Question about Air Purifiers
Wires cut need help - Air Purifiers
  • David Ogawa May 10, 2014
    would like to help you, but I need more information. Could you please provide the model number and describe more about the cut wires?
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 21 Answers
Hi what you do is:open casing to get some teftover of the wire'ing then take a wire that you had cut off an appliance that somebody threw out and splice them to connect them
Posted on Jun 18, 2014
TRYING TO FIND REPLACEMENT PARTS FOR A SHARPER IMAGE HYBRID GP GERMICIDAL AIR PURIFIER MODEL SI724 NEED THE WIRES AND BEADS TO REPLACE SOME BROKEN ONES
I have 2 of these air purifiers and I love them. I came to this site looking for a resolution because 1 of them stopped working properly. After running for about 30 seconds, the red light would come on. I had cut out 1 wire that was broken and thought that was the problem. There were sparks when it was turned on. After reading a couple answers here, I took a closer look and noticed that a second wire was also broken at the bottom. I just cut the second broken wire off the top and removed it and the purifier works great now. No more sparks!
Aug 16, 2012 | Sharper Image Hybrid GP (SI724) Air...
Where can I get replacement wires for an oreck truman cell? Seems silly to spend 200 dollars when the only thing wrong is four 29 cent wires does it not?
Here is a link to where you may can find what you need. You will need to have the correct model number (not just XL Tower Air Purifier) , to find your mode.
http://www.ereplacementparts.com/oreck-air-purifier-parts-c-130239_130321.html
Hope this helps you find the wiring you need. Thanks for choosing FixYa.
Sep 19, 2011 | Oreck XL® Tower Air Purifier
I HAVE 2 IONIC BREEZE QUADRA. FIRST HAD PROBLEM WITH 1, NOW THE SECOND ONE HAS SAME PROBLEM. HAVE CLEANED AND DRIED THOROUGHLY THE BARS AND FILTER, AND CLEANED REST OF WIRES WITH BRUSH. WHEN I TURN ON I...
If none of the hi voltage grid wires have broken then check to be sure grid wires are truly cleaned.
If not cleaned in a while like every 2 weeks they will have carbon build on them. And from my experiences with cleaning them is the build looks similar to the color of the wire. Try some qtips dipped in alcohol or cotton balls. The build comes off like flaking metal. Also be very tender with these wires they break fairly easy. When done cleaning turn upside down and back so beads can scrape up and down on wires. Also you do know once clean the parts especially the big collection bars they need to dry for at leased 24 hours before ever powering unit back on. Hope this helps.
Dec 13, 2010 | Sharper Image Ionic Breeze® Quadra® 4.0...
The guide wire(s) inside my ionic breeze bathroom air freshener (model S1717) broke. How can I replace these wires?
either cut and strip wires and wirenut them back together or order another harness i suggest the first option
Feb 23, 2010 | Sharper Image Ionic Breeze Air Freshener...
Fan blade barely rotates when turned on high.
there may be a problem with fan motor,but i believe your problem may be the rotory switch that controlls voltage to fan motor,to check this pull knobs off front ,then remove filter from back,there are 4 screws in bottom of case remove these,pull unit out carefully .there are 5 wires conected to unit ,two for fan 2 for on off switch,1 for ground just what wires go were,then disconnect wires from there posts,and pull unit out of box,find the two wires that go fan,snip wires that go to the circiut board leaving enough space to rewire after test get extention cord and snip off to make direct plug to fan to wall connect extention to the two wires from the fan motor and wire nut or tape so no short,pug extention cord into wall outlet if fan runs on a high rpm or max power,then your rotory switch is no good and you can install an external rotory switch on side of unit,if fan does not run any faster then your fan motor needs replaced,let me no if you need more help
Dec 03, 2009 | Ecoquest Living Air Classic Air Purifier
I have a professional series ionic breeze gp. It stopped working and has a red light on-something I had never seen before. Can you help with this model?
Well there is a small micro switch that is actuated by the grid. This is mounted on the side of the top control piece. There are two wires attached to the little circuit board, usually one is corroded so you need to cut it back and soder it to the center pin of the switch. also check the fuse.
Good Luck!!
Thanks
Sep 20, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Can you use honeywell 12k btu air con in a room with no windows
you can, however the heat from the condenser will recirculate back into the evaporator, you need a place to discharge the hot air, and also the drainage from the condensate. I have cut holes in walls to the outside of the room in many applications with no windows, and they work fine. Just a matter of if you have an outside wall, and how much troble it is to cut the hole, frame the inside of the hole out, get power to the unit and secure the unit in the hole. Hope this helps...
Aug 15, 2009 | Air Purifiers
Sharper Image Hybrid GP Germicidal Air Purifier SI724 NO POWER
Oh there are a lot of known issues! I used to work for sharper image and I believed in this items very much so until mine broke. However after a year I figured out how to fix it. Take the big square collection grid out and the back screen off. Now get you a thick rag and be very careful because there are several tiny wires going up and down. Smaller than dental floss, you need to be very careful because you can either brake them or slice your finger wide open( Under any circumstances I can not be held liable for the information I am giving you try this at your own risk). Now with the towel very gently go up and down each wire like you are polishing a brass pole(once again these wires are thin and can break or cut you). Do this from the back side of the unit and from the inside where the collection grid that you took out sits. Take your time and be thorough, and presto your 400 dollar air cleaner is working again.
Nov 21, 2008 | Sharper Image Professional Plus Ionic...
Ionice breeze quadra Model # S1637
All Sharper Image Ionic Breeze Ionizer have been recalled and are no longer supported
See the Chapter 11 link
See the EPA link as well
Jun 26, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Kenmore ac2044-1 shuts off
Take Cell out and examine closely with flashlight for debris and bent aluminum cell plates or ionizing wires.
Make sure all plates are more or less clear of one an other with fairly even spacing between them and no kinks on their edges.
If any are to close together it will cause a cell overload that will cause the Clean Cell to display and or completely turn unit off all together.
Mar 28, 2008 | Kenmore AC2044-1 Air Purifier
Air Purifiers Logo
80 people viewed this question
Top Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an Air Purifier Expert? Answer questions, earn points and help others
