Question about Air Conditioning and Heat for Hyundai Tucson
Ac blows hard but is not cold.
The fuse was blown so i installed another one and it acted like it was getting colder. i got a mile from thr house and the belt started smoking! i assume this would mean the compressor is locked up? it also looked like the bearing was coming apart.
  • Hyundai Master
  • 22,246 Answers
Something is wrong either the bearing is locking up or the compressor is faulty
Posted on Jul 12, 2013
Whats wrong with my AC ?
I see these climate controllers fail all the time. Does the a/c not blow cold or does the whole unit shut off all together? Also, what year is the truck? Please advise
Aug 04, 2016 | Ford F-150 F150 Extended Cab
Saturn vue ac
How do you check an orifice? Oh the high pressure side it will be warm to hot to the touch. The cold low pressure side will be much colder 45-50 degrees. if there is little difference and the charge is good the orifice could be plugged.
Aug 22, 2014 | 2006 Saturn Vue
2004 Oldsmobile Alero, 4 door, 3.4. 37 fuse has blown twice. I replaced the fuse and it worked fine but I think it's going to keep blowing. I heard that fuse 37 relates to air conditioning. Is that true?...
Whenever a fuse blows it is because the if a fault in the wiring or components that that fuse is protecting. So with that said it wouldn't have anything to do with freon, is your fan for the heater/AC working ok? Does it work on all speeds and not making noise. As for your freon if you have anyone who could put a little in for you to see if it low that would save you some money. Get back to me if on your fan operation.
Jun 25, 2014 | Cars & Trucks
Maytag m6x06f2a like new but doest blow cold air
Make sure the Thermostat is set correctly! The problem with mine was the temp in the house was colder than my A/C lowest thermostat setting.I had my AC temp setting on 66 degrees.The temp in the house was a little lower so the AC didnt kick on just the fan blowing cool air and no compressor working. The next day it was warmer out and the house temp was 79. So when I powered up the AC set at 66 i heard the compressor kick in and the AC worked fine.
Aug 27, 2013 | Maytag M6X06F2A Air Conditioner
Sentra AC
There's a 10amp fuse that powers the ac clutch relay and compressor. There are 15amp fuses that power the blower motor and the ac control switch. All of those fuses get power from the key switch. The resistor and fan switch provide the ground circuit for the blower motor.
I would want to know if those fuses are getting power, and if the control panel is working. You should be able to ground the blower motor and make it run on high, and that should not have any effect on if the ac compressor is running or not.
It could be a key switch problem in that the circuit is not strong enough to handle the load from the blower and the compressor at the same time.
Jun 21, 2013 | Cars & Trucks
2003 chevy s10 - keeps blowing out AC fuse. Will work for a couple minutes then compressor quits working. Check the fuse, it is blown out. Put in a new fuse, works a couple minutes, then quits, fuse blown...
Unplug the a/c compressor, there will be a plug near the pulley. Install a new fuse. Start the vehicle and turn the a/c on. Wait about the same amount of time it took for the fuse to blow in the past. Did the cues blow? If no replace the a/c compressor, the clutch has gone bad. If yes, than the wiring between the fuse and the relay or the relay to the comps sore is grounded. A careful inspection of the wiring should reveal the problem.
Jul 03, 2011 | 2003 Chevrolet S-10
Compressor does not engage when ac is turned on, is it definitely the compressor?
It could be low in freon and won't allow the compressor to engage. Have you checked to see if your fuse is blown? It should be in the fuse panel of the car. Was the air acting up prior to not working anymore? like not blowing real cold air or anything?
Jul 29, 2009 | 2000 Dodge Intrepid
No cold air blowing from RUDD UPKA_)$#JAZ
A few things to check; Clean filter, make sure none of your ducts have blown loose in attic area, or under house. If neither problem exists check to make sure your compressor is kicking on, it makes a deeper toned noise than fan motor. If it's not coming on, call A\C company, preferably the installer to check it out. Good luck.
Jul 10, 2009 | Heating & Cooling
AC DIED ON ME AT 51,000 MILES
check fuse, maybe you just have a blown fuse. Or you might want to see if you need it charged.
Jun 14, 2009 | 2006 Volvo S40
I have a problem with my alero.the mini fuses (10 AMP)that go to the gauges,ac,and speedometer,get blown out every tine i install a new one in place.the ac blower comes on but no ac cold air.both the mini...
Without being there to help your best bet would be to get a box of fuses and start unplugging each component one at a time until the fuse does not blow. Now you will know where the problem is.
Aug 11, 2008 | Oldsmobile Alero Cars & Trucks
Air Conditioning and Heat for Hyundai Tucson Logo
108 people viewed this question
Top Hyundai Vehicle Parts & Accessories Experts
Lawrence Oravetz
Colin Stickland
Colin Stickland
Are you a Hyundai Vehicle Part and Accessory Expert? Answer questions, earn points and help others
