Ac problems Laptop not running in ac mode
You must check the supply of your laptop
Posted on Jul 12, 2013
Hi. I have a HP Compaq 6820S, Intel Pentium T7250, 2 Gb RAM, 160 Gb HDD, i have a problem, Laptop won't charge battery. I let the laptop in sleep mode, around 7 days, when i come back, battery was 0%,...
try a new battery yet? (brand new fresh)
sleep mode. so you want it to run for 7 days in sleep.
ive no idea how long this laptop runs in sleep
and hibernate is longer.
no idea at all.
you do know that the speed features are programmable
right?
including what chips do and do not go to sleep'
like USB ports, WIFI, and all wake on , features. like Ethernet chip.
and more.
why not just turn it off, and let the battery last longer..
this mode sleep kills batteries faster. way faster.
leave it plugged in all the time to the wall pack.
so the battery never drains unless you need to use it, on battery.
Jul 18, 2017 | HP Compaq 6820s Notebook
Performance monitor extencion dll for clr.this can only be used on windows nt.yahoomessenger-could not load on non-windowsnt sistem
Run properties of the file (c:\Program Files\Skype\Phone\) Skype.exe, (e.g. right mouse button on the file in Explorer) and uncheck the "Run this program in compatibility mode for:" option in Compatibility tab. Known fix is to choose Run this program in compatibility mode for Window 95.
Mar 02, 2011 | Amstron LG Electronics LS50-AGHF1 Laptop...
I have a DELL Vostro 1500 laptop, since the last 2 weeks it appeared a message when i turn on my laptop, it says: " The AC power adapter wattage and type cannot be determined. The battery...
Certain models talk to a chip in the adapter, sounds like this one has gone bad. At this point you can live with, buy a new one or pick up a used. This is a fairly popular model and you should be able to locate one from a dead laptop.
Mar 06, 2017 | Dell Vostro 1500 Notebook
My laptop is not switching to AC mode even when plugged into Ac Power outlet. I work on battery mode and after full battery drain, the laptop goes into hybernation...once into hybernation it starts...
1. You may possibly have a faulty power supply adapter. Contact the manufacturer and see if there are any call backs on the power adapter for you laptop unit
2. you may also have a damaged connector at the laptop connection. This will require repair by a technician.
Aug 03, 2010 | Computers & Internet
When the AC adapter is connected the laptop runs slower than its only connected to its battery, what is the solution for this problem?
Hi
You need to look into your power options, it should be set up to run in low power mode which will use less CPU, screen power etc when running on batt and full mode when running with power. Its prob these setting that are messed up
Mar 19, 2010 | HP Compaq nx6310 Notebook
Hi I have a acer aspire 1694WLMi laptop which doesn't charge fully. Also when the ac adapter is connected the screen keeps flashing between battery mode and ac mode.
The source of the problem obviously is either the AC power cord or the battery, or it could be a combination of the two. In terms of the symptoms you describe, it could be a faulty AC cord. This could involve a few possiblities: loose connection between the AC plug and the AC adapter unit, a loose connection between the mini plug (the part that goes into your laptop) and the AC adapter unit, or the AC unit itself could be going bad.
Not sure how intermittent the flashing between battery and ac mode is. If you're talking very frequent such as once every minute or so, I would be suspicious of either the plug (both AC and input to laptop sides) or the connections between the AC adapter portion and the plug. Not sure how long you've had the laptop and cord, but it is possible that the cord has somehow worn out. This wearing out can be accelerated if you often use the AC cord and there is tension on it.
One finally suggestion of course is to either try a new cord. You can often find them on e-bay and can even purchase used ones for a cheap price. If you do, you will then obviously be able to confirm that the cord was the problem. One might think or say the battery is not charging fully and is the problem. True, the battery may be a problem, but the root cause may be the cord.
I Fix It
Aug 14, 2009 | Computers & Internet
My laptop doesn't open when i try to push the on button..help?
it is basically a hardware problem since your hardware(laptop) didn't respond when you turn it on. Are you running on battery mode or AC mode? if you're on battery mode try to check your battery it may be fully drained. Try to switch to AC mode by plugging into your AC adaptor/battery charger and see if it works.
Regards!
Jul 17, 2009 | Computers & Internet
HP Pavilion dv9000t display works only in VGA when on AC
After analysis your issue with display, it's seems your laptop's display card gets corrupted or faulty....
so request you visit at HP service centre and ask him for resolution.
Thanks
Sushant
Jul 06, 2009 | Computers & Internet
Toshiba laptop reboots when on AC Power
I have the same problem with my Toshiba too, prima facie, it looks like Toshiba and Vista don't make a good combo. I suspected this to be a pure hardware problem, but was disproven when I booted in safe mode. It does not have any problems with the AC Power on in Safe mode.
Jan 12, 2009 | ASUS G1S-A1 Notebook
Laptop wont run on battery!
ok it looks like your battery has run out of power thats why it would not run when ac is off.If it so happens that the laptop runs when battery is connected to ac then battery seems fine by me just flat. Conenect them to ac and run your pc,go to your control panell and power saving options and set to mimimum usage/power saving mode in this way you charge your battery.Remember bright screen consumes more power
Apr 24, 2007 | Acer Aspire 5670 Notebook
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
