Does Panasonic TX-37LX80M 32" Widescreen LCD Multi-System HDTV with HDMI come with a safety gear which blocks the lightning from striking the television?
I would like to know whether this type of model offers some tools that stop lightning from damaging the television.
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Please understand, that a lightning will have trillions of volts, when it hit the earth. Do you thing any material or circuit made by a human being can withstand it? All are only mere saying. Not the truth.
Posted on Jul 12, 2013
  • 33 Answers
SOURCE: sharp television and panasonic cinema system with hdmi connection
Ok, here's the deal. You can have sound being putout from hdmi coming from one of those sharp units, but it just depends on how you are connected. If you are using a digital audio output, from the tv, it wont push out the sound the way that it should. You will have to downgrade to using audio composite cables to connect to your external speaker system from the audio ouputs, not the digital audio outputs. Its not designed to push out sound from an hdmi cable. The BEST way to have this setup is to run your sound directly from the cinema to the external audio source(leaving the hdmi cable in the tv).
Posted on Dec 12, 2008
  • 718 Answers
SOURCE: How do I remove the stand from a panasonic tv. model TX - 32LXD70
The stand is held on by four screws. Lay the tv face down on a flat surface. Cover the surface with a blanket first. Use a regular phillips screw driver. (If you have a users manual see page 7)
The screws are the set just above the stand on the back of the set. The stand will then slide out.
Posted on Feb 17, 2009
  • 257 Answers
SOURCE: I have a Samsung 32 inch LCD HD Ready Television
You can go to samsung.com and look for it. If not, let me know I will try to get it and post or send it to you.
Posted on Aug 12, 2009
SOURCE: vizio L32 32 HDTV LCD Television no sound no pitcher
Got sound but no pitcher
Posted on Aug 23, 2010
SOURCE: Sony Bravia EX400 HDTV LCD, after lightning
hello marksrapolai
that problem releted with BA board so replace it then ok
if you know more please call me on +91 9274498896 or mail me
to lgindia.subhash@gmail.com
Posted on Dec 26, 2010
How do you change the hdmi on a Panasonic tv?
HDMI is a signal what do you have going on here?
Oct 04, 2016 | Panasonic Viera TX-32LX70 32 in. LCD TV
I need a firmware for Panasonic TH-L32C20X LCD TV, Software Version: 1140 Can you help me, Thanks.
sounds like you need a technician but try the panason website and support you will need a pc and sd card
http://av.jpn.support.panasonic.com/support/global/cs/tv/download/fw/europe/step3_eu.html
Dec 17, 2015 | Panasonic TH-L32C20X 32 inch Multi-System...
Tv picture flashes off and on
Just check whether the power outlet is ok, by connecting the TV to a different power outlet. If it does not work, this could be a defect due to dry solder/component failure in the PCB. This may need attention by a qualified service technician.
Jul 15, 2012 | Panasonic TC-L32C3 - 32 Widescreen 60Hz...
Sanyo lcd-32k40 features
  • Model: Sanyo 32K40 Multi System LCD TV
  • World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!!
  • World-Wide NTSC M, PAL BG, PAL I, Secam BG, DK/ PAL DK TV tuners
  • 32 inch LCD TV with 3 HDMI inputs and PC input
  • USB input for direct media playback
  • 45,000:1 Dynamic Contrast: While viewing either very bright or very dark scenes, it can be difficult to distinguish main images which blend into the background.
  • Dynamic Contrast dramatically mitigates this problem by adjusting the backlight intensity, providing up to a 4X improvement in contrast.
  • 6.5ms Response Time
  • Widescreen 16 X 9 Format
  • World-wide Dual Voltage 110-240 volts 50-60 hertz
  • HDTV monitor (HDTV tuner required for HD reception)
  • This is a multisystem TV. All Multi System TVs in the market do not have a digital TV tuner: What does this mean?
  • To watch digital channels (ATSC Broadcasting in US and DVBT broadcasting overseas) you need a digital source/tuner like a cable box, digital tuner, satellite service, etc.
  • To get the best quality video on this TV you need a source that has a digital connection like HDMI or component.
  • Wide Screen Mode allows you to watch conventional 4:3 aspect ratio broadcasts in wide screen (16:9) mode.
  • Steady Sound® equalizes volume levels so there is consistent output between programs and commercials.
  • Built-in hidden speakers includes 2 (5W x 2) speakers to deliver dynamic sound.
  • Component Video Input offers the best video quality for DVD (480p and 480i), and digital set-top box (1080p, 1080i, 720p, 480p and 480i) connections.
  • PC Input allows you to connect your PC and display the PC screen on your TV.
  • Surround Sound Audio Effect
Mar 04, 2011 | Sanyo 42 in. LCD TV
Cannot remove input label from Panasonic Viera's screen
Are u using HDMI/1 hook up HD box and signal?The HDMI/1 port still work?Do u use the device in the HDMI/1 port lately dose it work?Replaced the HDMI cable,Unplug the tv about an hour,plug it back in,reset it back to factory setting again.See if this work,not than ur HDMI/1 is shorted.
Mar 23, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
Connect lcd LE10 32'' model to laptop
connect them via HDMI. Audio and video from your laptop will go the TV. You need an HDMI cable for that connection.
cheers!
Jul 11, 2009 | Panasonic Viera TC-32LZ800 32 in. LCD HDTV
Buy Samsung LN32A550 32 in. 1080p LCD HDTV Free shipping Order Today! [Click Here!] Samsung LE32B650T2 32-inch Widescreen Full HD 1080p Samsung LE32B650T2 32-inch Widescreen Full HD 1080p Save On "Buy...
SPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMv
Jul 02, 2009 | Samsung LN32A550 32 in. LCD TV
Lightning strike
Yes there is a fuse, but it is integrated, i.e. a soldered component in the main board. A manufacturers warranty fix would be your best bet or failing that a manufacturers recommended engineer. Please don't use an unqualified person as the main board can be blown if too much heat is applied when changing out the component part.
Oct 12, 2017 | Vizio L32 32 in. LCD HDTV
Lightning affected Lcd tv
Panasonic 32"LCD Mod,TX32LXD70A
Jan 02, 2009 | Panasonic Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
