Question about Vehicle Parts & Accessories
Where are washer fluid resivior located - Vehicle Parts & Accessories
    Problem Solver:
  • 11 Answers
What type of car do you have? On most cars, it's on the driver side under the hood, close to the windshield. Most of them are white buckets with a pop off top, which is attached to the bottle. Depending on the type of car.
Posted on Jul 12, 2013
Where does the clutch fluid go in a 1992 tracker
open hood , look to drivers side fire wall look for a small black cap ,it will look like a very small brake fluid resivior
Aug 20, 2014 | 1992 Geo Tracker
What should the power steering fluid resivior be at for a 2002 mini cooper be at
fill it to the second line on the stick and make sure to use only pentosin power steering fluid.
Feb 13, 2013 | 2002 Mini Cooper
Where is the rear window washer resivior located on a 95 jimmy
It's the same reservoir as the front windshield washer. If it's not working, check the washer line to make sure there are no cracks or breaks in it. Good luck and keep me posted.
Feb 22, 2010 | 1995 GMC Jimmy
1998 Ford Explorer Where is the rear windshieldwasher fluid resivior located?
The rear windshield washer fluid for the rear window uses the same as the front. if it is like a '99 Explorer, it has one pump that has reversing current controlled by two relays . Access the relay box by removing air cleaner top and hose near right front corner. The front and rear washer relays are the two near the rear of the box. One of the two is sticking or has corroded terminals. You can use the horn or a/c relay from the relay and fuse box near the battery.Good luck and hope this helps.
Dec 08, 2009 | 1998 Ford Explorer
Wind shield washer fluid stopped working 2005 excursion
Pull resivior and see if it gelled up around screen for pump motor.Cheaper washer solvents tend to do this,If so you can clean screen and it should be ok.Note sometimes you can look down in liquid with flashlight and see gell in resivior.
Jun 19, 2009 | 2005 Ford Excursion
1996 Mitsubishi 3000GT windshield washer will not squirt water!?
Recommend remove nozzel and clean,also recommend remove resivior pump and clean screen,may have solvent jelling up.Very comon when using cheaper solvent.note always use an alchohol base solvent in resivior and make sure water jug is clean.
Jun 16, 2009 | 1996 Mitsubishi 3000GT
Windshield washer quit working
check fuses under dash and in enginge compartment/thenif the fuses are ok then its the pump itself that needs to be replaced/ Please rate my response thank you very much
Jan 15, 2009 | 1996 Eagle Vision
Fluid stopped coming out
with most vehicles not sure with a honda the pump is in the bottom of the washer fluid resivoir.remove resivior and replace pump.
Oct 22, 2008 | 2005 Honda Pilot
Replace Fuel Filter
Just unbolt it on top and bottom and replace (remember to use two wrenches so that you don't break the hard fuel line or the mounting bracket).
The filter is located directly beneath the windshield washer fluid resivior. You will have to remove the washer fluid resivior and possibly the brake fluid resivior as well as they both get in the way.
Disconnect the filter on a surface were it's OK to spill gas on the ground, when you take the hose of it will pour out it's contents.
Oct 11, 2008 | 1998 Mitsubishi Eclipse
Windshield wiper fluid does not spray and how does it turn on?
The washer pump should be in the resivoir bottle...remove the plug on the bottom of the resivior and check it for power when the washer button ie pushed... if you have power, then you should replave the washer motor...
Please rate this,
Rob...
Sep 16, 2008 | 1990 Ford F150
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
