Question about Jenn-Air JSD2695KES Side by Side Refrigerator
Not cooling Jenn-Air refrigerator Model JSD 2695 KES used since July, 2007, starts slowly warming up yesterday over a 6 hr period though the doors were seldom opened. Rear fan and internal fan continued to operate but it did not seem that the compressor was running. No icing was observed, unit fairly dust free underneath. Transferred out all food, unplugged unit for 5 minutes, plugged in = nothing, turned off power with inside control for 5 minutes, turned back on = still no compressor, though fans continued run. Kept unit on and the next afternoon (approximately 24 hrs later) the fridge begins cooling back down and soon is at 0/34 freezer/refrigerator temps respectively.... Any idea on what would cause this type of random problem?
3 Suggested Answers
rpbuice
  • 161 Answers
SOURCE: kenmore refrigerator compressor clicking
Relay on the compressor bad.
Try unpluging for 30 - 45 min until the compressor has cooled down then plug it back in. If it doesn't start replace the relay. Most service techs carry a universal relay and wiil put the relay on, if it starts, your good to go, if not, then the compressor is bad.
Posted on Dec 17, 2008
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Posted on Jun 12, 2009
I have a Kitchenaid refrigerator model kbra22klss01.
Try turning the=> 8170840 Defrost Timer clockwise slowly. It may be stuck in the defrost lobe and the timer is so weak it cannot turn to get out of defrost,. Sea Breeze
Dec 01, 2013 | Jenn-Air JFC2089HE French Door...
Jenn-air gasket is hot
The refrigerator portion is fed cold air from freezer section to cool it. Check for the freezer fan and/or the damper mechanism that directs air into fridge compartment for proper operation.
Sep 03, 2017 | Jenn-Air Refrigerators
I have a Jenn Air JCD2289AEW side by side refrigerator. The freezer has not been cooling properly for a few days. Now the refrigerator seems to be maybe less cool than it should be. I still get cold air...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | Jenn-Air JCD2389G Side by Side...
Freezer not cold enough to maintain ice and food
  • When your refrigerator isn't cooling your food and drink items, first check that the power cord is plugged into a working electrical outlet. If you recently plugged in the refrigerator for the first time, it will take approximately 8 to 12 hours before the refrigerator is cool. Even though the refrigerator is cool in this time frame, you shouldn't place the refrigerator to a colder setting until the initial cool down stage, which takes 24 hours.
    If the refrigerator has been running for 24 hours, you can adjust the refrigerator to a lower setting. The control panel is located in upper portion of the refrigerator compartment. Press the up arrow button to set the refrigerator to a higher setting, which will decrease the temperature of the refrigerator compartment.
  • Door
  • If the temperature control is correctly set but the refrigerator compartment still does not cool down, check the refrigerator door. First, remove any food or drink items that are preventing the door from fully closing. In addition, make sure all of the drawers are fully closed, as they may keep the door from closing.
    Next, clean off the gasket with warm, soapy water and a sponge. Rinse the soapy water off of the gasket. If the gasket is not clean, it will not create a seal with the refrigerator.
    Another reason the refrigerator is not cooling down may be because the refrigerator door is opened too frequently or left open for a long period of time. Pay attention to your use of the door and try to shorten the amount of time the door is opened.
  • Other Causes
  • Your Jenn-Air refrigerator might not cool down for other reasons. If you have recently added food to the refrigerator, the temperature of the food may have an effect on the temperature of the refrigerator. The temperature in the refrigerator will adjust after the food sits in the unit for an hour or more.
    You may have obstructed the air flow on the inside of the refrigerator with the placement of your food. The rear air grille is located under the crisper drawers. Move any food items away from the rear air grille to increase the air flow through the refrigerator.
  • If those thing above did not solve your problem you better check and replace the relay and compressor and it will be good as new. Thanks
  • Jan 23, 2011 | Jenn-Air JCD2389G Side by Side...
    Jenn-Air JSD 2789 GES Fridge it's run but only cool .Could it be stuck in defrost mode?
    Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
    heatman101
    Oct 25, 2010 | Jenn-Air Refrigerators
    My jenn-air upper freezer is 21 degrees and refrigrator is 55 degrees. I cleaned compressor and coil. Both were dirty. The freezer was warm yesterday but i transfered most of the contence to my outdoor...
    As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
    If your refrigerator is running but warm, then…
    Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
    heatman101
    Aug 29, 2010 | Jenn-Air Refrigerators
    Jenn Air bottom freezer refrigerator not cooling properly,
    This may be your compressor. You'll probably need a hard start kit put ont he compressor if it's not still under warranty. I hope this helps you out!
    Aug 13, 2009 | Jenn-Air JBR2086HES Stainless Steel Bottom...
    Jun 11, 2009 | Jenn-Air JFC2089HE French Door...
    JENN-AIR BLOWS WARM AIR
    hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
    Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
    Jenn air french door refrigerator
    Can you place the unit into Turbo Cool? once it reaches 34 degrees it will reset to 40.
    This can happen if you've recently added a lot of food lately, such as for a party. The energy saving nature of the unit cannot cope with the influx of a lot of food food from the grocery store all at once.
    If that doesn't do it, stick around and someone will be along to help you.
    Kind regards,
    Worldvet
    Jun 02, 2008 | Jenn-Air JFC2089H Bottom Freezer French...
    Jenn-Air JSD2695KES Side by Side Refrigerator Logo
    Top Jenn-Air Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
