Question about HTC Explorer A310e Android 2.3 Unlocked Quad Band PDA Phone Black
Touchscreen calibration my phone touch screen not working properly. i have calibrated the screen from setting. please tell me any other way to calibrate the touch screen of my htc explorer.
3 Suggested Answers
jonniewalker
  • 1029 Answers
SOURCE: How do I calibrate my touch screen
Calibrate the g1 touch screen on the device by going to Start>Settings>System Tab>/Screen then Click Align Screen If you cannot get to the Screen Alignment utility using the menu’s, it can also be accessed by pressing the Volume Up and Center Navigation Buttons at the same time.
hope this helps, pls appreciate by rating as fixyaa
Posted on Jan 13, 2010
  • 195 Answers
SOURCE: need to calibrate my phone
click on start,settings,screen or start,settings,power,adjust backlight,screen!
Posted on Mar 20, 2010
Htc prophet touch screen issue
for window phones
1. Press the "Home" key and press "Start." Use the directional pad to highlight "Settings," then press the center or "Enter" button.
2. Use the directional pad to select the System tab. Select "Screen," then press the center or "Enter" button. Select "Align Screen."
3. Using your smartphone's stylus, tap the crosshairs as they appear on your screen. Do this for as many as appear, until the calibration tool finishes. Your screen is now properly calibrated.
for Android phone
4. Press the "Home" button or capacitive area, then press "Menu." Tap "Settings."
5. Tap "Language and keyboard." Tap "Keyboard settings." Tap "Tutorial" and go through the steps that appear on your screen.
6. Once this is finished, turn your phone off and on again. Your keyboard has been adjusted, which activates a re-calibration of the capacitive touchscreen. (Capacitive screens are technically far more accurate that resistive, and so a full calibration tool is not included with Android phones.)
Aug 20, 2012 | imate JAMin Smartphone
My touchscreen is not work
If your touch screen is not working, theres just 2 major causes of such, either a hardware cause which might be either the phone falling on a hard object or in water which could damage the sensor board and either the screen is malfunctioning and needs to be calibrated.
If you can access the menu of the phone, i will advice you calibrate the screen first before you send it to a repair shop. There is no updates to download for such problem as updating the firmware of the phone would do nothing but change the settings of the phone.
To calibrate the screen, you will have to go to the phones menu, go to settings, then you select the calibrate screen, it will show you some stars to touch and once you touch them properly, then your screen will be able to work effectively.
But if you cannot access the menu because of the touch, then i will advice you send it off for repairs, and what to repair on the phone is the sensor board.
Hope this helps you.
Jun 18, 2011 | LG KU990 Viewty
Touchscreen not responding
If the touch screen of your phone is not responding to touch then it means you have to calibrate the screen to get it working once again.
To calibrate your screen, be sure that the nuvi is properly charged, then you follow the steps below:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen, turn on the nuvi.
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears(white screen with touch dot),
  5. Then follow the on screen instructions.
That should do the job for you. hope this helps.
Jan 10, 2011 | Garmin nuvi 255W GPS Receiver
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
Nuvi 760 powers on but the touchscreen will not work
If the Touch Screen is not working properly, Calibrate the touch screen..
Turn he unit off then on.... Slide Power Key to the right ( lock )
Hold finger on screen for about 30 seconds until calibration screen appears... for on screen instructions
May 10, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
HOW CAN DO PHONE CALIBRATION?
Over the time, the touchscreen might have to recalibrate for better touch precision. If you press 1 but it activates 2 in the To calibrate Nokia 5800 touchscreen: Click the menu key > Settings > Phone > Touch Input > Touch screen calibration. There you are prompted to tap centre of target with stylus, where the 4 circles (target) at the corner animates one by one to guide user complete the touch screen calibration process.
May 05, 2010 | Nokia 5800 XpressMusic Smartphone
My touchscreen is off point, and my calibration wont work
have you tried reswtting it to factory settings. make sure there is nothing putting pressure on the touch screen. If this soesnt work you may have to replace your touch screen. mysciphoneshop.com offers replacements, but they have to be soldered in be careful if you decide to do this.
Apr 04, 2009 | Dual Electronics CECT P168 Cellular Phone
Touchscreen calibration in ubuntu
The touch screen on these models do not have a calibration setting. They work or they don't. If it not working properly you can try uninstalling the drivers for the touch screen, then reboot. The machine will find the touch screen and reinstall the drivers automatically. Also check for any updated drivers at Panasonic's support site. Then check the connection for the touch screen, the touch screen has a separate connection than the screen, and it may have worked loose or have a little dirt or corrosion built up. If this doesn't work, then I'm afraid that the touch screen may be wearing out, nothing you can do for this.
Sep 01, 2008 | Panasonic Toughbook 28 Notebook
HTC Explorer A310e Android 2.3 Unlocked Quad Band PDA Phone Black Logo
132 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
