Please help to remove aucum signal - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
What do you mean by this 'aucum' signal? Please provide details.
Posted on Jul 12, 2013
Installing aftermarket turn signals on a Suzuki 1978 gs1000. Windjammer fairing removed so I have no wiring reference for turn signals. Need a wiring diagram, or just a simple explanation. PLEASE help....
Get a test light. Hook clip on - side of battery. Turn on turn signals and ck wires. The light will flash, that is the + wire. If turn signal has only 1 wire hook that to the + wire. The - connection will ground through frame and complete the connection.
Apr 30, 2014 | 1978 Suzuki GS 750 E
I'm trying to hook my DVD player to my tv its a vizio flat screen but I keep getting a Aucum Signal... What do I do
hook your dvd player into video 0ne two or three, there indication is red white and yellow. red for left sound white for right sound and yellow for video. then turn your tv to video output to what ever you attatched your rca cable to either vid 1 2 or 3. the remote should have an input selection, good luck this is easy and if you hook the cables up to the red white and yellow connections either on the side front or back of the tv it will detect it normaly, if not choose it from the remotes selection tab, called input selection. hope this helps.
Nov 12, 2012 | Televison & Video
I wasworking on turn signals thought i had a burnt out light bulb and now i have lost all my unning lights including my head light please help
Hi Roy, always check fuses and bulbs first, you could have a faulty turn signal module or a bad turn signal button/switch, remove it from the switch housing and check for continuity, check your wiring and connections from the turn signal switch to the turn signal module with a testlite. Make sure all wires are not worn or pinched and connector pins are not corroded, broken, or loose. For a free wiring diagram please visit the website below:
Harley Davidson Wiring Diagrams and Schematics
Mar 19, 2012 | 2000 Harley Davidson XL Sportster 883
My cordless phone is not functioning properly.I get consistent disturbance in the background while talking on cordless.Please help me remove this noise.
This can be due to poor meshing of the base and handset , a poor signal strength that tends to pick up stray EMI signals. Make sure that the antennae of the Base phone is tight and up . Check the voltage to the base phone - if adapter is faulty.
Also check the handset for any loose fittings on the antennae.
If the problem does not resolve then you need technical help to check if the operating frequency or the signal processing is weak and faulty on the base unit. Best you can remove base unit and look for any loose links in RF section or shielding faults in this section that picks up stray signals.
Jan 22, 2011 | Audio Players & Recorders
92 buick lesabre, left blinker won't work unless you move it manually. bulbs and fuse are fine. hazards work.
Hi Friend:
Since you've check or Changed your Bulbs and Fuse also Check or Replace your Turn Signal Flasher,Just as a Percation i would Double Check Fuses,Bulbs and Signal flasher.
If these are All showing bad I would say your Signal Switch has Stopped Working.
To Replace the Signal Swith :
1st Disconnect your Negative Battery Cable.
Remove Steering Wheel (you'll need a Puller, the remove the Shroud around the Steering Wheel Colume.
CAUTION= If you have Air Bags be careful. But you will have to remove the Air Bag Module by removing the coil lock spring Screw.
Then remove the Retaing ring and Coil Spring it will still be attached to your wiring=Just let it Hang.
Next you'll need a Compression Lock Spring Plate Tool.
Attach it to the Center of the Steering Colume, Rotate the Nut Clockwise to Remove,After Compressed you'll see a Metal Snap ring Remove it from the Groove then remove the Tool& Plate
Now you'll need to remove the Plastic Cancel ,the ring and ALL the Bearing including the Bearing Race.
Remove the Signal Arm Lever Screw. then the Signal switch Screws. Pull the Switch out and let it Hang(Still attached to the Wiring.
Get down under then you'll have to look for the screws that hold the wiring to steering colume, Remove then.
Then remove the Retaining Rng and the Wire Plug Protector.Now you Can Pull the Signal Swith Out.
Installing New Swith Simply Reverse the Removal Directions to Install your New Switch.
Please take time to Vote on my Quality of Service and the Help i Provided And a Small Testamony would be Great.If you don't mind.
