Carrier ac unit model 38ycb030300 does the top fan blow in the ac or up and out of the ac unit
2 Suggested Answers
  • 306 Answers
SOURCE: Tonnage of my Carrier AC Unit
3 1/2 ton unit the 042 tells me.
Posted on Dec 11, 2008
My(38ycc030340)carrier heat Pump ac unit blows 5 amp fuse on board in handler in attic when switch stat to heat.
Miss wired or shorted low voltage wiring. Have you changed stat? Animal chewed wires at foundation wall or in attic?
Oct 10, 2016 | Carrier Heating & Cooling
Display F3 on carrier Ac what problem
Well without a model number, I can tell you this. On some models, F3 indicates fan speed 3, which is high speed.If you push the mode button, these units will switch between f1, f2, f3 and smart fan. No problem.
On others, F3 indicates a fan speed error, either something is keeping the fan from turning, or there is a bad or loose connection somewhere.
On still other models, F3 indicates a freon leak or problem in the refrigerant circuit.
If carrier made their own units, they would probably act the same, but they don't. Model number is important, since the unit could be a daikin, LG or Samsung under the skin...
Nov 29, 2014 | Carrier Heating & Cooling
Why is one 30 AMP fuse pair blowing on Carrier Tech 2000 SS AC Unit?
Pull off one of the wires to the fan. If it still blows a fuse the compressor is shorted. If not replace the fan motor.
Jul 03, 2014 | Carrier Heating & Cooling
Carrier air conditioner isn't cooling the house. It is blowing air, but it doesn't seem to be cool air.
Check the outdoor unit to see if it is discharging hot air out of the top ofd the unit, check the insulated suction line to make sure it is cold or sweating. Try to listen to the outdoor fan and the compressor to make sure they are both operating
Jun 24, 2010 | Carrier 38CKC036 Air Conditioner
My Carrier Home AC unit stopped blowing cold air today. I opened it up and cleaned everything and didn't notice anything out of place, any ideas?
This could be complicated to resolve over the internet but I'll give it a try. When you stated that it stoped blowing cold air, did it stop blowing air all together? Also is the outside unit rtunning?
Sep 05, 2009 | Carrier 38CKC042 Air Conditioner
Ac sytem blows strong air but its warm
If the compressor and fan work in the outside unit, and the fan inside (air handler) works, probably the system is low in refrigerant which means there's a leak that has to be fixed and then recharge the unit.
Sep 04, 2009 | Carrier 38CKC030 Air Conditioner
I think my compressor unit outside needs to be recharged, everything else looks good but I can't get it to blow cold air.
if the compressor itself is running and that means the compressor not just the fan on top. It may need a recharge, only hooking up guages and reading pressures vs temp can tell you for sure call a reputable ac service.
Jun 04, 2009 | Carrier Heating & Cooling
My Carrier AC fan will not turn, only blows out warm air.
Breaker has popped either at breaker box or at the safety shut off switch. Fuses are blown or the sending unit has popped.
Apr 30, 2009 | Carrier BCA101R Air Conditioner
BDP furnace + model 585A030080YACR
Sounds like your indoor fan motor is not working, check either the cap or the indoor fan motor it's self.
Jun 26, 2008 | Carrier Heating & Cooling
Carrier Weather Maker not blowing anything
if you turn on just the fan at thermostat does it run.
if not then the fan motor / belt / relay / start capacitor is the issue.
if your not familiar with ac then you will need help to diagnose the air handler.
belt is easy.
just take a look by opening the side access panel
Jun 04, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
