Question about JVC GR-PD1 Mini DV Digital Camcorder
Capturing GR-PD1 Hi-Res clips in Final Cut Pro 6
I have footage recorded (unintentionally!) in the camera's Hi-Res mode 25 frames per second (25fps) but the audio - if I understand the issue correctly - is captured at 50fps. When the footage is played back on the camera this is not a problem because the 'magic in the box' syncs sound and vision (again, from my understading of the manual) by playing both at 50fps. However, when I capture the footage to Final Cut Pro (FCP) chaos ensues! The video plays back at twice normal speed and, obviously, video/audio sync is completely scuppered. I can solve the video play-back problem by simply reducing the playback speed 50% (which effectively doubles the length of the video track) and then sync the audio. The problem is that I have, say, 30 seconds of video but only the first 15 seconds of audio! I've tried capturing the footage on a PC using the MPEG capture utility and audio converter and this works fine but leaves me with a ".m2t" file which, after I transfer it to the MAC, is not recognised by FCP. I have also tried converting the .m2t to DV format using DVDROP (dvdrop also knocks it out in NTSC not PAL so it isn't really ideal even if it did work!) the .m2t file that goes in synced comes out unsynced. Frankly, this problem is driving me bonkers and I cannot see another way round it. Is there a solution? Regards Bowjey.
I have a similar problem, i - by mistake - shot some footage in ps 50 mode. Now i can capture it in my mac by playing it analog, and than capture it. This seems to work fine only.... date and time keeps showing in the footage and that's not what i want cause that makes the footage totally useless.
Problem is, i don't have a manual i can't seem to figure out how to 'not display' date and time of the recording. Does anyone have a suggestion or maybe an english pdf manual you can send me? Any help would be higly appreciated. ([email protected])
Regards
Ton
Posted on Nov 03, 2007
Check out: http://jvcgr-pd1.blogspot.com/2005/07/dealing-with-pd1s-format-m2t-or-mpeg-2.html Use MPEG Streamclip to convert m2t to a useable file (MPEG).
Posted on Sep 06, 2007
SOURCE:
When I capture HDV footage from my XH A1 to Final Cut Pro 5, the footage is out of sync. The video is playing like in 110%, or something like that. The original footage is in 24f mode. It doesnt happen in...
Make sure the properties for the project you start after the ingest match the frame rate you used to record. Reads like 29.97 speed setting looking at images recorded at 24f.
Jan 01, 2009 | Canon XH A1 Mini DV Digital Camcorder
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Any movement recorded in HD mode is not clear.
HD mode images may appear to move somewhat stiffly compared with SD mode or DV mode images. This is because they are shot at a rate of 30 frames per second compared with the 60 frames per second for the SD or DV mode images. The movie is shot at 24 frames per second, and looks good. So HD mode can have the same feel as a movie material. For smooth movement during video clips, we recommend you minimize rapid-panning or avoid shooting fast-moving subjects. Should you wish to record more natural motion in the picture, we recommend setting a slower shutter speed, or changing the recording mode to SD or DV.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Open Questions:
JVC GR-PD1 Mini DV Digital Camcorder Logo
260 people viewed this question
Top JVC Video Cameras Experts
Ekse
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
