E3d320vx vizio tv IR not responding remote IR
I just replaced the remote that came with it (brand new remote same model #) but it still doesn't work. Batteries are new as well. I've only had the TV for a little over a year. Other people have had the same issue with the original remote malfunctioning but the replacement works perfect for them. Please assist. THANKS!
dnewcombe1
  • 1564 Answers
SOURCE: remote control not working on brand new series 4 42 inch samsung
Make sure the remote is set to operate your tv and not a cable box or accesory. It's in the menu
Posted on Jul 24, 2009
budmrtn
  • 11361 Answers
SOURCE: samsung 5 series 40 remote not working
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera’s Lens (Digital Camera can detect IR), you should see flashing light on the camera’s screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
Posted on Jul 17, 2010
welcomejee
  • 10594 Answers
SOURCE: Philips 47PFL3603D LCD TV -
There could be many reasons like IR pins not soldered properly, it is not getting +B supply or IR output signal is blocked, buffer transistor on same board is bad etc etc
Replacement IR Board is available for $6 at Encompass.com so I would suggest to replace complete board instead of IR Sensor.
Hope these info will help you.
Thanks.
Posted on Jan 05, 2011
walesarumi
  • 6993 Answers
SOURCE: The TV will not respond to the remote and
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
You need to do some diagnosis to confirm the source of the problem.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Regards.
Posted on Nov 28, 2011
gopakumarg43
  • 74383 Answers
SOURCE: T.V. remote sensor not working
Hello
If you are sure that the fault is with the remote sensor of your TV, replace it with a new one. The remote sensor can be located just behind the remote sensor window at the front panel of the TV. You nave to open the TV to access it. It is a three solder terminal component. It will look somewhat like this, having brownish black in colour. This component can be bought from most of the electronic spare part selling shopw at your town; very cheap to buy too. OK
How do I activate w/E3D320VX Smart TV?
[PDF]e3D420VX - VIZIO
cdn.vizio.com/documents/downloads/.../E3D320VX/UM_E3D320VX.pd...
E3D320VX. // E3D420VX ... Your TV is equipped with a three-pronged grounded plug ...... The first time you turn on the TV, the Setup App will guide you through ...
How to control a TV with your smartphone - FlatpanelsHD
Nov 19, 2015 | Televison & Video
Vizio tv remote not responding
possibly bad batteries in the transmitter. could also be a blocked IR receiver at the TV(do you have something in front of the IR receiver in the TV?) last resort could be either IR receiver PCB or the MAIN PCB.
Mar 03, 2015 | Vizio VW42LF 42 in. LCD HDTV
Vizio sound bar code
034,028,075,018,072. Check these codes. If you wish to get more codes to different other brand remote controls, check this link. Code list and setup proceedings to some popular model remote controls are given in detail.
Feb 26, 2013 | DISH Network IR Remote Control
My Vizio tv , model number e3d320vx. The back light, power light , and Vizio symbol come on but that's it . Won't do anymore .
Eprom failure most likley so the main board will need to be replaced. I would send a email to customerservice@tvrepairworld.com to see if they have the replacement main board for your model they should have it available.
Jan 02, 2013 | Televison & Video
RCA flatscreen remote doesn't work
\its most likely the ir sensor which has the issue. I will need the model number of your set to help you further on the issue. You can reply to this same post for further assistance if needed.
Jan 01, 2013 | Televison & Video
My tv [vizio vf550m] won't respond to a remote.
Vizio is famous for having main board issues. If you have replaced the IR board the only two other items it could be is a broken wire from the IR to main or the main board has an issue. Nothing else can stop the remote from working provided the remote is working properly.
Nov 02, 2012 | Vizio VF550M 55 in. LCD HDTV
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
Vizio TV. Can't get out of PHOTO mode. I have no remote. Side MENU button doesn't respond when in PHOTO mode. Need to Hard Reset... How can I?
^_^ Those answers are only for new remote but that's not the only way, There trying to ask in another way with out a remote.
Jan 16, 2012 | Vizio VA26L 26 in. LCD HDTV
My tv control doesn't work and i put new battery's in and that didn't work either
There's a quick test you can do to test the functionality of the remote to make sure it isn't the TV's IR sensor that's broken. To perform the test all you need is the remote and a digital camera (cell phone cam works too). Take the remote and look at the IR "eye" through the camera's screen. Don't actually take a picture simply use the camera as you would a magnifying glass. While looking at the IR eye press a few buttons on the remote. If the remote is working you should see light coming out of the remote. Our eyes cant see the IR light but the camera can. If the remote doesn't light up then the remote is at fault. You can replace your remote on many websites for somewhere in the 20 - 50 dollar range.
http://www.replacementremotes.com/
Here for example, you need to input your TV model number and it will tell you what remote you need with pictures. Then, once you are sure that is the remote you want, you can order right from the same website.
Hope that helps!
Jul 19, 2011 | Televison & Video
Televison & Video Logo
262 people viewed this question
Top Televison & Video Experts
Electro Med Services...
