Griffin itrip wiring diagram
I have an itrip where the dock connector was located now only has four wires...they are green, orange, red, and blue. in regard to the four wires that come out of a standard ipod usb cable, red, black, green, and white. how should they connect to the itrip? i found the wiring diagram for a standard ipod usb cable but not for an itrip auto 2006. can anyone help me out?
3 Suggested Answers
campbellbs
SOURCE: I need a wiring diagram for my iTrip. The wires
@dpettus88
I had the same problem. The plastic harness around the connector broke after I had the iTrip for only a few months. It finally quit working recently. I was amazed to see how cheaply made this somewhat expensive item was when I finally took it apart. Anyways, here is what I came up with. There\'s a bit of whine in the signal, which I believe is because my soldering on the yellow and brown wires left a little to be desired. But, as I said, this configuration did actually work. Will post results of cleaning up the connection on those two pads.
Posted on Feb 12, 2011
  • 35 Answers
SOURCE: USB connector cable which pair
abbey tuuney usb ko kya audio video wire samjha hai kya jo tv k picchu lagao aur tv chal padi no its wrong yaar usb it means universal serial bus iss mai device kai tarah k electronic signal bhejta hai which is converted by the device as it needs
Posted on Jun 21, 2011
I trip wire broken
I noticed that no 1 spoke of the wires that you were requesting so what I found out from the board self for the a iTrip work comes up the little LCD display if you pop it open it tells you what each 1 of those wires are for the red and black obviously are power and ground. Green is Right side, brown is ground (or S on Griffin's board), yellow is Left Side, purple goes to 'I', blue to 'X', white is 'T'. I'm only guessing for the x,t,&I but i maybe the interaction from connector to LCD x is receive and the is transmit. Not really sure on it so don't quote me on that. But that's about far as I can help with. Since I'm converting mine from iPod connector to regular headphone jack to use on my android
May 16, 2012 | Griffin Technology iTrip Auto with...
There are 3 wires on the itrip and i need to repair the car socket which one's goes to which soder points
if these are your letters on the board
this is with the car socket to your right
A Green
S Yellow
LR Brown or Orange
LG Blue
G Black
V Red
My problem is the other side need white blue and purple
Aug 17, 2011 | Griffin Technology - iTrip Auto Dock...
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
I need a wiring diagram for my iTrip. The wires broke off at the plug that goes into the iPod. I'm not sure which wire,( green, orange or red ) is the ground wire. Trying to fix it myself. Thanks for any...
@dpettus88
Dec 09, 2010 | Griffin Technology iTrip Auto with...
The wires on the cig lighter side of my iTrip auto 2008 pulled out and I want to solder them back in but I need to see which color wire goes where...? I can do the soldering fine but I want to make sure I...
my itrip is a little different but im pretty sure they layout would be the same. but on mine (2010).on the botton side..
A= Blue wire
S= n/a
LR=n/a
LG=Purple wire
V=Green wire
Other side (Left Side)
R=Orange
S=Green
L=Red
Sep 07, 2010 | Griffin Technology iTrip Auto Universal...
Wires came loose of control unit from circuit board do you know what order they should be soldered back green white and yellow wires are still connected but I don't know where/which terminal to...
maybe we can help each other out with the questioni have my white black and red still connected but the purple blue yellow green and brown cables are un soldered if u look at the transmitter with the buttons on the bottom and the screen at the top the wires should be on your right there should be nine spots strating from the bottom to upward skip 1 next one should be white then skip one next should be red then next one is black and then thats all i have hope we can help each other
May 15, 2010 | Griffin Technology Griffin iTrip AutoPilot...
Wires came loose of control unit from circuit board do you know what order they should be soldered back Green, white and yellow wires are still connected but I don't know where/which terminal to...
Rotate the iTrip AutoPilot FM Transmitter controller so that its buttons are facing up and its data cable is on the left side. The data cable wires attach to a row of contact points along the left side of the circuit board as follows (from top to bottom):
1 = Purple
2 = White
3 = Blue
4 = Red
5 = Black
6 = Brown
7 = Green
8 = Yellow
9 = <unused>
Mar 27, 2010 | Griffin Technology Griffin iTrip AutoPilot...
1994 FORD EXPLOER XLT RADIO CONNECTORS HAVE BEEN CUT OFF
here is wire color diagram.
1994 Ford Explorer Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Light Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: Light Blue/Red
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Blue
Car Stereo Amplifier Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Pink/Light Green
Left Rear Speaker Positive Wire (+): Pink/Light Green
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Mar 29, 2009 | 1994 Ford Explorer Limited
21 people viewed this question
 Grubhead
Grubhead
