Question about Coffee Makers & Espresso Machines
Aulika error codes
List of error codes on saeco aulika
Error code 5 on saeco minuto coffee machine
Error code 5 means the water flow is obstructed. Here are possible locations:
1- The machine was not descaled. Calcium deposits are clogging the water system.
2- The flow meter is not passing impulses for water flow speed & quantity.
3- Descale Descale Descale.
Before you select the automatic descaling, make a few espresso without adding coffee grounds. The automatic cycle does not clean the coffee side of the machine. You have to do it intentionally.
Dec 18, 2016 | Saeco Coffee Makers & Espresso Machines
Saeco error: water circuit priming E05 Hi,could anyone help me with this problem? Vinegar didn't help...
Take out the water filter and see if the code disappears. If it does, replace the water filter. If not then use vinegar to descale the unit.
Dec 17, 2015 | Saeco Coffee Makers & Espresso Machines
What does error code 23 mean on the Saeco Minuto Coffee machine
I believe error 23 is a sensor error for the lever on the front of a minuto.. It cannot be repair at home and would have to go to a service center.
Service Center for Saeco Gaggia Rancilio Spidem Starbucks Espresso Machines
Jun 10, 2015 | Saeco Coffee Makers & Espresso Machines
Saeco xelsis error code 5
Error 5 on your machine usually means it needs a new pump. The pump may be too weak to do the job.
Always try to descale the machine before doing anything else. If you can't then you will have to take it in for service.
Please visit our service center page.
If you need descaler visit this page.
http://www.cerinicoffee.com/espresso-descaler-25/?sort=bestselling
Dec 30, 2013 | Saeco Coffee Makers & Espresso Machines
Saeco error codes
I don't think this is the case. The E04 code is about lubrication of the brew group. This is directly from Saeco support in Germany. However, the problem does persist. It seems to be an issue of poor design more than anything else.
Dec 22, 2013 | Saeco Coffee Makers & Espresso Machines
We have the Saeco Exprelia and have the error message E15. We have tried turning it off and back on again but still insists on cleaning the carafe but no water is coming through - almost like its blocked...
Working for the Philips-Saeco Costumer Service, so heres your fix.
Call your Hotline, tell em about the error code.
Its about the Temperature Controller steering the boiler.
Its not sending any signals to the boiler when this happens, and the only way to fix it is to have it repaired by a certified servicer.
Ask the hotline about that.
Jan 01, 2011 | Saeco Coffee Makers & Espresso Machines
Saeco Magic where is the gasket on the steam pin?
You can get most parts from Saeco directly. I know they are hard to get in touch with, but once you get them they are extremely helpful. The parts are a bit expensive, but it is nice to be able to purchase them. I was able to find a parts list for my Saeco Magic Comfort Plus by doing an Internet search for it. It has every part listed and a take apart view; very handy to see what goes where and what possibly might need replacing. You may want to see if Saeco offers that when you call them for your model.
Apr 12, 2010 | Saeco Magic Cappuccino Espresso&Cappuccino...
Error Code 4 on Saeco Talea Ring
I need to know what error code 4 means as well.
Has anyone helped you yet?
Apr 05, 2009 | Saeco Talea Ring Plus Espresso Maker with...
Coffee Makers & Espresso Machines Logo
1,030 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
