Hi Everybody , I am having a CD RW in my home , Its not ejecting , untill we are using the Emergency hole to eject
But i openind the cover and checked inside , It was worked but if i fix the cover properly means its not working
Is there anybody have idea to what to do with this
I checked the cover also , No damage or nothinbg in that , I feel that its uncomfortable to seat on drive
The only thing that can be done is to go to my compter, right click>properties>hardware tab>device manager and look for cd/dvd drives, click the + sign and when your drive appears, right click on it select uninstall, then restart the pc and it will reinstall itself again.
If you still find that it wont eject, either the firmware or the mechanism is at fault and only replacing the drive will be the solution as they are only very cheap to replace and very easy to fit.
Hi, the disc drive has an emergency eject hole on the front. With the laptop switched off, insert a paper-clip (or similar thin object) into the hole until the cd pops out. This is number 4 in the picture below:
Use a pin and insert in the emergency eject hole (usually in the center below the tray) and then you can eject the drive tray with force. It is time you planned for a new drive.
Untill then please insert a music CD into the drive tray and leave it there, this will ensure the eject will work (most of the time). Booting time will definitely increase if the drive has issues, reading or responding.
Is the cd/dvd? Look carefully on the front, you'll see a tiny hole just below the Tray (usually beside or above the eject button), take a straightened paper clip or a long needle and push inside the hole while you press the eject button, push it inside until it ejects out.
try tu eject it once by using a needle from emergency eject hole.if again it couldnt bring it automatically by eject button,it is related to the inside lever motor...
you can do an 'emergency eject' by sticking a paper clip into the tiny hole just underneath the tray by the eject button - this should release the tray
Hi! My reply is a bit late, but if you still have the same problem this may help.
You can force your DVD rom to eject a disc by poking a paper clip into the small hole near the eject button. Insert a paperclip into the hole for a few seconds (perhaps 10 to 30 sec). You may need to repeat the process several times until it ejects the disc. In case you are wondering where is this little hole - it's on the left side of the eject button.
did you try to do the emergency eject ?
jewellers driver in drive pinhole.
use the eject method again, Computer powered Off. Open the drawer and push it back in firmly.
This is an eject button, make/break switch problem.
Also try ejecting the drive from my computer/Right click with mouse ( CD Drive ) Eject.
And ensure the 4 Pin Molex ( Red-Black-Black-Yellow ) is the right way round. Yellow usually faces to the outside of the casing.
