Question about Dishwashers
The heating is not working at all on my fujitsu air conditioner
Hi, I have a Fujitsu Inverter AR-RY3. when using it in summer the cooling works fine. however, now we are trying to use the heating option and it is not working. I press 'start', push master control button to 'heat', fan to 'high' and have set temperature, at multiple different temperatures, and no heat comes out. the fan opens and a green/yellow light flashes but that's it. please help! thankyou
    Problem Solver:
  • 17 Answers
Should have an heating element inside...that one I think is broken or can be also the thermostat..
Posted on Jul 12, 2013
SOURCE: Kenmore Quiet Guard 2 keypad
Sounds like the electronic controls (smart card) are acting up. Try shutting off the power at your fuse box or shut off the circuit breaker for 1 minute them turn the power on again. This fix quite often works on electronic appliances.
Posted on Apr 08, 2007
  • 1003 Answers
SOURCE: Kenmore 587 High Temp/Heat Dry lights flashing, cycle not complete
REPLACE TIMER
Posted on Jan 18, 2008
  • 77 Answers
SOURCE: Won't run - normal light flashes
You may try removing power to D/W for a minute and reconecting. likely cause though is keypad (console). If a light above a pad stays on the pad is likely closed all the time. Normal is probably cycle most often used. you can test the keypad by removing power to D/W and accessing the control panel. remove conncter P-1 and using an ohmeter test resistance between 13 and 4 on the connecter coming from keypad. yes without very small clips or 4 steady hands it is a little tricky. in the field we use a breakout board. if you get any reading when not pushed pad is bad. you may find a manual inside the kickplate which explains the keypad sequence. it may be control but more likely keypad, even if test is inconclusive.
Posted on Jun 07, 2008
SOURCE: Hi, I have a KitchenAid Model: KUDP02FRSS1. I
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4e8b0d2df77cd7e585256cd800643b6d?OpenDocument
please find your service and repair manual above, use this in conjunction with the website provided and troubleshoot and isolate your issue with a view to a repair.
this website below will show you how to troubleshoot and repair this unit.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Most likely you have a switch, or a sensor issue. Now, if the soap tray doesn't open, you may have a solenoid problem, or the circuit that drives it, they all may be interconnected, if so, this usually points the the controller. Many problem are with the actual control panel, but first one must eliminate one by one the possible sources of the problem, sensors, switches, circuit boards etc.
Posted on Sep 19, 2010
jyackle5
  • 8197 Answers
SOURCE: I have a Kenmore Ultra Wash 15632/34/37/39. The
Try to Press and hold AIR DRY for 4 seconds, to reset the dishwasher
Posted on Nov 15, 2010
HOW DO I SET THE TIME on Fujitsu AR-RY3
Right above the 'CLOCK ADJUST' there is a small hole, you need to push a ballpoint pen or something into that hole, to allow you to set the clock using the - and + buttons next to it. Then press the pen into that hole again in order to finalize the time.
Dec 09, 2010 | Fujitsu 36CS Air Conditioner
We bought a house with Fujitsu Air-conditioners we have no instruction manual on how to use the remote. Im trying to set it to go off after an hour or so. Model No.INDOOR UNIT is, AST12RSJCW Serial No is...
Switch on by pressing ON/OFF. Press mode button to cool position. for cool and keep required temp by clicking
Same procedure for Heat. For heat keep +29 and for cool 25 to 22 degree. Press fan for High, Med,Low. If you keep mode in Auto cool and the fan speed will be low and you can't change fan speed.
Please visit Fujitsu website for further details. Hope my msg is helpful?
Dec 09, 2010 | Fujitsu Heating & Cooling
How to change the time on my Model Number: AR-RY3 remote conrtol
Nov 15, 2010 | Fujitsu 36CS Air Conditioner
Fujitsu inverter; opens vents but no red light, no cold air
check that it is set to cooling sounds like it may be set to heat in cooling mode the indoor fan should at least run
Mar 10, 2010 | Heating & Cooling
My fujitsu inverter does not cool below 18deg C
Heya Mark,
Fujitsu air cons are factory set at 18degs you cannot change it without going through all the controller programs. Normally air cons are serpose to run around the 20deg point, is the air con not running effectually or do you just really like it cold.
I could check with tech help and see if I can send you the derictions of changing the minimum set point but it will not be good in the long run for your unit
Jan 07, 2009 | Fujitsu 36CS Air Conditioner
Dishwashers Logo
152 people viewed this question
Top Dishwashers Experts
Owen Barnes
