Question about Echo Garden
Echo Trimmer starts but won't run
Starts but will run only a few seconds. After starting, while idling, it will die immediately if I increase throttle. I have replaced the carburetor, spark plug, and cleaned the air filter. The first time starting after replacing the carburetor, it ran fine for several minutes. I began a test of actually trimming but as soon as it came under a little load it began to lose RPM until it died. It acts as if it is starved for gas.
    Habit-Forming:
  • 151 Answers
Replace the filter in the gas tank. Sounds like it is mostly plugged.
Posted on Jul 10, 2017
5 Suggested Answers
SOURCE: My Echo power edge trimmer
I was having the same problem and stood there while the tech fixed it for me. I could have done it myself; honestly, nothing to be afraid of. Take the air cleaner off and then take the carburetor off and start taking it apart layer by layer (remove screws and take pictures with a digital camera of how to put it back). It is not complicated and it was a small piece of grass stuck where you never thought it could get that allowed a start but not full throttle.
Posted on Jun 05, 2009
#1 Taper
  • 1040 Answers
SOURCE: engine starts finem, but will not reach fill RPM.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Posted on Jun 28, 2009
  • 512 Answers
SOURCE: Starts fine but dies when set to run.
You either have a air leak in a fuel line, carb jets are plugged, or carb seals went bad. They sell a rebuild kit for your carb, 10-15 dollars. I would start by removing carb spraying it with carb cleaner and blowing it out with a air gun, put it back on and see if this worked. If not I would replace fuel lines and rebuild carb.
Posted on Jul 25, 2010
vincob
  • 718 Answers
SOURCE: I have a craftsman 32cc weedwacker gas trimmer,
No more Mr. nice guy. But it sounds like your just out of adjustment, try readjusting your high idle screw. Good Luck..
Posted on Apr 03, 2011
Ryobi line trimmer plt3043a starts idles but dies when i attempt to increase speed
May I suggest checking along the fuel line and its attachments for a very minor air leak. The minute it sucks air it will stop. Check any rubber washers or O rings too.
Feb 02, 2015 | Ryobi Garden
HUSQVARNA 128LD WILL START RUN FOR A FEW SECONDS AND DIE.
You need to adjust your idle screws. Start at 1 and a half turns out for High and Low then go from there.
Aug 22, 2014 | Husqvarna 128 LD Weedeater
My 1979 buick reagal runs rugh when is hot
Idles rough and quits when gas pedal is pressed less?
http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html
Rough idle, staling and Erratic shifting?
http://technoanswers.blogspot.in/2012/03/rough-idlestaling-and-erratic-shifting.html
Its a hot start issue.
Can be related to low fuel pressure or problem with crank sensor.
Also it can be weak battery or starter.
But possibilities are to be inspected to confirm what exactly it is.------
To troubleshoot and confirm the issue,i suggest you refer few solved help links with similar types of problem like yours:------
Click the link below:------
1991 Toyota Trecel: Engine Starts fine but dies when gets Warm?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1995 Lexus LS400: Running Hot?
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
2002 Toyota Camry: Puff of Blue or White Smoke while Starting?
http://whatisbyme.blogspot.in/2012/05/2002-toyota-camry-puff-of-blue-or-white.html
Multiple problems on car: Car runs hot, A/C blows hot and car starts surging?
http://schematicsdiagram.blogspot.in/2012/04/multiple-problems-on-car-car-runs-hotac.html
Delay starting on Toyota Prius?
http://schematicsdiagram.blogspot.in/2012/02/delay-starting-on-toyota-prius.html
Honda car will not start intermittently?
http://technoanswers.blogspot.in/2012/02/honda-car-will-not-start-intermittently.html
Vehicle Starts, Runs and Loses Power
http://whoisbyme.blogspot.in/2012/07/vehicle-startsruns-and-loses-power.html
Intermittent starting issues on Volvo 760?
http://schematicsdiagram.blogspot.in/2012/02/intermittent-starting-issues-on-volvo.html
Car starts and cuts off immediately?
http://repairhelpcenter.blogspot.com/2012/01/car-starts-and-cuts-off-immediately.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These details will help.
Thanks.
Dec 04, 2012 | Cars & Trucks
My toro weed trimmer starts good runs great for a few minutes then starts to bogg out then dies, will start back up but won't stay running.i already replaced the fuel tank, lines and filter.
Check the air filter isn't dirty.
If the machine runs ok on high speed but cuts out while idling, the idle speed may be too low. There is usually an adustment screw for increasing the speed.
If the fuel line is a flexible type which moves around inside the tank, check it is able to move freely because if you are cutting at awkward angles, the end of the line can end end up above the surface of the fuel, **** in air and airlock the line. You can eliminate this as the problem by fully filling the tank.
Check whether there is a one way check valve on the tank. This vents air into the tank as the fuel leaves for the carburettor. Sometimes particles of dirt can get stuck in this.
Apr 30, 2011 | RTO Weed Eater Hedge Trimmer 20cc,...
4 cycle cub cadet will start but as you increase RPM it dies
Check at the exhaust port. Clean out any carbon buildup there. Believe me, it makes a big difference. Hope this helped and best wishes.
Sep 04, 2009 | Craftsman 25cc Gas Line Trimmer
My Echo power edge trimmer starts and idles fine. When I try to throttle up it begins to die out. I can get it to run at a slower speed, but to get it to maximum rev it dies. I replaced the spark plug,...
Apr 18, 2009 | Echo Garden
Chainsaw runs out of gas.
From your description, it sounds like your carb is running too lean. Make sure the spark arrestor screen is free of carbon build-up and the air filter is in place. Warm the saw up. With the saw at idle, adjust the Low adjustment screw to slightly enrich the mixture. If you turn it to run the fastest possible when idling, it is too lean. When the Low setting is right, you will be able to increase the RPM without it dying. If the High setting is way too lean, it may also die when you open up the throttle. If you run the saw too lean, it willl overheat and sieze.
Mar 29, 2009 | Echo Garden
Garden Logo
27 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
