E3d320vx vizio tv IR not responding remote IR
SOURCE: code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Posted on Dec 23, 2008
  • 139 Answers
SOURCE: Vizio VW32L HDTV10A stopped responding with Vizio
Change the batteries in your remote. If your cat was laying on a button it could have drained them.
Here's tip - you can use your camera on your cell phone to see the IR signal coming out of your remote. Point the remote at your cam and press "On" or any button. You should see a bright flash with every key stroke.
Posted on Mar 06, 2009
  • 4 Answers
Unfortunately, those remotes only take a 3 digit code. I bought 2 new remotes, which do take 4 digit codes, but the code(s) for the Vizio do not work (or partially). I found that the 4 digit codes for the Goldstar and LG work better than those provided for the Vizio, but still not as good as the original Vizio remote.
Posted on Apr 01, 2009
SOURCE: How do I replace the IR remote sensor on my LG TV?
My LG TV stopped responding to the remote. A very helpful repair technician told me to stick a head phone jack in the sensor jack on the back of the TV a few times to clean out the contacts. Now the remote control works fine.
Posted on Nov 11, 2009
welcomejee
  • 10594 Answers
SOURCE: Philips 47PFL3603D LCD TV -
There could be many reasons like IR pins not soldered properly, it is not getting +B supply or IR output signal is blocked, buffer transistor on same board is bad etc etc
Replacement IR Board is available for $6 at Encompass.com so I would suggest to replace complete board instead of IR Sensor.
Hope these info will help you.
Thanks.
Posted on Jan 05, 2011
How do I activate w/E3D320VX Smart TV?
[PDF]e3D420VX - VIZIO
cdn.vizio.com/documents/downloads/.../E3D320VX/UM_E3D320VX.pd...
E3D320VX. // E3D420VX ... Your TV is equipped with a three-pronged grounded plug ...... The first time you turn on the TV, the Setup App will guide you through ...
How to control a TV with your smartphone - FlatpanelsHD
Nov 19, 2015 | Televison & Video
Vizio tv remote not responding
possibly bad batteries in the transmitter. could also be a blocked IR receiver at the TV(do you have something in front of the IR receiver in the TV?) last resort could be either IR receiver PCB or the MAIN PCB.
Mar 03, 2015 | Vizio VW42LF 42 in. LCD HDTV
My vizio remote works but the tv doesn't respond. I replaced the remote anyway but it still doe not work. resetting tv doen't work what is next?
It is possible the remotes are either bad or not compatible to the tv. Recheck the remote type and the batteries to see it that helps.
Feb 21, 2015 | Vizio L32 32 in. LCD HDTV
My tv [vizio vf550m] won't respond to a remote.
Vizio is famous for having main board issues. If you have replaced the IR board the only two other items it could be is a broken wire from the IR to main or the main board has an issue. Nothing else can stop the remote from working provided the remote is working properly.
Nov 02, 2012 | Vizio VF550M 55 in. LCD HDTV
Vizio m470sv remote stopped working, bought a vizio replacement remote...still no good????
What you are dealing with is not a bad remote controller, the problem is from your IR Sensor. You will need to replace this IR Sensor. You Vizio TV has a common defect with the IR Sensor. Make sure you order the revised version so you don't encounter this problem again. You can find the IR Sensor here: 3637 0022 0189 0171 1671 0892 Vizio IR Sensor
Oct 28, 2012 | Vizio VO Televison & Video
Vizio vl370m remote control
If remotes have been ruled out the only way to test the remote infrared receiver is with the set apart/ and a schematic measure voltage at the receiver when the remote is used---most of the time since the part is rather small this is just replaced to see if it is or is not the problem; some receivers will fail where if the remote is held very close they work--always the receiver in that case.
Apr 12, 2012 | Vizio VL370M LCD TV
Just bought a vizio tv Model #E470VLE, my dish remote will not control the mute or volume buttons now, how do I get it to do that?
Hey there, Cheri Torres with DISH Network Customer Service here. It sounds like you are going to need to readdress your DISH remote to your new Vizio TV. We have a few different codes for each of our different models of remotes. You will be able to locate the model number of your remote on the back of the remote at the top usually a two to three digit number with a decimal point. I will list here for you the best codes for Vizio TVs as well as the instructions for addressing the remote to your TV. I hope you find this information useful and if you have any further questions or concerns feel free to email directly at Cheri.Torres@Dishnetwork.com.
Codes for Vizio TVs
3.0, 3.1, 3.2, 3.4 IR remotes - 505, 671, 627 and 766.
5.0, 5.2, 5.3, 5.4 IR remotes - 627, 505, 506, 457, 111 and 520
4.0 and 4.4 IR/UHF remotes - 505, 627, 555 and 766
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - 627, 505, 678, 825, 520 and 766
20.0 IR and 21.0 IR/UHF remotes - 505, 598, 627 and 773
Instructions for addressing your remote to your TV.
  1. Turn the Television On.
  2. Press and hold the TV mode button until all other mode buttons light up red.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound(#) button once. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
May 22, 2011 | DISH Network IR Remote Control
Remote stopped working Got new remote and it
It can be the IR remote receiver board inside the TV. Is the new remote setup for VIZIO TV?
Old VIZIO remote is bad for sure?
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
Dec 03, 2010 | Vizio L32 32 in. LCD HDTV
Mar 06, 2009 | Vizio VW32L 32 in. LCD HDTV
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Electro Med Services...
