Question about NCR 7197-1001-9001 - Realpos 7197 Receipt Printer
Installation drivers for win7 billing purpus
How to install printer canon LBP1120 in win 7 64 bit?
According to MicroSoft (and searching the Canon site for drivers) they have not released drivers for that printer and Win7 (which seems very odd as long as Win7 has been out.
Oct 04, 2014 | Canon LBP 1120 Laser Printer
I need driver for Hitachi GD2000 2X ATAPI/E IDE DVD-ROM Drive to complete a win7 install
You're not going to get an install then. If that is NOT an OEM Install disc, you might have to try another drive to do the install with. Most ATAPI/IDE Drives are run by the BIOS.
Feb 01, 2014 | Compaq HITACHI GD2000 2X ATAPI/E IDE...
I have a "i-nix NWC-15-2L
That means the win7 has already some driver installed in it.. Unistall the driver from win7 and reinstall your webcam driver from the CD which you got with your webcam (check whether its compatible with win7).. Hope this wil solve your problem
May 13, 2011 | Computers & Internet
Received a reply from "Geekman"
Your desktop was designed for Win7 and WILL NOT work properly on XP. You can however, install the support for XP part of Win7 Ultimate Edition. Aparently it works realy well but I have no personal dealings with that side as I like Win7.
Hope that brings an end to your XP torment.
Feb 12, 2011 | Computers & Internet
The card was working fine in windows xp. But i recently installed windows 7 and the card is not detected.
need a new driver for Win7 for the SB card....for Win7 HW mafgs have not develoepd any drivers as the Win7 source code was not provided to the Hw nfgs by MS....
MS has develoepd std drivers for all HWs that can install any HWs....
you need to register with MS your copy of Win7 and download all updates and the SB card will auto install once all updates are done....
Feb 07, 2011 | Creative Labs Sound Blaster Live! 5.1...
Not install to windows7
may your win7 is win7 64bit but your camera driver is for win7 32bit, reinstall driver using driver for win7 64 bit
Jan 23, 2011 | A4tech PK-635 Webcam
Can you give me a link to download a driver for Protax DC500t camera that works on windows7? The disk I have only works on windows xp Thanks, Peter
If your Windows7 is x32 version, then your driver should work in it. But if you have x64 version, you'll get some trouble to install driver for XP in Win7 PCs. I've stuck the same problem like you, but my case was modem problem. Programs like game or other application that can be installed in XP usually can be installed in Win7 64 bit and extracted in Program Files (x86), but driver case is an exception.
I've search via google but I got nothing. Actually, there is a way to install XP driver in Win7 which is use XP Mode in Win7, but you must upgrade your OS to Win7 Ultimate (I think, see microsoft website to make sure) so you can use this mode.
or
you can install two OS in your PC, Win7 and Win XP maybe. When you want to install driver for XP or if you want to do some work related to this driver, you can start up with XP OS, but if you want to do other work, use Win7.
This is so unconvenient, but better than you can't connect your camera to your PC.
Good luck Peter !
Hope this help and be kind to rate my answer please.
(^_^)
Jan 06, 2011 | Cameras
HP TX1110us, custom install to win7, RC inoperable
To get the remote to work on Win7 you need to install the CIR driver. Check the driver download page for your product for the appropriate Win7 driver. http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=ob-75405-1&jumpid=reg_R1002_USEN If a Win7 driver is not available then the Vista driver will also work. Please check with this?Plz vote if this resolves issue.. Dreamkam
May 20, 2010 | HP Pavilion tx1000z Notebook
Lan drivers & draphic drivers are not installing. Im using win7
There are no drivers available or needed for this board under Win7.
Optionally you may use this tool (http://www.intel.com/support/motherboards/desktop/detect.htm) to detect any drivers you may be missing. Your biggest problem may be that Win7 hasn't detected your Lan card and update isn't possible. If this is the case try installing a USB Wifi Card and doing the update. Win7 will automatically find the drivers and install them for you with update.
Mar 07, 2010 | Intel D845GVSR Motherboard
Cant detect MSI 661FM3-V LAN driver for win7
eventually through continued research, i found out that this is a common issue with several mobo ang win7... SIS driver for LAN was the answer. i just downloaded the driver then install manually. although there is still no driver support intended for win7 as of the moment, vista driver does the trick...
Feb 01, 2010 | MSI 661FM3-V Motherboard
NCR 7197-1001-9001 - Realpos 7197 Receipt Printer Logo
Top NCR Office Equipment & Supplies Experts
k24674
Are you a NCR Office Equipment and Supply Expert? Answer questions, earn points and help others
