Question about Hardware & Accessories
Gardenia aquazoom My Aquazoom Sprinkler has slowed to a trickle. It covers an enormous range normally but struggles to output any water with most of the water gushing from "around" the near and far sprinkle holes instead of from the holes themselves....an internal leak. But how do you open it and fix it? Allen
  • 5,245 Answers
$51 for a $12 sprinkler, that has a $8 water timer that you can buy separately at local box store?
Clean out the filter washer where water hose connects. Soak the sprinkler in white vinegar. Otherwise the unit appears to manufactured so that disassembly and part replacement is not possible... this is typical of all plastic water timers.
Don't buy gardena products since they have no online support, as found offered from companies like Orbit etc.
Always buy sprinkler timers and watering equipment at local store so returns are easy.
When buying online products that offer warranty, check who supports that warranty... because the seller usually offers 90 day exchange and nothing more... and then you have shipping costs to seller.
When buying online products, check if the manufacturer has website that offers support. If replacement parts are needed, ask who will sell those parts when needed a few yeaRs later. For example gardena site shows a link for parts but no parts are offered for sale, nor any parts sheets available, so there is no way to identify parts.
Never expect a plastic water timer to last very long.
Posted on Jul 12, 2013
My sprinkler head is stuck spaying in one spot and I can't figure out how to adjust the range and distance of it.
Sounds like you have a bucket impact sprinkler. These are problematic as they tend to beat themselves into non-operation from the moving parts involved and the impacts. They stop turning for a number of reasons, low water pressure, dirt and debris filling the bucket impeding rotation, plants covering the sprinkler etc. If no debris is found and others continue to work on same zone the water pressure is probably unchanged it may just be tired. I suggest replacing it using a pop-up rotor preferably a Hunter PGP-ADJ or PGJ-ADJ Rotor as rotors have only 1 moving part a gear which is sealed inside the sprinkler making them very dependable.
May 14, 2014 | Orbit Sprinkler System Super-jet 3-inch...
Cold water runs really slow when filling up washer,starts out normal but then goes to just a trickle until filled.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Mar 30, 2011 | Washing Machines
Just had my Kenmore delivered yesterday and the water trickles in! Initially, when I moved it to warm it did come out normally, but then it also slowed to a trickle. Same if I move it to rinse. I called...
There is a wire screen filter in the water hose where it connects to the water supply. It's probably clogged with sediment from the water supply. It usually happens with the cold water only so try hot water and see if it's better.
Feb 05, 2011 | Kenmore 24032\24036 Top Load Washer
When we use the cold water it is just trickling in. I cleaned the water inlet screen for the cold water on the back of the machine but it is still only a trickle. Is there another screen inside the back...
Often there is a screen at the inlet of the hose also...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
I need the various programs for my T14e
Look on your timer it should show A programs or B programs this will allow you to set timer to 2 differnt programs Program A or B so when you set timer for example you might put your grass on A program and your Gardenias on B program and it won't interferre with your water timesor the amount water when you water. So make sure the T14e sprikler controler has a A and a B programs.
Dec 10, 2009 | Garden
Leaks water from housing and moves slow. is their
Hi..my name is Keith..and i dont know of a repair kit but you can get parts for your sprinkler ..online...at.....lrnelsoncorp.stores.yahoo.net..i hope this will help..if not write me back
Jul 03, 2009 | Nelson Sprinkler: Traveling Tractor
Cold water good for a few minutes then slows to a trickle. Shut off for a few hours and cold water good again for a few minutes. Inlets are clear. Is this normal behaviour for a dying valve?
Yes, it will fail soon. it is beat to go ahead a order a new inlet valve assembly asap. the pressure sensors that are housed in the valve assembly are failing.
May 22, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Hardware & Accessories Logo
96 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
