Question about Fisher and Paykel GWL11 Top Load Washer
Mw511 pump removal guide
  • Fisher and P... Expert
  • 554 Answers
Pump removal
Posted on Dec 13, 2013
Mw511 fault code
For an error code the lights don't flash they just stay on
and beeping sound.
Your pump could be over-current and faulty.
Apr 20, 2014 | Washing Machines
Mw511
The MW511 are 24volt solenoids.
Jun 10, 2013 | Fisher and Paykel GWL11 Top Load Washer
Help F&P MW511 beeping and not draining
You have Error code 37,
37.
(00100101) Pump Blocked Error (No change in the water level)
While draining, the water level reading from the pressure sensor has not changed for over 3 minutes. There are three likely reasons for this fault. One is that the drain hose or the pressure switch hose has been squashed or kinked and the pump out rate has been dramatically reduced. The second possibility is that the pump is partially or fully blocked. The third is that the pump is not operating due to Motor Control Module, wiring or pump failure. This fault could also appear if the machine is pumping to an unusually high head of drain hose or into an extended length of drain hose. The fourth possibility is a diverter valve fault or blockage, water level is not altering as the diverter is stuck in the recirculation mode, giving the module the appearance the pump is not lowering the water level.
Primary Source:
Action:1)
Pump System.
Check that the drain hose has not been kinked.
2) Check the length of the drain hose and try to reduce the length if
excessively long. A 39.36in / 1 metre extension hose of the same diameter fitted to the existing drain hose is the maximum allowable length.
3) Check for open circuit windings in the pump. (Note: Pumps are
fitted with a thermal cut-out, which will reset on cooling.)
4) If the basket is empty of water, remove the pump from the pump
housing and check that it is not blocked. Also check the drain hose is not blocked.
5) If the basket contains water, then service the pump from the top of
the machine by removing the top deck and inner basket. Bail out the water, remove the pump cap and hood and clear the restriction.
Secondary Source: Wiring.
Action:
Tertiary Source:
Action:
1) Check the pump harness is connected correctly to the pump. 2) Check continuity of the pump harness.
Motor Control Module module.
Activate the pump by operating the machine in spin mode. Check the pump is rotating. If it is not operating, and Primary and Secondary checks have been performed, then replace the Motor Control Module.
F&P MW511 HELP beeping and not draining
You have a blockage in the drain hose or pump,
Try to drain all the water out before you remove the pump
Error Code 37,
37. (00100101) Phase 1 to 6 - Pump Blocked Error ( No change in the water
level)
Controller module, wiring or pump failure. This fault could also appear if the
length of drain hose. The Fourth possibility is a diverter valve fault or blockage,
Primary Source: Pump System.
Action:
1) Check that the drain hose has not been kinked.
2) Check the length of the drain hose and try to reduce the length if excessively
long. A 1 metre extension hose of the same diameter fitted to the existing
3) Check for open circuit windings in the pump. (Note: Pumps are fitted with a
thermal cut-out which will reset on cooling.)
4) If the bowl is empty of water, remove the pump from the pump housing and
5) If the bowl contains water, then service the pump from the top of the machine
by removing the top deck and inner bowl. Bail out the water, remove the
Action:
Tertiary Source: Motor Controller module.
Action:
been performed, then replace the Motor Controller module.
Note: Consider fitting Pump Hood Kit (WM013). If 5kg Smartdrive fit splash guard to
pump.
Fisher and paykel mw511 pride wont turn on
Your pump could have blown the in the 4 amp in the board
Check your pump should be 34 Ohms
or higher, but not less then 28 Ohms if so replace pump and the fuse
The 4A fuse is near the AC plug on the board.
Apr 18, 2013 | Fisher and Paykel Washing Machines
Water Ran out from under machine
Is the pump making loud noises.
If so the pump seal has perished,
Replace your pump.
Aug 14, 2012 | Fisher and Paykel Washing Machines
Mw511 Fisher and paykel washing machine does the cycle fine but now won't empty the water. How can I take the back of the machine to see if something is blocked?
You don't need to remove the back, tilt the washer back in the front right corner is the pump. Try to turn the impeller if it wont turn its either blocked or failed. Bail the water out of the washer push the tab on the pump and twist the pump will come out so you can clean the debris inside.
Good luck with your repair!
http://www.appliancerepairlesson.com/
Mar 05, 2011 | Fisher and Paykel GWL11 Top Load Washer
Squealing sound on spin cycle.........
Turn power off AT THE WALL,under the wash bowl Spray some wd40 on to the pump at both ends, while this may stop it for a while. Your pump may well be on its way out. you should replace for a new one. bad pumps can cause more problems problems .
Mar 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel (mw511)
check out the DRAIN MOTOR PUMP , its a small motor with 2 hoses connected to it , it could be clogged , need to remove it , inspect inside the impellers for any debri , clean it , re install and try again , hope this helpful AJ
May 20, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
