be a repair shop job which took forever due to Canon's inability to provide spares for its products.
Posted on Oct 12, 2007
Can i move printerhead without power
I have done this many times. Yes. It will reset itself once turned on PLEASE TURN OFF POWER PRIOR TO manually moving! Please leave feedback!
Jul 11, 2016 | Office Equipment & Supplies
My printer canon pixma mp550 shows error 5100
The marked part was sometimes not pulled back completely. When printerhead moved to the left position it was stopped there. This caused a horrible sound, caused by the belt.
You could see wear at the area. Flattened the surface with a knife. Tested by tipping down with srewdriver.
Oct 19, 2012 | Office Equipment & Supplies
My print comes out with a blank strip down the left side of page......when print out comes out about a fourth of the way from left to right theres a blank strip fromtop to bottom...about a inch wide
If the printhead in an inkjet printer is printer but not moving then a single block of print will normally be generated along the page. When this kind of problem happens the related components include the printhead positioning motor, the timing belt, the home position sensor, the control board and possibly the power supply.
With the power off, manually move the printhead to the center of the printer. Turn the printer on to see if the printerhead seeks the home position at the far end of the printer. if the printhead moves to the end of the printer, and it doesn't turn off, or doesn't return to the center of the printer then the home position sensor is malfunctioning and needs replacing. If the printhead assembly will not move at any time, check to see if the printer is in maintenance mode. In this mode the printer typically keeps the printer assembly in the home position. If no mode problems are present, then the positioning motor should be replaced.
Good Luck!
Dec 13, 2010 | Lexmark X2600 InkJet Printer
Epson LX 300 printer. every line, starting
Try to check your printerhead it could be damage due to over use or old printerhead. Just replace your printerhead to print it normal.
May 29, 2010 | Epson LX-300 Matrix Printer
I get a 6a00 error, the first time i start up my canon pixma mx850. I tried to move the printerhead manually and that works fine. But i still get this error everytime. When I look at the sliding mechanism...
if it's 6A00 then theres a problem with the cleaning unit where the printhead parks. Look for any paper scraps in that area,
the two foam pads that must cover/protect the heads when the cartridge is parked are jammed up, preventing the head cleaning squeegee from moving back and forth. Just to the right of these pads is a piece of blue plastic, part of the assembly holding the foam pads . very gentle downward pressure on this blue plastic frees the pads and the squeegee could move back and forth again. and will clear ur issue
there is a safety pin lodged under the far right side (home base). gently push the unit to the left to expose the imposter, and remove it
regards
Aug 16, 2009 | Canon PIXMA MX850 Multifunction Printer
Howdo you remove printerhead from Kodak 5500
Here is the manual for reference:
Kodak 5500 Manual
If you go to page 88, these instructions are given...with pictures.
1 Make sure the AiO printer is on.
2 Open the printer access door. The carriage moves to a center position.
3 Wait until the printhead is idle and silent, then pinch the pinch latch on the ink cartridge with your thumb and forefinger and lift it out of the print head. Remove both ink cartridges and place them on a flat surface with the ink pads up.
4 Unlatch the printhead by pressing the button in the upper-left corner of the carriage.
5 Remove the old printhead.
Thanks for using Fixya.
Jul 02, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printerhead is not moving
12 times is AP position error.
Check the carriage lift mechanism or paper feed mechanism.
In worst case the print head or logic board assembly are defective.
Mar 27, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Hp officejet 7110 All in one
The early signs of mechanical failure aka carriage stall. You can try resetting the print heads and cartridges and see if it helps.
Sep 17, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Printerhead problem
The problem with encoder strip please follow the steps given in this link: (note is the not canon but lexmark website but the problem is with encoder strip please follow the steps WARNING! Be very careful when cleaning or adjusting the printer's encoder strip if broken it may not work )
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:549:0:0&framed=&docid=ENUS22722&relevance=0
Just follow the steps that it if unable to do it please cannon tech support>>>>>>>>>>>>>>
http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
May 03, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Canon BubbleJet i9950 InkJet Photo Printer Logo
53 people viewed this question
Clive
Clive
old marine
old marine
