Question about Indesit Washing Machines
Ceramic heater Err 22 Indesit TK 64-S
My green led is flashing twice on my sterling tf250 furnace and it not firing up. I was wondering if theirs a trouble shooting guide for these heaters that might help me out?
Yes... 2 flashes... An ignition failure... (page 22)
Most commonly a cracked ceramic IGNITION element...
(less likely low or no gas... still less likely... wires open).
Try removing power and restoring.
Listen for the pilot valve to operate...
located in bottom RIGHT of fan side.
documents
http://homeappliance.manualsonline.com/manuals/mfg/sterling_1/tf250.html
Feb 10, 2016 | Sterling Heating & Cooling
Tip
How to bypass firewall blocking of specific sites (e.g. Facebook.com)
So, you cannot enter
The access to these sites is BLOCKED by firewall settings.
In order to gain access, the administrator of the PC or network has to remove the RULE from firewall(s) that deny access to these sites.
If above is not possible (e.g. in case it was made on purpose by the administrator, e.t.c.) you can try to connect to facebook through proxies that can bypass your firewall.
Actually, by using a proxy url to access e.g. facebook you can "fool" the firewall ! Take into account that some proxies might be forbidden as well! (So try another one from the list)
Below you can see some of these proxies. Just go there, type www.facebook.com (or www.youtube.com) in the URL and press go. Whala!!!
http://cloakme.tk
http://cloakninja.tk
http://facoxy.com
http://ktunnel1.tk
http://ktunnel2.tk
http://ktunnel3.tk
http://ktunnel4.tk
http://midhat.com
http://ninja-cloak.tk
http://ninjaoxy.tk
http://ninjaproxy1.tk
http://ninjaproxyarea.tk
http://proxyninja.tk
http://subick.com
http://vcloak.tk
http://vroxy.com
http://vroxy.tk
http://www.airproxy.tk
http://www.bypass-facebook.tk
http://www.covertbrowser.info
http://www.facesaver.net
http://www.fastninjaproxy.tk
http://www.freeninjaproxy.tk
http://www.getonfacebookatschool.tk
http://www.greathide.com
http://www.onesneak.com
http://www.proxican.com
http://www.proxybear.com
http://www.proxybooth.com
http://www.proxyspirit.com
http://www.proxyviper.com
http://www.pruxu.info
http://www.trixu.info
http://www.unblockmyspace.com
http://www.viperproxy.com
http://www.yoursly.com
http://www.yoursneak.com
on Aug 05, 2011 | Computers & Internet
What does err message mean
This means the internal diagnostic in your appliance have found a faulty in its operation. It may be a generalized code that is non-specific or it may be be accompanied by a number or series of flashes or beeps that tell a service tech what system has been effected. This being a heater my guess is it is a safety issue that prevents the unit from turning on.
Jun 21, 2015 | De'Longhi TCH7090ER Ceramic Tower Heater
I'm searching for a Honeywell HZ365 ceramic compact heater to purchase
this one is similar...
http://www.amazon.com/Honeywell-50250-S-99-97%25-Round-Purifier/dp/B00007E7RY/ref=sr_1_fkmr0_1?ie=UTF8&qid=1354484907&sr=8-1-fkmr0&keywords=Honeywell+HZ365
Dec 02, 2012 | Honeywell HZ365 Ceramic Compact Heater
I cannot clear an error message #2 on the screen and it has locked up my printer.
do you mean error code E002-000?
If thats the case, follow the procedure:
press*
press2
press8
press*
select COPIER
select FUNCTION
select CLEAR
select ERR
select OK
turn off and on
If these doesnt resett your machine, you need to change fixing heater ceramics.
Hope that helps!
Aug 28, 2010 | Canon 3045 Black and White Copier
How do I program extra departments into a Casio TK - T200. I need 22 Dept Keys
The TK-T200 comes with 30 Flat PLU buttons. These can be set to open price if you want to use them as departments. To remove the fixed price, Turn key to program mode 0 now press the PLU button you want to change SUBTOTAL
Now you will need to enter a price (no decimal point) each time you use it in REG mode.
If this is not suitable, please let me know more information about your needs.
If anyone needs a manual for a Casio TK-T200 cash register,
http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-T200_users_and_programming_manual.html
http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-T200_service_manual.html
Aug 04, 2010 | Casio Parts Cash Register PC Desktop
Canon Image Class D860 - Error message E003. How do we correct?
Under service mode ( MENU and # ) find CLEAR, and select ERR ( if you cant find err, select ALL ), and OK.
Restart machine.
If that does not help change the whole fixing assy.
E003 means that you have temperature problems in fixing assy.
If clear does not help, that means that you have bad thermistor or fixing ceramics.
Jun 29, 2010 | Canon imageRUNNER 400S Copier
Can i upgrade my processor from 1.9ghz to 2.8ghz?
According to Acer's website sepcifications, that Laptop is only upgradeable to 2.3GHz:
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=606&formid=3404&website=AcerPanAm.com&siteid=7117&words=all&keywords=&areaid=2
AMD Turion 64 X2 dual-core mobile technology TL-66/TL-64/TL-60/TL-58/TL-56 TL-52 (2x 512 MB L2 cache, 2.30/2.20/2/1.90/1.80/1.60 GHz, 1600 MHz HyperTransport Bus),
AMD Turion 64 mobile technology MK-36/MK-38 (512 KB L2 cache, 2/2.20 GHz,), supporting AMD PowerNow! technology and AMD HyperTransport technology or
AMD Athlon 64 X2 dual-core mobile technology TK-53/TK-55 (2x 256 KB L2 cache, 1.70/1.80 GHz), supporting AMD PowerNow! technology and AMD HyperTransport technology
Apr 17, 2009 | Acer Aspire 4520 Notebook PC
I get lightheaded from the smell/fumes put out by this heater.
if this making you unwell a non ceramic should help , do you get headaches does it feel like you are getting the flu ?
Jan 17, 2009 | Comfort Zone CZ-441 Ceramic Heater
Indesit washing machine w1235
could be the bearings or heater/heater may of lifted or spider sometimes a coin can get trapped
May 20, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
