Question about Casio Baby-G Shock Resistant Watch BGD100-1B
Baby g watch put in mute - Casio Baby-G Shock Resistant Watch BGD100-1B
How do I fix the sound on a baby g watch?
if you had battery replaced,they may have lost a spring.there is a mute mode. your manual number is on back of watch in a box. use that number to look up the manual in casios website.you can set tone
Mar 25, 2012 | Watches
I own baby g 3786 watch and need new strap for it. where can I buy it?
I've had to send mine to Casio every time I've needed a new band. It's a PIA. I wish I could find another way to replace it. They will only put the same band back on. I'd like a different band that is a little more durable. Good luck.
Jan 07, 2011 | Casio Baby-G BG370S-4V Wrist Watch
How can unmute my watch. even the alarm tone is on mute.
Um, well I had the same problem on my baby-g watch, but i fixed it so here:
- dunno if this'll work, but hold the bottom left button for a long time. never let go till you here a beeping noise. like DO NOT let go. like this is a g-shock and not a baby-g, i dunno where the mute is indicated, but u might see it somewhere. so, just do that dunno if it works as, again, i have a baby-g. good luck! :)
Nov 30, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
How do u turn off the alarm on a baby g shock. Like how do u turn it off forever?
mcdevito75 Here, You should be able to reach the alarm thru the MODE cycle, Press MODE and see Flashing display, press Mode for each function till you reach alarm and put alarm to off, if you have t1 and t2 time you"ll have to do this twice.
Oct 26, 2010 | Casio BG191 1B2 Baby G Watch
How to take my watch of mute
press and hold Adjust Button for 2 seconds
Aug 19, 2010 | Casio Baby-G Wristwatch
I need to change a battery in a baby g watch
mcdevito75 here, Casio watch with the LCD display, any wrong pressure on this display and your Casio is ruined, the liquid display can break very easily. BEST BET, look for a small watch repair shop in your area for this battery change.
Jul 14, 2010 | Casio Baby-G Wristwatch
Want to set the time on baby casio baby g watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please
Mar 18, 2010 | Casio Baby-G BG169-2V Wrist Watch
Can I replace the battery in my Casio Baby G BG-460?
Replacing the battery is best done by an experienced technician, especially when they are a waterproof variety, as the seal is very important.
Getting the back of is sometimes much easier to do than putting it back on again.
I advise you take it to your nearest dealer in your make of watch.
Jan 14, 2010 | Casio Baby-G BG460-8V Wrist Watch
When I press light buttopn in the middle the display goes blank
This sounds like a simple battery replacement. Depending on how low the battery is usually pressing the light button and the display goes dim or blank is a good indicator of this. Takes a CR1616 battery and be careful of the spring inside and make sure the seal is in the correct position. You will need to touch the AC button and the back of the battery with a pair tweezers for a couple of seconds to reset the watch. Put the case back on and set the watch thru the functions.
Dec 06, 2008 | Casio Baby-G BG169-2V Wrist Watch
Baby-G 3687
This is suppose to be an auto setting watch, see Support FAQ link...
http://www.baby-g.com/support/
Find the manual here...
http://world.casio.com/wat/download/en/manual/
Jun 25, 2008 | Casio Baby-G BG370S-4V Wrist Watch
Casio Baby-G Shock Resistant Watch BGD100-1B Logo
79 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
