Aficio mp 161 firmware update
Where can i find the latest firmware version for the printer ricoh aficio mp 161
Touch2Heaven
  • 145 Answers
SOURCE: RICOH AFICIO MP 2000
you must clean developer and drum section. after that you must put new developer and initialize it. After that place in correct toner.
Posted on Oct 15, 2008
Joed911
  • 4338 Answers
SOURCE: i need ricoh aficio mp 1600le driver, how do i get into.
Here is the driver page:
http://www.ricoh.com.sg/downloads/drivers1.aspx?path=http://support.ricoh.com/bb/html/dr_ut_e/ra/model/mp16/mp16en.htm
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 11, 2008
SOURCE: adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
Posted on Apr 11, 2009
SOURCE: Ricoh Aficio MP 161 giving me an error code of
One of the following controllers is
installed to the basic model:
* The controller of the MFP
model
copier/facsimile model
printer/scanner/copier
model
OR
The controller of the optional
printer/scanner is installed to one of
the following models:
* The MFP model
* The copier/facsimile model
* The printer/scanner/copier
Posted on Dec 04, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: My Ricoh Aficio MP 161 said to add toner but still won't copy
Check your old toner bottle and make sure the plastic "cap" is still in the bottle. These machines have an occaisional problem with the caps coming off (not the black screw off cap but the semi clear cap under the black screw off cap) and staying inside the black plastic "cup" that you insert the toner into. If the cap is missing it may be stuck inside this cup. If the cap is still in your old cartridge then try opening/closing the front door and letting the machine cycle to see if the toner light goes out. May have to do this several times. Had one customer just yesrday have to do this to clear the toner light after adding toner.
Good Luck.
Posted on Jan 28, 2010
Ricoh aficio mp 161 firmware
What firmware are you looking for?
System/copy, Engine...........
Jun 24, 2016 | Ricoh Office Equipment & Supplies
I need to install firmware for window 8 on a Ricoh Aficio Mp C2000
You will need a service technician to update the firmware. He will have to download from Ricoh's service website.
Nov 09, 2013 | Ricoh Aficio MP 2000 Black and White...
How to enter service mode in ricoh aficio mp 161
Service mode is 'Clear-1-0-7-stop (hold stop until machine goes into service mode).
Aug 22, 2012 | Ricoh Aficio MP 161 Black and White Copier
Firmware ricoh mp 4000
i can firmware ricoh mpc 6000, please sent to me phamgia6688@gmail.com.
thanks!
Aug 17, 2012 | Ricoh Aficio Mp 4000...
I have a Ricoh 161 but after a firmware update erro (NIB) the machine tries to continue the update. How I cancel the firmware update or reset the firmware in the machine? ----------------- Eu tenho uma...
You can not stop a firmware update.
Did you turn the machine off while the firmware update? If you did that your NVram is broken
I think that the only chance you have is with a new NVram. Sorry but you will have to put a new NVram.
Jun 10, 2011 | Ricoh Aficio MP 161 Black and White Copier
TENHO UMA RICOH 161 E DEU O CODIGO SC 819
Isso é um erro de firmware.
Existe uma actualização que corrige isso. Se tiveres acesso a descarregar os firmwares e se souberes como fazer... O teu problema está resolvido.
Contudo aconselho que ligues com a assistencia tecnica. Contacta com a Ricoh portugal e eles enviam-te um tecnico que saberá fazer isso.
Boa sorte.
Mar 01, 2011 | Ricoh Aficio MP 161 Black and White Copier
SC550 Error. Ricoh MP 6500. Cleared Parts Exceding Target list. Reset 1902-001 on Copy SP. Still get SC 550 after power-up. ...Red "alert" light on, and red light on near "printer"...
That error code refers to the FUSING WEB END.
First of all you must see if the fusing web is end.
If the error occurs before the web ended you have to upgrade your firmware. There is a release firmware that corrects this symptom.
Feb 23, 2011 | Ricoh Aficio MP 161 Black and White Copier
I have a Ricoh Aficio MP 161 that was given me to use at work, I am on a construction site, and we don't have internet access, so I had to borrow a Verison Access card... anyway I have tried to install...
What was the driver that was installed? Where did you get? Are you sure that was installed the PCL6 for Ricoh Aficio MP 161?
I think your problem is with the driver. You can download for free the driver on the page of Ricoh.com.
You have a good equipment. I have much experience in this model. Reply any question ok!!!???
Feb 08, 2011 | Ricoh Aficio MP 161 Black and White Copier
Wen i turn the switch on in my ricoh aficio ap 3800c this shows in the screen cs999 what is that
This is a firmware error code. You are going to need a service tech to reload the firmware. Make sure they use the latest version with any and all updates included.
Dec 19, 2009 | Ricoh Aficio AP3800C Laser Printer
k24674