Thanks for Using FIXYA
Jul 05, 2010 | 1992 Buick LeSabre
Need help wiring up turn signals
You '93 Sporty has a turn signal cancelling unit that controls the turn signals. Could you be more specific as to what kind of help you need in wiring up the signals. If the turn signal unit has been removed from the bike, that unit alone cost somewhere in the vicinity of $150. Please contact me directly at wd4ity@bellsouth.net and maybe I can help you more.
Feb 03, 2010 | 1993 Harley Davidson XLH Sportster 883
Having problems with my turn signals, they do not work when i just click the turn signal, I have to hold them in a specific way for them to come on.
step by step heres what you got to do
1.disconnect battery ground cable
2.remove nut retainer and jam nuts hten steering wheel
3.remove turn signal cancel cam assembly
4.remove hazard warning screw and knob
5.move the turn signal switchso you can access the turn signal screws and housing screws which can be accessed through the opening in the switch
6.remove housing screws and housing
7.only on models with tilt steering wheels remove shoe pin retainer cap
8.remove pivot switch screw and pivot pluse switch assembly
9.remove turn signal screws
10.remove wire prtecting from opening in instrument panel bracket assemblyand seperate from wires
11.disconnect turn signal switch connector from ignition and dimmer switch assembly connector
12.disconnect 17 wy lock from turn signal connector
13.use ternimnal tool #j-35689-a or equivelent, disconnect wires on buzzer switch assemble from turn signal connector
14.remove turn signal switch assembly from column
15 reverse to put back together
16. please note that signal and column housing screws got to be torqued to 35 inch lbs the switch screws at 20 inch lbs hazards at 7 inch lbsand the jam nuts at 30 ft lbs
Nov 21, 2009 | 1992 Pontiac Grand Prix
1992 cavalier ignition switch and key assembly
The following procedure is "generic" for replacing the lock cylinder. There are a couple of specialized tools you will need and saftey precautions concerning the air bag system.
Take a look and let me know if you wish to tackle the job.
Regards,
To remove the ignition lock:
CAUTION You must remove the steering wheel when replacing the ignition lock. On vehicles with a Supplemental Inflatable Restraint (SIR) system, you must temporarily disable the SIR system and remove the inflator module when removing the steering wheel. Leaving the SIR system on could result in deployment of the air bag and possible personal injury.
  • Disconnect the negative battery cable, and remove the steering wheel.
  • Remove the bumper and the carrier snapring retainer from the steering shaft.
  • Use a lock plate compressor screw tool to install the lock plate compressor screw in the upper steering shaft. To keep the shaft from telescoping, tighten it to 40 inch lbs.
  • Using the lock plate compressor tool, install on the upper steering shaft, tighten it to depress the shaft lock. Remove the shaft lock retainer, the compressor tool and the steering shaft lock.
  • Remove the turn signal canceling cam assembly. Put the turn signal switch in the "N" position and remove the upper bearing spring.
  • Position the turn signal switch so the mounting screws can be removed through the holes in the switch and remove the turn signal lever.
  • Remove the turn signal switch-to-steering column screws and lift the turn signal switch. Remove the wire protector and disconnect the turn signal switch connector.
  • Use a terminal remover tool to disconnect the buzzer switch wires from the turn signal switch connector. Remove the buzzer switch assembly with needle-nose pliers.
  • Place the lock cylinder in the ACC position, then remove the lock retaining screw and the lock cylinder set.
  • To install the new cylinder lock, reverse the removal procedures.
  • Tighten the lock retaining screw to 22 inch lbs., the turn signal switch screws to 59 inch lbs. and turn the turn signal lever screw to 53 inch lbs.
  • As part of the final replacement procedures, check the operation of the switches and the steering column.
Mar 04, 2009 | 1992 Chevrolet Cavalier
2000 chrysler cirrus
Hi...
You are looking for the location of the TURN SIGNAL FLASHER.
The turn Signal flasher on a 00 Chrysler Cirrus.
Is mounted inside of the Turn Signal switch.
Some model If you remove the steering cover you will have axces to the Flasher.
But In some Model you will need to replace the Multifuntion Switch ( Turn signal switch)
OK.. I hope this help on your question.
I'm Based on a AUtorepair Software. to give the answear..
Thank you for use fixya..
Aug 06, 2008 | 1996 Buick Century
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
