Question about Vehicle Parts & Accessories
Fluid not reaching rear widow is there a hidden resivior
  • chelle thomas Jul 13, 2013
    my brake lights work. i have a 1.6 , 2007 dymanique. Ive had the car for two weeks, ive taken it back sevral times , had the drop links changed .
    Top Expert:
  • 78,267 Answers
Make, model and year required.
Posted on Jul 12, 2013
Where can I locate the rear windshield fluid reservoir?
Most model vehicles the same resiviore for the front also supply the rear, if it's full and the front works, the rear hose or spray orifice may clogged ?
Feb 20, 2015 | Cars & Trucks
What should the power steering fluid resivior be at for a 2002 mini cooper be at
fill it to the second line on the stick and make sure to use only pentosin power steering fluid.
Feb 13, 2013 | 2002 Mini Cooper
Unable to bleed the brakes how do you bleed the reakes out
First fill the brake resivior then have someone pump pedal three times and hold pedal down, while you start at the right rear wheel open the bleeder screw and let fluid out and then close make sure who ever pumps pedal keeps preasure on it as you open bleeder because pedal will drop they must push and follow pedal, after you clsoe bleeder you then have them pump pedal again three times you will do this four to five times on each wheel make sure to check fluid level after each wheel is bleed, after the left rear you move to left rear then right front then last is left front, hope this helps.
Sep 11, 2010 | 2003 Volkswagen Passat
I added fluid for the windshield wipers but the rear does not work? Is there a different resevoir for the rear wipers of a 2005 GMC Yucon?
Hello. No separate reservoir. It can be the relay,the circuit from the switch,or the pump.Most of the time it is the pump.
please rate my answer as very helpful. thanks. Joe
Apr 15, 2010 | 2008 GMC Yukon
1998 Ford Explorer Where is the rear windshieldwasher fluid resivior located?
The rear windshield washer fluid for the rear window uses the same as the front. if it is like a '99 Explorer, it has one pump that has reversing current controlled by two relays . Access the relay box by removing air cleaner top and hose near right front corner. The front and rear washer relays are the two near the rear of the box. One of the two is sticking or has corroded terminals. You can use the horn or a/c relay from the relay and fuse box near the battery.Good luck and hope this helps.
Dec 08, 2009 | 1998 Ford Explorer
How do I change the brake fluid of my mini cooper s 2006 model, thanks.
this is something if you need to ask you need to leave to the professionals . not to be mean but that is your life you are playing with and one little air pocket in the line could cause you your life. buy the way it is a 2006 there really shouldn't be any reason you should need to change this yet.
any way take the cap off brake bleeder loose at the pass side rear and use a brake line bleeder kit to drain the fluid any refill the resivior as needed then do the driver rear bleeder then the pass front then the driver front
just rememver to never let the resivior get empty
Oct 05, 2009 | 2006 Mini Cooper
Wind shield washer fluid stopped working 2005 excursion
Pull resivior and see if it gelled up around screen for pump motor.Cheaper washer solvents tend to do this,If so you can clean screen and it should be ok.Note sometimes you can look down in liquid with flashlight and see gell in resivior.
Jun 19, 2009 | 2005 Ford Excursion
Power Steering Fluid Reservior
the resivior is behind the motor on the pasenger side about half way down the motor
Feb 27, 2009 | 2002 Chevrolet Impala
Brakes
once you remove the caliper bolt and get calipers out of the way, just a BFH to remove the hubless rotors
Jan 15, 2009 | 1997 Dodge Ram 1500 Club Cab
Replace Fuel Filter
Just unbolt it on top and bottom and replace (remember to use two wrenches so that you don't break the hard fuel line or the mounting bracket).
The filter is located directly beneath the windshield washer fluid resivior. You will have to remove the washer fluid resivior and possibly the brake fluid resivior as well as they both get in the way.
Disconnect the filter on a surface were it's OK to spill gas on the ground, when you take the hose of it will pour out it's contents.
Oct 11, 2008 | 1998 Mitsubishi Eclipse
Vehicle Parts & Accessories Logo
29 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
