Question about Acer Veriton 6800 PC Desktop
Continuous beep booting - Acer Veriton 6800 PC Desktop
    Brigadier General:
  • Acer Master
  • 3,400 Answers
Http://www.pcmag.com/encyclopedia/term/38515/beep-codes
READ THIS SO YOU GET A UNDERSTANDING OF WHATS PROBLEM ARE.
Posted on Jul 12, 2013
Continuous beeping
You have a faulty key on the keyboard. Replace the keyboard, they are not expensive. Look at ebay for prices.
Feb 06, 2014 | Computers & Internet
Continuous beeps, no display
Usually continuous beeps from an hp means the power supply unit is acting up.It is not switching on the power required for the mobo to boot up. Could also be ram prob but then the beeps tend to have a break b4 repeating. try booting with HDs disconnected. If no result. clean rams teeth with a eraser and try again. If still beeping try another power supply unit. It does not have to be identical similar will do. Once you isolate the cause of the non boot you can decide if you want to do a patch work repair or fix with originals
Oct 31, 2012 | HP Compaq dc5000 PC Desktop
CONTINUOUS BEEP SOUND DURING BOOT
The beep sound is sometimes an indication of the successful boot. But, if the beep is continuous, it usually means a memory problem. I*t could be a failing ram stick or a failing memory cache on the cpu. Try substituting the ram sticks one at a time to eliminate each one.
Aug 02, 2012 | Intel Computers & Internet
I have GA945GCM MOBO. While booting it gives continuous beep. If any keyboard key is pressed it stops. The keyboard spacebar key is not functioning. After boot in windows XP, the keyboard problem (spacebar...
Hi shreepad,
Those sound like you have a bad memory chip DRAM or it may not be seated correctly. The beep code of 1 long beep, also indicates a bad memory chip. If you have two or more, take one out and until you find the one that's bad. Then replace it.
Good Luck
Mark
Nov 24, 2009 | Gigabyte GA-945GCMX-S2 Motherboard
I am getting three short beeps while booting
The beep codes below may help you identify the possible computer problems. However,
they are only for reference purposes. The situations might differ from case to case.
gAMI BIOS Beep Codes
*Computer gives 1 short beep when system boots successfully.
*Except for beep code 8, these codes are always fatal.
1 beep Refresh failure
2 beeps Parity error
3 beeps Base 64K memory failure
4 beeps Timer not operational
5 beeps Processor error
6 beeps 8042 - gate A20 failure
7 beeps Processor exception interrupt error
8 beeps Display memory read/write failure
9 beeps ROM checksum error
10 beeps CMOS shutdown register read/write error
11 beeps Cache memory bad
g AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Nov 03, 2009 | Gigabyte GA-7VKML Motherboard
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
Beeping before booting
probably the RAM. Take it out and put it back in to check. You will need some RAM to boot, so try each stick separately if you can. I'm guessing though that you'll have to get at least one other stick of RAM to check. You'll probably find that one is bad. It's probably covered for life, but that would be a good reason to upgrade it.
Nov 19, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Acer Veriton 6800 PC Desktop Logo
173 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
