Question about Photography
Workshop manual download
Who to replace water pipe in freezer door
3 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: can the water pipe in a GE SBS door be replaced?
Hi and welcome to FixYa. I am Kelly.
Open the door and then lift
gently the door seal from the inside. You will note that there are screws in the door. All you have to do to open the door is remove all of the screws for the door gasket and possibly a fet bor for the mteal retaining place for the door seal. The door will come apart but is is a tedious process to get it back together if you do not lay it flat. Sometimes you get lucky but if there are 2 people then you can do it door on. The water line is replaceable but usually you need to know how long of a water line that you need as it is sold in bulk by the foot. It appears that there is a hose just at the hinge point that can be purchased separately.
Take a look at this link for the Location of the hose here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5209032&diagram_id=22190124#d22190124
It looks like item 80 that your talking about.
Just take your time and do not get in a hurry. Things have a tendancy to break.... (lots of experience on my part!)
Thanks for using Fixya.
Kelly
Posted on Jun 26, 2010
  • 106 Answers
SOURCE: The water from dispencer is not coming out and the
no it is not possible because while assembling the fridge all the parts are assembled saperately
Posted on Dec 13, 2010
How do I get the water I need to drink - to come from the dispenser?
Hi Holly
Is pipe getting pinched somewhere.
Disconnect & blow through pipe to test.
Sep 13, 2015 | Electrolux Refrigerators
Inside of freezer door bubbled up
If the pipe that burst was spraying water onto the refrigerator, it is likely that some water got between the inner panels of the freezer door. This water then froze and expanded, pushing out the inner panel of the freezer.
Jan 21, 2013 | Refrigerators
Doewoo no frost fridge freezer is working fine except that we keep getting puddles of water under the freezer door. any ideas. had about 4 years now
probably a blocked drain outlet or pipe. At the bottom rear of the unit, mine had a drain pipe blocked with a plug of mould (5/6 years old machine), apparently quite common. I detached the pipe and cleaned it out and replaced it.
From inside the freezer, I removed the lower back panel and thawed the ice build up on the drainage tray below the defrost heating element, leading to the pipe outside. The puddles of water that was appearing every defrost cycle have now stopped - permanently I hope. Hope this helps you
Sep 02, 2012 | Daewoo Refrigerators
Freezer leaking water even though water turned off
Is the water leaking from the door, onto the floor in front. If so, probably a blocked drain outlet or pipe. At the bottom rear of the unit, mine had a drain pipe blocked with a plug of mould (5/6 years old machine), apparently quite common. I detached the pipe and cleaned it out and replaced it.
Jun 04, 2012 | Daewoo FRSU20IC (21.8 cu. ft.) Side by...
Our BEKO AP930 fridge freezer ice maker stopped working and we replaced the ice sensor but now the water dispenser isn't working. pipes connected correctly and there is a water suppky, Any ideas??
i had a similar problem with mine and the advice i got(possibly on here) was to leave the freezer door open to let the water supply pipe in the door defrost,put some blankets/ towels in the freezer to stop the
food defrosting,it worked for me and only took about 10 mins.
Dec 30, 2009 | Freezers
Not getting water from dispenser in door
if you can get ice but not water from the dispenser then suspect a frozen water line within the door . Check you get water to the connector at the bottom of the freezer door. Sometimes you can clear the blockage by connecting a steamer to the pipe but this will only be a temporary fix . If the pipe has frozen within 6 inches of the dispenser outlet then there is a heater mod that can be fitted WR49X10173
Nov 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GSS25L GE no water
Check the electrical connector that is next to the water pipe at the bottom of the freezer door
Aug 19, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
No Water At the Door
I use an old style "pipe cleaner" soaked in very hot water and pushed up the tube at the door. The blockage is usually about 3-4 inches up the tube where it freezes. The hot water on the pipe cleaner takes only a minute or so to soften the plug enough for it to push through. Re-heat the pipe cleaner in the hot water often so it melts quicker. The ice plug is typically about 1 inch long in that small tube so it doesn't take much to get the water flowing again.
Jan 26, 2007 | Hotpoint HSS25GFP Side by Side...
Photography Logo
250 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
